↓ Ms.No-Name
hey guys..
this maybe goes to judd or paint or anyone else for the help my question is.. i want to tune my subs to the max performance. so that why i was look at this http://mobile.jlaudio.com/support_pages.php?page_id=143 tuning with a volt meter? but what i dont get is how many watt(or volts) do i need to get up too and how much is it to the subs ? (ie say 14v what does that = to? as for watts) thx ![]() |
i'm back
Location: morton il User is: OffLine ![]() ![]() ![]() ![]() |
Re: tuning by meter ?
i could not tell you what the formula is or how they come up with those numbers....but that is jl,for maximum performance with no clipping......rest assured,that chart is not for every amp out there,it's jl specific.
i'm sure any respectable amp manufacturer will have a recommended voltage you need to set at,call your amp maker |
↓ Ms.No-Name
i knew there was a site that had the formula's all u did was punch some numbers(watts) in and it would give u the volts number.. but that site went down. maybe someone else knows. thx i appreciate ![]() |
i'm back
jed would know...
The How-To Guy
Location: Cache, OK User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
OR i would know......maybe.
I think i remember that site, i saw it posted on here awhile ago. Good thing i saved the PDF .hope this helps, i don't know if this works or not i haven't tried it. ![]() Last edited by beandip : 07-24-2008 at 07:13 AM. |
JED
i'm heading to ohio right now. you can survive a few days without me joe
alot of those formulas also assume that the amps are 100% efficient, are you talking about setting your gains?
↓ Ms.No-Name
beandip -
umm..i dont really know about that farmual.seems a lil too easy .but if some one can back this up i try it. because the site that i seen say like u play a hz (32hz) then tune for a watt number? skinnyg yes im trying to set the gains, thx. ![]() Last edited by AVNCHRIS : 07-24-2008 at 02:03 PM. |
The only accurate way of finding out the wattage going to your subs is by first checking the voltage at the terminals, and then checking the amperage with a clamp on meter around one of the leads (either the positive or the negative, not both) going to the sub. Wattage= Amperage x Voltage.
The method shown by beandip can vary drastically, since the impedance of the sub will change with frequency; and there is no magical frequency where every sub will play at its nominal impedance. When it comes down to it, the best way is to use your ears; since that is what you attempting to please anyways. I assure you that if you tune your system by ear, that the difference between what you feel is perfect and the few watts that might be left on the table will not be enough for it to make any discernible difference to you at all. Another thing to keep in mind, that multimeter doesn't know what distortion is, nor what a clipped signal is. The quality of the CD can effect your tuning, as music that is recorded at -0dB is going to be louder than a burnt cd recorded at -5dB. There are many ever changing variables that can come back to bite you in the arse if you are trying to tune by numbers and not by your own judgement. |
↓ Ms.No-Name
all this is confused me. now. but really thanks for the help everyone ![]() |
