Protection mode...this ones got me stumped, Hifonics Brutus BX1000D - S-10 Forum
post #1 of 13 Old 11-03-2007, 05:11 PM Thread Starter
User is: OhhWatALoser is offline
Send a message via AIM to OhhWatALoser
ok friends car, Hifonics Brutus BX1000D powering a 4 ohm dvc 10 inch kicker L7. it was wired for 2 ohms.
it plays fine until he turns it up loud then almost everytime instantly goes into protection mode, but when its low volume, its fine.
tired versious test, disconnecting the sub and rca and just running the amp works fine, running the sub on my amp, works fine, my amp running the sub, works fine.
i have a audiobahn intake amp, 400x2 @ 2ohm (<---and why does it underline that) and a kicker 10 inch L5, wired for 2 ohms.
only thing i can think is when his sub hits, a loose wire of some sort inside the amp is shorting out. cuz his amp powered my sub fine, (just ran a wire from his car to mine, mayb it wasn't shaking the amp enough) and my amp powered his sub just fine, so i think that rules out any problem with his sub.
any ideas, insight, tests, anything?
i was gonna try putting his amp physically in my car and seeing if that will set it off into protection mode. if thats the case, guess ill be opening the amp up.
link to amp specs.... http://www.maxxsonics.net/manuals/hi...500D-2200D.pdf
any help will be appreciated
post #2 of 13 Old 11-03-2007, 05:16 PM
My mirror hates my sub
Speedy2222's Avatar
User is: Speedy2222 is offline
Send a message via AIM to Speedy2222 Send a message via MSN to Speedy2222 Send a message via Yahoo to Speedy2222
Re: Protection mode...this ones got me stumped, Hifonics Brutus BX1000D
bad ground most likely.. where is it grounded?
-Speedy
97 s10 - Audioque SDC2.5 15 3.5cu 34 hz
post #3 of 13 Old 11-03-2007, 05:18 PM Thread Starter
floor board, it worked fine for i don't know how long, ground never changed, ill check it tho.
why would a bad ground throw it into protection rather than just turn it off completly?
post #4 of 13 Old 11-03-2007, 05:19 PM
Speedy2222's Avatar
because it is protecting the amp..
is it on bare metal??
-Speedy
post #5 of 13 Old 11-03-2007, 06:28 PM Thread Starter
yes
whats it protecting it from?
post #6 of 13 Old 11-03-2007, 06:33 PM
It's a Blue thing...
♠ lυε ♠'s Avatar
User is: ♠ lυε ♠ is offline
Originally Posted by OhhWatALoser View Post
yes
From low voltage due to a bad ground.
-Jay
♠♣NEW CALIFORNIA S10 FORUM♣♠
www.WaylayedInc.com
♠|♦ '97 Noma Bagged DD ♣|♦ '98 S-10 4.3l Static 5/5 ♦|♣
WANTED: '55-'57 CHEVY BIG WINDOW PICKUP
♠ lυε ♠ is offline
post #7 of 13 Old 11-03-2007, 10:18 PM Thread Starter
oh no? and this hurts the amp how? im not understanding the theory behind this.
but ill still check the ground, just trying to understand this
post #8 of 13 Old 11-04-2007, 12:23 AM
Mine Sweeper!
juddspaintballs's Avatar
User is: juddspaintballs is offline
Send a message via AIM to juddspaintballs
change his fuses too, don't just visually inspect them. sounds weird but i had a main fuse problem once that it would allow 12v through but as soon as the amp starting drawing a little bit of power from it, it wouldn't allow enough current through and the amp went into protection very quickly. could be that with the amp wired that way it's just trying to draw too much power through a bad fuse that didn't blow.
Opinions are like assholes: everyone has one and they all stink.
My Audio Build Thread
Originally Posted by juddspaintballs
radio shack didn't have the pot i need and the guy there didn't know shit
Originally Posted by Sir Toad
i never bought pot at radio shack
post #9 of 13 Old 11-04-2007, 09:08 AM Thread Starter
strange, if he has any extras, i guess ill try it.
post #10 of 13 Old 11-04-2007, 10:57 AM
skinnyg's Avatar
User is: skinnyg is offline
Send a message via AIM to skinnyg Send a message via MSN to skinnyg Send a message via Yahoo to skinnyg
gain too high and bass boost maxed out
Originally Posted by platour22 View Post
How is 4 18s more cone area than 8 12s.
8X12=96
4X18=72
lol
skinnyg is offline
post #11 of 13 Old 11-04-2007, 11:09 AM
User is: gmcjimmy96 is offline
whats is the size of the box for the speaker the amp is pushing. My friend had a box that was to small, and it kept going into protection mode and burning up the fuse every time he turned it up to loud. We built a new box...and it all worked fine
post #12 of 13 Old 11-04-2007, 09:29 PM Thread Starter
well its the amp thats messed in case anyone was wondering, i can just hit it with my hand and throw it into protect, i opened it up, can't find anything, blew it out, still same shit, guess its just garbage
post #13 of 13 Old 11-05-2007, 07:14 AM
Speedy2222's Avatar
i'll take it off your hands.. let me know
-Speedy
