Sub Problem
Well I was crusing down the road with windows up subs low...and they went out...Cries....Thought it was fuse block. Just had not put a big fuse block in. SO i switched it out. I have a kenwood 650 amp and 2 10 inch kickers. The amp light wont turn on and no subs playing...I have a like 4 gage power wire i think...should i go bigger. Any ideas of whats wrong. All connections are tight.
Josh |
I lead the blind
Re: Sub Problem
recheck the fuse again, and make sure the remote wire is securely attached
Panda s10 driving mofo.
Location: Birmingham/Anniston Al. User is: OffLine ![]() |
Re: Sub Problem
check your power wire start to finish, and check your grounds, and you're remote. possibly fuses...
Registered Minitrucker
Re: Sub Problem
back to the ground,...remeber to expose bare shinny metal fallowed with a little dye electric greese when you tighten it down. bet ya thats it
Re: Sub Problem
Well hot damn....I figured it out....*CRIES* Amp is blown....looked it side. Its nice in toasty. Thanks guys for the help.
Josh |
Re: Sub Problem
Yeah the bare metal some how turned into rust...Wierd. so it blew my amp. Josh |
takin it easy
Re: Sub Problem
moisture?
JED
Re: Sub Problem
Re: Sub Problem
![]() Josh |
Re: Sub Problem
![]() Josh |
