poping sounds from sub when brakes applied - S-10 Forum
post #1 of 24 Old 01-13-2005, 01:54 PM Thread Starter
User is: Timmyleve is offline
Hello,
I have a 2000 GMC Jimmy. I have had some popping crackling sounds from my subs when no music is played or at low volumes, I thought it was the ground wire and checked all my wiring. I also got a new battery but today after checking all my connections i backed the truck out of the garage and noticed that when I would tap the breaks i would hear the popping sound from the sub, also for the past month my gas gauge would go crazy like sometimes go from E to F. Has anyone heard of this problem, I don’t want to bring it to my local car audio dealer, they will charge my a arm and a leg. Could it be the alternator?
Amp: Rockford punch p5002
Subs: 2, 12" rockford stage 2's
Head deck: Pioneer 5600
post #2 of 24 Old 01-13-2005, 02:17 PM
User is: DevilDriver is offline
Re: poping sounds from sub when brakes applied
i was going to say your amps ground, but you said you already checked that. sounds like a much more serious problem than your stereo wiring, but i can't say for sure without looking at it first hand. check and make sure that there is nothing wrong with your battery/alternator wiring. that's probly not it, but at least it gives you a reason to eliminate
post #3 of 24 Old 01-13-2005, 03:20 PM
Tech Contributor
Zapnoma's Avatar
User is: Zapnoma is offline
I know you said you "checked" your ground, but try moving it to a different spot. It might not have the best connection where it is or whatnot.
Also, how is the ground for your cd player? stock ground?
Pimp
Zapnoma is offline
post #4 of 24 Old 01-13-2005, 03:22 PM Thread Starter
Yea, I am wondering if somehow it's the new battery. I am gonna check out the connections.
post #5 of 24 Old 01-13-2005, 03:26 PM Thread Starter
I never thaught about checking the ground for the CD player, The cd player was installed by a professional... but it may have become loose. I'll have to open it up..and check... The ground for my amp has been there for about 2 years and I haven't had a problem.. I'll try moving it also it wont hurt to try.
post #6 of 24 Old 01-13-2005, 03:38 PM
Tech Contributor
Zapnoma's Avatar
Did the pop just start out of the blue?
Pimp
Zapnoma is offline
post #7 of 24 Old 01-13-2005, 03:49 PM Thread Starter
I have had this setup since june and It seems like it started last month. I started my truck and I heard a sound from amp (it seems like this amp makes a clicking sound when it's cold) so I restriped the ground, power, rem and speaker cables and pluged them all into the amp...then after that it seems like I keep getting that poping sound. Do you think the cold can affect the subs and amp? I live in northern NH and it's have been quite cold. Also I opened up the box to make sure the speaker wieres were connected tightly.
post #8 of 24 Old 01-13-2005, 04:07 PM
Tech Contributor
Zapnoma's Avatar
It could be, due to the larger amount of static electricity in the colder air of winter.
Pimp
Zapnoma is offline
post #9 of 24 Old 01-14-2005, 12:50 AM Thread Starter
Intresting, I'll have to see if I notice it on warmer days...thanks a lot Zapnoma
post #10 of 24 Old 01-14-2005, 01:05 AM
Tech Contributor
Zapnoma's Avatar
No prob.
Since it has gotten colder, it has made my sub/amp tweak out. Now, when its really cold, the sub will just start playing on its own, low rumblings....
Pimp
Zapnoma is offline
post #11 of 24 Old 01-17-2005, 05:40 PM Thread Starter
Yesterday this is what I did.
1. Cleaned the ground wire mount, grounded it in another place under the seat
2. Pulled the subs from the box, re wired and soldered them.
3. Re-striped all the wires going into the amp.
I am still getting feed back when I put the directional, brake, rear window defroster. It's like a pop.. Then sometimes it does this noise just out of the blue....
This must be a ground problem right? My dad told me that he thinks there's filters you can put in the ground wire to take out some of the static or something.... is it possible that it could be my deck ground, I haven't touched it.. and if it was the deck ground I am sure I would hear this popping sound from the speakers.. I only hear it from the subs...any suggestions? Does anyone know of such filters? Does this definitely sound like a ground problem? I am going to probably replace the ground see how that works. It’s confusing me...because this just started...if the subs were in a car truck it would probably not be noticed but since it's in the back of my jimmy I hear it and it's annoying... Thanks for your help guys..
post #12 of 24 Old 01-17-2005, 06:03 PM
Supa Fly
BlazerPimp's Avatar
User is: BlazerPimp is offline
Your pops is talking abouta ground loop isolator...and those are usually used for alternator whining in the speakers.
My friend is having the same issue with his dodge intrepid. He wants me to come takea look at it...The first thing I was gonna check is grounds...so we will see...keep us posted if you fix it.
post #13 of 24 Old 01-17-2005, 06:12 PM
Audiomentry
JCamacho's Avatar
User is: JCamacho is offline
Have you had any work done to the motor or transmission? There is a grounding strap from the cab to the motor? maybe just maybe.
JCamacho is offline
post #14 of 24 Old 01-17-2005, 06:24 PM Thread Starter
BlazerPimp - Yea, your right... I dont think that isolator would help. I just looked at it on the radio shack website...It would filter sound from the deck, and there is no need for that because there is no poping sound from my speakers.. I would need to find a isolater for the amps ground wire that may help.
JCamocho - All I have done is replaced the battery, I'll have to check that ground strap.
post #15 of 24 Old 01-17-2005, 06:30 PM
Tech Contributor
Zapnoma's Avatar
i'll ask my friend what he did when his popped when he touched his brakes...
Pimp
Zapnoma is offline
post #16 of 24 Old 01-17-2005, 06:38 PM Thread Starter
Thanks a lot Zapnoma
post #17 of 24 Old 01-17-2005, 06:59 PM
Tech Contributor
Zapnoma's Avatar
:thumbup:
Pimp
Zapnoma is offline
post #18 of 24 Old 01-17-2005, 07:01 PM
Ex Bagged Minitrucker
choppingXtreme's Avatar
User is: choppingXtreme is offline
check your PM
Sold my 2000 S10. I'm not laying frame anymore, but I got plenty of pics
http://www.cardomain.com/ride/3032380
New Ride 2007 NBS Silverado CrewCab Victory Red
post #19 of 24 Old 01-19-2005, 02:09 AM
User is: sleepy10 is offline
sounds a power drain of sourts..... I would defently go ahead and upgrade the ground at the deck *friend of mine had the same prob and that ended up being the trick*...
sleepy10 is offline
post #20 of 24 Old 01-19-2005, 11:24 AM Thread Starter
Ok, sounds good.. I'll give that a try. Thanks a lot sleepy10..
post #21 of 24 Old 01-19-2005, 11:25 AM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
check and clean your connections at the battery itself. Also try moving your RCA's my old car made a poping and a whining noise when i would hit the brakes, the cable had gonen pinched behind the dash some how. i replaced my rca cables with better ones and moved them to the center of the car the entire way back... away from the factroy wires running to the back of the car, and the nose went away.
post #22 of 24 Old 01-19-2005, 12:34 PM
Mobile Audio Junkie...
Imperial Xtreme's Avatar
User is: Imperial Xtreme is offline
That's what I was just thinking... Check all of your wires, power, RCA's, remote, and see if one of them got pinched. I had a problem where my power wire melted and was touching some metal and kept shorting out my radio...
CHECK ME OUT: "Imperial Xtreme" @ cardomain.com
post #23 of 24 Old 01-19-2005, 06:10 PM
Tech Contributor
Zapnoma's Avatar
Here's what my buddy said.
>I replaced the RCA's. It helped for a couple of weeks and then it
>returned. I never did fix it the second time. It led me to believe
>the deck or amp was bad. Not entirely sure though.
Pimp
Zapnoma is offline
post #24 of 24 Old 01-19-2005, 09:36 PM Thread Starter
Yea, thats what I am going to have to do.. I haven't even opened my dash up.. I know down the other end everything looks good.. It sucks because I am back at school so I dont have anywhere to take a look at it.. (it's been like 10 degrees) I think I am gonna go home in 2 weeks so i can put the jimmy in the garage.. I am also going to replace both grounds...if it still does it with the gronds replaced I'm going to replace the rca's..then if it still does it.. I am going to break something, then bring it to the local car aduio dealer...I might just even do that it will prob end up only costing me 40 bucks.. I'll keep you guys posted on what happens, But i wont really be able to get to it till prob next weekend....
