Flex Fuel Composition Sensor Duplicator - Replicator - Eliminator - S-10 Forum
Go Back   S-10 Forum > S10Forum Flea Market > For Sale
Old 02-11-2012, 06:21 PM   #1
Registered Un-dependent
Mechnix's Avatar
Eliminate that irritating check engine light caused by a bad: Flex Fuel Composition Sensor
Driving with the SES - CEL light on, you won't know if a new problem is about to leave you stranded!
Plug & play design using OEM Delphi Weatherpack connector.
No splicing,crimping or modification of your vehicle.
Easy 5-10 minute installation
Make sure you or your mechanic has verified the wiring going to the flex sensor-FIRST, unplug & test:
Pin A-White 5-Volts
Pin B-Pink 12-Volts
Pin C-Purple Ground
If you don't have these meter readings then you need to repair this problem first, it may be all that's wrong!
Duplicate, Eliminate,Replicate
GM Part# 12568450 & 12570260
Eliminate SES - CEL DTC Codes:
P0176 Flexible Fuel Sensor
PO178 fuel composition circuit Low input,output,frequency
PO179 fuel composition circuit High input,output,frequency
Product sets engine to run on regular gas, you will no longer be able to run E85, which is not cost effective anyway.
Works on
2000-2002 GM 2.2L Chevy S-10 2WD pickups
2000-2002 GMC 2.2L Sonoma 2WD pickups
2000-2002 ISUZU 2.2L Hombre pickup
2002-2005 GMC 5.3L V-8 Sierra half-ton pickups 2WD & 4WD
2002-2005 GMC 5.3L V-8 Silverado pickups
2003 Chevrolet 5.3L Avalanche 4-door pickups
2005 GMC 5.3L (Vortec) Avalanche
2002-2005 GM 5.3L (vortec) Suburban SUVs (all)
2002-2005 GM 5.3L (vortec) Tahoe SUVs (all) Fleet 2005 GM 5.3L (vortec) Tahoe police package
2002 GM 5.3L (vortec) Denalis (all)
2002-2005 GM 5.3L (vortec) Yukon & Yukon XL SUVs (all)
Rigorously tested on fleet vehicles,with an estimated lifespan of 650,000 miles- eliminated DTC codes,easier starting,smoother running and an average 1-2 MPG improvement.
Replaces costly GM Part# 12568450 & 12570260 @ over $600 plus and 2-3 hours labor to replace
Proudly Made in the USA by 40 year veteran mechanical-electronic technician.
30 Day money back guarantee
1 Year product warranty against defect in material and workmanship
Physical damage or tampering with unit will void this warranty
Free Priority Mail w\tracking
$129.95 ($20.00 discount over my Ebay price)
Send an Email to net_sale@comcast.net
I accept Paypal and I am Verified
