Subs constantly rumble? - S-10 Forum
post #1 of 11 Old 01-16-2011, 01:05 PM Thread Starter
User is: papasmokes420 is offline
Hi, i have two 15 inch kicker cvrs hooked up to a 3200w power acoustik amp.. and when the volumes down all the way, the subs rumble? and when i turn the volume knob from 0 to 1 or vise versa, the subs hit like a pop sound almost? i changed my ground numerous times to different locations, and still hasnt helped, anyone have any ideas? i dont wanna blow my subs or amp..
post #2 of 11 Old 01-16-2011, 01:50 PM
Mr. SQ
bobditts's Avatar
User is: bobditts is offline
Re: Subs constantly rumble?
have you tried different RCAs? are you using a converter?
bobditts is offline
post #3 of 11 Old 01-17-2011, 03:32 PM
My mirror hates my sub
Speedy2222's Avatar
User is: Speedy2222 is offline
Send a message via AIM to Speedy2222 Send a message via MSN to Speedy2222 Send a message via Yahoo to Speedy2222
shitty amp?
-Speedy
97 s10 - Audioque SDC2.5 15 3.5cu 34 hz
post #4 of 11 Old 01-17-2011, 05:45 PM
badmofo529's Avatar
User is: badmofo529 is offline
shitty subs?
post #5 of 11 Old 01-17-2011, 06:21 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
Feedback.
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #6 of 11 Old 01-20-2011, 07:18 PM
NOS make light brighter!
danssoslow's Avatar
User is: danssoslow is offline
High noise floor, gains turned way up. Turn your gains down and see if it goes away.
My V6 runs awesome. Friends have told me it runs like two 4's!
post #7 of 11 Old 01-20-2011, 09:26 PM
Slowly but eventually
98lowerednewproje's Avatar
User is: 98lowerednewproje is offline
I don't know alot about these things, but maybe you have your power wire running right next to your RCA's? I have heard it creates a noise in the subs? I might be wrong about that though.
Procrastination has carried me this far in life, it will carry me to my grave, and hopefully put that off as well.
'98 RCSB on jack stands, waiting on me to get the 4.8 and T56 swap together, while I steal parts off of it to keep the daily going.
'99 2DR 2WD Blazer that I bought for a daily but just can't leave it alone.
post #8 of 11 Old 01-26-2011, 02:46 AM
User is: clutchxr is offline
I used to have a power acoustik amp in my 64 impala. Only way I could listen to it was to keep the gain almost all the way down. Not sure if it was because the amp was junk or if that was how it needed to be set to work with my head unit. Was loud enough to get me a $500 fine for noise polution. Still I think these amps are overrated. The one I had used 4x20amp fuses. There is no way it could make 2000 watts if amps x volts= watts. basically you get what you pay for. I think my amp was hundred something new.
clutchxr is offline
post #9 of 11 Old 01-31-2011, 08:17 PM
User is: 249mx is offline
I was having the same thing, my friend said to check all the connections especially the ground he said there is something in the amp that makes it do that for protection or something?
1999 s-10 LS 4.3l vortec H.O., extra cab short bed, thrush glass pack, intake.
249mx is offline
post #10 of 11 Old 02-04-2011, 11:33 PM
working at 145bpm
DaRkCyDe's Avatar
User is: DaRkCyDe is offline
feedback from a connection somewhere, id start with running a different set of rca's outside the vehicle, if that doesnt work, switch with a different amp, and if still does it, then you may want to try to ground your rca's.. you can find info on that at www.realmofexcursion.com if you search, sometimes cd players have faulty points at the rca internals
every time i park its a mother****in car show
DaRkCyDe is offline
post #11 of 11 Old 02-09-2011, 10:40 PM
CincyTrucker's Avatar
User is: CincyTrucker is offline
Rca outputs in cd player going out. Very common in pioneers.
Edit: Guy above me said the same thing, didnt see it.
I don't get it.... These are just trucks.
