S10 Keyless Entry Remotes & Programming Instructions - S-10 Forum
post #1 of 25 Old 10-09-2005, 08:35 PM Thread Starter
User is: 93Miata is offline
Question S10 Keyless Entry Remotes & Programming Instructions
What does your local dealer charge for GM keyless entry remotes?
My Chevy dealer wants $129 a piece plus $35 for programming for each of my trucks (99 LS, 01 Xtreme).
I'm curious to see what other dealerships are charging for new remotes and programming.
I'm done with ebay because the listings show new remotes, and 3 out of 3 times I've won - I end up with junk that doesn't work and won't program. First one was superglued together and cracked. Can't check the battery if you can't even open it. Second one was completely corroded inside from water and didn't work. The 3rd one only 1 button worked and it looked like someone tried to superglue the circuit board pieces back together. Each one was advertised as new, or like new and they obviously weren't anywhere close to that. The Keyles Ride site is run by one of those same lying ebay sellers, so thats off the list too.
What does your local dealership charge? I bet there's some that want even more than what mine is charging.
93Miata is offline
post #2 of 25 Old 10-09-2005, 08:47 PM
2001 S-10 Crew Cab
HenryJ's Avatar
User is: HenryJ is offline
Re: S10 Keyless Entry Remotes & Programming Instructions
They are expensive from the dealer! I paid $46.85 for one
You can program them yourself and save that rip-off - Programming Keyless Remote Transmitters
Speed is just a matter of money...How fast do YOU want to go? -ThunderII
HenryJ is offline
post #3 of 25 Old 10-14-2005, 09:46 PM Thread Starter
Post Re: S10 Keyless Entry Remotes & Programming Instructions
I found another site online that I'm willing to give a shot - www.ThePartsYouNeed.com
The other KR site I mentioned before wants about $65 a piece with shipping for the 99 S10 remote.
They're less than 1/2 that price on ThePartsYouNeed site with the instructions included. I ordered 1 this morning.
https://www.thepartsyouneed.com/disp...productId=1063
I'll keep you guys posted. If it works good, I'm going to order one for my 01 as well.
93Miata is offline
post #4 of 25 Old 10-15-2005, 07:20 AM
carries a gun at work
bill 4.3l 5spd's Avatar
User is: bill 4.3l 5spd is offline
Send a message via AIM to bill 4.3l 5spd Send a message via Yahoo to bill 4.3l 5spd
try pming s10warehouse.
98 Reg Cab S10--5/6 drop, Street Scene valance, headers, hard tonnau, welded in Sir Mike's Rollpan, Goodmark Cowl hood, shaved doors/gate, leather blazer buckets.....pretty sure i missed a bunch.
post #5 of 25 Old 10-19-2005, 12:28 AM Thread Starter
I got my remote from ThePartsYouNeed.com in the mail today. 4 days isn't bad especially when one was a Sunday.
Programming was easy, took about 10 seconds. I can't believe a dealership would charge 1/2 hour of labor for a 10 second job. Thats a good way to lose customers.
Anyhow, the remote works great and when I went to put in an order for remote for the Xtreme I noticed I got free shipping, so I bought a 2nd remote for the LS and a pair for the Xtreme. FINALLY I will have remotes that work and that I can use.
ThePartsYouNeed.com rocks!
93Miata is offline
post #6 of 25 Old 10-22-2005, 08:16 PM Thread Starter
2nd order came in today.
Programming was the same for both trucks, and I just had to program the 99 units together to synchronize them both.
Good deal.
93Miata is offline
post #7 of 25 Old 10-22-2005, 10:40 PM
992drjimmy's Avatar
User is: 992drjimmy is offline
I got one for my 99 oof ebay for total of 12 bucks programmed it in a few minutes. It was a used but new looking remote.
post #8 of 25 Old 11-10-2005, 06:22 AM Thread Starter
They were new on the site I bought from and factory GM, nothing aftermarket.
I can't get a link for when I search S10 on their site, so just go to their homepage and type it in the search menu:
Https://www.ThePartsYouNeed.com
93Miata is offline
post #9 of 25 Old 11-10-2005, 01:55 PM
GMC99's Avatar
User is: GMC99 is offline
Send a message via AIM to GMC99
Can anyone tell me how to program the remotes for my 99 sonoma? I bought a pair of them off ebay, and they guy turned out to be full of crap. He told me to run a jumper wire between terninals 4 and 8 on my ecu port, and then do some other stuff. Well the problem is i dont have a metal pin in terminal 8 of my plug, so that wont work for me. I wrote him back about 30 times and he wont reply back cause he knows he screwed me over. Anyone know the right way to program these remotes. Ive had em for sometime now and still havent been able to program them. Thanks in advance. Chris
99 GMC Sonoma SLS 4.3L Vortec
GMC99 is offline
post #10 of 25 Old 11-10-2005, 02:57 PM
2001 S-10 Crew Cab
HenryJ's Avatar
Follow the link in my above post.
HenryJ is offline
post #11 of 25 Old 11-11-2005, 01:35 AM
GMC99's Avatar
Gotcha, I will try it out tomorrow and let you know what happens! Thanks
GMC99 is offline
post #12 of 25 Old 11-11-2005, 03:56 PM
specializing in 98-up s10
s10warehouse's Avatar
User is: s10warehouse is offline
I did this my self on my 2003 blazer programmed 3 remotes in less then a minute so here is my contribution for the month should work on most all gm's the remotes i used actually came out of a new monte carlo and worked just fine
simple dirrections
While holding the driver's side door "unlock", turn ignition on then off 3 times.
Locks should cycle lock and unlock.
After they cycle, hold the lock and unlock buttons at the same time on the first key fob, hold for 20 seconds or so, or until the locks cycle again. Then hold the lock and unlock on the next key fob and so on.
After you have programmed the all the key fobs (up to 4) then turn the key to on for 10 seconds, off 10 seconds and give the fobs a try.
95Camaro z28385ci.6spd 17K org.miles,k&n intake, 58mm tb,30lb accel injectors,msd 6al,bilstein coil overs,4 piston bembro brakes ,fikse rims front 17x9.5 275/40/17,rear 17x11.5 315/35/17bfg drags 4-sale 9k obo http://www.s10forum.com/gallery/view...Name=album2377
post #13 of 25 Old 11-11-2005, 04:05 PM
DeXtreme on 20/22's
Xtreme24's Avatar
User is: Xtreme24 is offline
i think autozone is selling factory remotes now. try them. good luck
Sean
2001 S10 Body Dropped on 20/22's
MiniTruckin' Feature September, 2010 Issue
http://www.s10forum.com/forum/signaturepics/sigpic13377_1.gif
Nfamus Air Suspension | DFWminis | Crime Pays Video
Xtreme24 is offline
post #14 of 25 Old 11-11-2005, 08:17 PM Thread Starter
AutoZone doesn't stock the remotes, they have to order them in, and in some cases they are MORE expensive than the dealer...which doesn't make much sense.
I checked with them a few months back for my aunt's Cadillac, and they said it was $129-179 for the 96 Deville Remote, and they don't provide programming so you "have to" go to the dealer.
Programming instructions were posted all over the net for those remotes, so that didn't make any sense.
That ThePartsYouNeed.com site seems to stock remotes and instructions for everything tho, and they helped me out nicely for my remotes.
93Miata is offline
post #15 of 25 Old 11-12-2005, 08:28 PM
GMC99's Avatar
GOOD NEWS!!!!!! I was able to program my remotes today. Thank you all very much for the info and correct instructions. By the way, dont buy any remotes from "autopimp_usa" on ebay. He is full of crap. The remotes he sent me were both cracked, and 1 had the writing worn off the buttons, and took over 5 weeks to ship these pieces of junk. He advertised these as being in like new condition. Then to top it off his instructions were totally bogus. They didnt work, and then after i told him they wouldnt work he wouldnt reply to my e-mails anymore. Hes a terrible seller, just keep an eye out for him if you are buying remotes on ebay. Thanks again to those of you who posted the instructions. Chris
GMC99 is offline
post #16 of 25 Old 11-14-2005, 08:41 PM Thread Starter
Chris - Glad to hear you got it figured out, but I tried to warn about the ebay crap. I got NEW remotes in only a few days for $25 (same remote for the Sonoma) and they even gave me free shipping on my 2nd order. Quite the breath of fresh air compared to the ebay scammers.
93Miata is offline
post #17 of 25 Old 11-14-2005, 11:59 PM
Blown ex ***
Jess's Avatar
User is: Jess is offline
this thread is going to "security" . where it should have been in the first place.
97, VORTECH V2 SQ / PowerStroke FMIC @14 psi, A4, 3.08
a broken down 13.88 @ 96.65
now with, 2114, 270ahr, ported heads, 1 5/8 L/T's & true duals, TunerCat, LC1 & XD-16, 3:73 Z/T
My Truck...
video = http://video.google.com/videoplay?do...55517765935057
95 x-cab, silver, tint, 4.3cpi, a4, 3/4
EDELBROCK TES & 3 1/2" exhaust for sale. PM me
Jess is offline
post #18 of 25 Old 11-17-2005, 12:24 AM
for those people with 2 trucks/blazers you can also program one remote to work on both trucks as long as the remotes are with in the same year range . my friend has 2 2000 sonomas had them both working off one remote
post #19 of 25 Old 11-18-2005, 01:04 AM Thread Starter
Hmm, I'll have to try that.
93Miata is offline
post #20 of 25 Old 07-23-2006, 12:28 AM
xxkptdeuce40xx's Avatar
User is: xxkptdeuce40xx is offline
Send a message via AIM to xxkptdeuce40xx Send a message via MSN to xxkptdeuce40xx Send a message via Yahoo to xxkptdeuce40xx
hey does anyone know how to program the remotes for a 1994 s-10 blazer?? please reply or send me a PM i just found out my truck has a keyless entry but i didnt get the remotes when i bought it THANKS!!
post #21 of 25 Old 01-22-2007, 12:46 AM
User is: s-dime-dreaming is offline
another think i would like to add to the remote is that i tried the steps above to reprogram the remote and got nothing to work so i took apart the remote and cleaned where the buttons touch the board thing(best i could come up with) and cleaned a bunch of black gunk off it and i also cleaned where the battery is held and after doing that the remote works fine so if you were like me try cleaning it i used a q-tip and wiped it clean
post #22 of 25 Old 01-22-2007, 01:01 AM
o i reread my post above and it shoudl say is another thing i think i would like to add
2000 black LS ext cab 4.3lv6 auto 4x4 2"body lift bfgoods m/t 31's euro tails and rims.....thats all i know
post #23 of 25 Old 10-26-2012, 07:58 PM
User is: steeltoe is offline
S10warehouse says cycle the ignition three times, I was told to cycle the ignition two times. Which is it? Neither of the remotes on my 2001 S10 are working anymore even though I replaced the batteries and cleaned them up.
steeltoe is offline
post #24 of 25 Old 12-09-2012, 04:57 PM
donwp's Avatar
User is: donwp is offline
Programming Instructions for 1995 S10
donwp is offline
post #25 of 25 Old 12-09-2012, 08:21 PM
24digger's Avatar
User is: 24digger is offline
You need to ground the H port in the aldl connector, I'm pretty sure that's the letter, anyway I know it's the purple wire.
Ground it and you'll hear the receiver click, the hold down the lock button, it should lock the doors.
You're done.
24digger is offline
