#1401 |
Minitruckin' 4 life!!!
Re: sound system show off!!
The whip.....
![]() The subs, and the current enclosure... ![]() The new enclosure.... ![]() |
#1402 |
This space for rent!
Looks kewl, you gonna smooth those corners over by the 2 outer speakers?
#1403 |
Thanks. Yeah, probably.
#1404 |
** Sik Addictions **
another build, i think this is #5 or 6 ive posted in here lol
... waiting to get my amp back from being repaired, should be pretty loud. i still have to make trim panels around the wall to seal it tight to the sides and roof of the cab (basically where the back side windows are). ![]() Audioque HD3's Autotek MM4000.1 I'll have more pics and a vid once i get the amp in Last edited by sLonoma22 : 10-08-2008 at 03:41 AM. |
#1405 |
doesnt have a s10 anymore
#1406 |
ADDICTIVE DESIRES
![]() I'll get some better pix up later. 4 DD 1508, 4 4" flared aero ports & an AQ2200. |
#1407 |
#1408 |
#1409 |
I want sonoma grill!
cubic feet |
#1410 |
The names Brian...
hugeass port ![]() |
#1411 |
^ Im With Stupid ^
Location: Levittown, PA-☆-NE Philly-☆-Trenton, NJ-☆Tha 19057 Bitches☆ User is: OffLine ![]() ![]() |
#1412 |
but really, these subs like 4.5 cubes net which is a lot for 15"s but they get down pretty good, so this wall is 9 cf net with 160 sq. in. port. btw, you say "only two subs", well I'll let you sit in it one day and then you WILL be saying "thats only TWO subs" ![]() Last edited by sLonoma22 : 10-08-2008 at 07:55 PM. |
#1413 |
The reason said "only 2 subs" was, because as you can see I'm running 3, and they don't take up very much room. As apposed to your 2 that take up half the damn cab. lol, but I understand now why you did it that way. If nothing else, it looks kinda intimidating. lol
#1414 |
^ Im With Stupid ^
I like his setup...
I do not think I could handle not having my back window blocked though! That is just me, maybe if I had a show truck or something, but never on my daily. |
#1415 |
here are a few of my hoopty 4L7 12s zx2500.1 zx650.2
200 amp alt ![]() ![]() ![]() ![]() |
#1416 |
Damn... that looks hella nice, man!
#1417 |
The names Brian...
Taylor1, what kind of 200amp alt do you have, whats your output at idle (volts and amps), and at what RPM does it reach full tilt?
Thanks in advance. |
#1418 |
well i have one off the ebay seller. and at a cold start it is 15 but once my engine is warm is drops to like maybe 13 but when my rpms are up it stays at about 15
#1419 |
The names Brian...
#1420 |
btw, its the CS130 case. but if you have a 4.3L i think you could get the CS144 with a bracket, that will allow you to get up to a 300amp there are brackets for the CS130 case too, buddy of mine has an Iraggi 300amp on his 2.2 Last edited by sLonoma22 : 10-09-2008 at 12:53 PM. |
#1421 |
The names Brian...
I just have yet to find out a reason why when you upgrade the output of an alternator, you loose output at idle, and it can be very hard to achieve the best of both worlds. I've read it's got something to do with a cheap regulator that isn't very compatible with the stator or something. It's been awhile since I've looked into it. |
#1422 |
#1423 |
Here is my system -Its not extreme but I like it.
#1424 |
^ Im With Stupid ^
I like your HU...Looking at the same one...
#1425 |
Heres mine, right now 1 speaker is blown.
#1426 |
Fibergalss, grey vinyl, and a spot for my amp......
#1427 |
^ Im With Stupid ^
Damn that is nice...
#1428 |
nothing fancy but it sound decent
#1429 |
^ Im With Stupid ^
BIG ports...bet that baby T H U M P S!
#1430 |
Finally got the system installed... it looks pretty nice, but I've already started talking about what I wanna do for the next setup. lol
#1431 |
#1432 |
Its that dam ADD!
