where should i mount my fuse holder?
tryin to find a place under the hood to mount this...
JED
Re: where should i mount my fuse holder?
firewall
well for one move the power wire to the battery and off the 10ga diss block it's on now because if i remember it is on a 30 amp fuse link and you will toast it and then just mount it any were it will not get hot or rub on any thing
gona be doing the big 3 soon.. and was thinking of replacing that "power supply box" with a distro block and run my 4 gauge wire to it then a 0 gauge to my battery and then still have spots for the big 3..
oh noez |
oh yess
Registered Minitrucker
something like this is clean, i was able to ditch the chevy dist block and dont worry about what draginlow mentioned about the 30 amp what ever,...i have popped the 60 amp fuse you see there 3 or 4 times in the last couple of months and havent had any issues
he needs to up grade the wire going to the dist block if he is going to go that way like you have or just go to the battery |
takin it easy
Phoenix Gold?
yah its pg (phonix gold)
Panda s10 driving mofo.
Location: Birmingham/Anniston Al. User is: OffLine ![]() |
yea its a pheonix gold block,... here are some more pics of the setup and big 3... i wrote with yellow in mspaint i hope you guys can read it.... ![]() ![]() ![]() ![]() ![]() ![]() |
so yellow wasnt to good after all....lol srry.
so should i move the amp wire to my battery or leave it on the block? i got 4 gauge wire for my power from the amp that should b plenty for what im running. then after i get my check and some bills paid next week im gona get about 15 foot of 0 gauge and 2 top post terminals and do the big 3.
http://www.knukonceptz.com/productDe...?prodID=KLM0BL http://www.knukonceptz.com/productDe...prodID=KBT-30P http://www.knukonceptz.com/productDe...prodID=KBT-30N Last edited by lwrd93 : 07-04-2008 at 10:07 PM. |
amp wire should be directly on your battery
good wre and post?
wat?
i mean to say is this good "wire and post terminals"
wat?
umm pretty sure u are dumb
#24 |
#25 |
hmm i might hold off on the 0 gauge into the cab for now funds are low.. how much will i need to do under the hood? are the alt's on the same side on the older and newer style trucks?
#26 |
ok so i just got a rebuilt motor put in and i think they grounded it at a different spot than original i use to have about 3/4 my battery gauge now its not even half... there are 2 wires comin from the one goes to my starter and other to my alternator then there is a ground little one goes to my headlight i think and then the bigger ground is bolted to my block. there is a whinning noise when its idle and when i rev it u hear it get faster didnt have that before my friend said sounded like my alternator.. what are the correct grounds and postives stock?
#27 |
I would suggeat MOVING IT to the battery . An like seriously if your going to take someone's advice who says this Be my guest , There is a REASON his fuses are blowing .. an I'am going to leave it at that . Do whatever you wish . |
#28 |
Sounds like you have a ground loop. I would try fixing that main ground wire to begin with.. that COULD solve your problem.
#29 |
it didnt do it before the engine rebuild though? and im not talking about the wire going to my amp im tlkin about the normal wires if u didnt have a amp at all... factory stuff
#30 |
#31 |
in my opinion and what i done to mine. i mounted mine right on my box close to my amps. but i made a custom dist block.
#32 |
i wana see some under the hood pics of ppls fuse mounts..
#33 |
