pioneer avh-p5700dvd - S-10 Forum
post #1 of 19 Old 09-06-2005, 06:21 PM Thread Starter
User is: dragginmike95 is offline
just got my in dash and i was wondering how to bypass the parking brake switch on it? also if you know how it actually works could you explain it to me?
thanks
post #2 of 19 Old 09-06-2005, 08:26 PM
Insane Network Engineer
rlith's Avatar
User is: rlith is offline
Send a message via AIM to rlith
Re: pioneer avh-p5700dvd
thanks
Ground the light green wire...(this makes it think the parking brake is on) And how does what work, the head unit?
See my ride at
http://www.pghconsulting.net/teal
and www.s10planet.com
Support Sattelite Radio! Goto www.siriusbackstage.com
rlith is offline
post #3 of 19 Old 09-06-2005, 09:37 PM
forum idiot
orangesonoma's Avatar
well no the new pioneer units require the lt green wire to be grounded thru a switch...if it see ground when the unit is powered it need to have the ground removed then re applied for it to work...
did it the other day...
Brian
orangesonoma is offline
post #4 of 19 Old 09-06-2005, 09:38 PM
User is: DevilDriver is offline
i believe that is on the N2's, the 5700's are still the same
post #5 of 19 Old 09-06-2005, 09:40 PM
forum idiot
nope...did one yesterday in a nissan 240...i gounded it and it only worked that one time...then i turned off the ignition when i secured the unitin the dash...and turned the key and had no pic...
the n2 is somthing totally different to bypass it for the video...
Brian
post #6 of 19 Old 09-06-2005, 09:41 PM Thread Starter
no i was asking how the actual parking brake switch worked with the head unit....because in the manual it says to connect the light green to the positive side of the parking brake switch....?
post #7 of 19 Old 09-06-2005, 09:42 PM
forum idiot
no its says the negative side of the switch....there is no positive side
Brian
post #8 of 19 Old 09-06-2005, 09:42 PM Thread Starter
so how did you bypass the parking brake????
post #9 of 19 Old 09-06-2005, 09:42 PM
forum idiot
who you talking to?
Brian
post #10 of 19 Old 09-06-2005, 09:44 PM Thread Starter
the exact terminology in the manual is power supply side
post #11 of 19 Old 09-06-2005, 09:46 PM
forum idiot
that makes no sense...
the switch is bolted to ground and the wire comes off it is ground after the switch...on all cars...
Brian
post #12 of 19 Old 09-07-2005, 06:11 AM
rlith's Avatar
If the 5700 is like that, then all you really need to do is install a switch between the straight ground and the green wire... Simply toggle that after the car is turned on..
And for those saying the same thing on the N2, nope, not only does it require the brake ground to be activated, the internal gyro system detects motion and will kill the video. (One of the reasons I like my AVH-6500DVD w/ AVIC88 setup...
See my ride at
rlith is offline
post #13 of 19 Old 09-07-2005, 08:09 AM
forum idiot
i know a way around the avic-n2...
Brian
post #14 of 19 Old 09-07-2005, 09:31 AM
rlith's Avatar
Yes, you can reroute the output to the rear cam or the aux vid input... That doesn't solve the issue of not being able to input to the nav system without pulling over... For that you need to solder a relay into the system. This has been covered numours times at www.the12volt.com
See my ride at
rlith is offline
post #15 of 19 Old 09-07-2005, 10:09 AM
forum idiot
solder a relay??
there is a better way and it works great...i sent you a pm...
Brian
post #16 of 19 Old 09-07-2005, 11:09 AM
Broken Handed Superman
MeltingPlastic's Avatar
User is: MeltingPlastic is offline
Send a message via AIM to MeltingPlastic
idk in my n1 i just grounded teh green wire and it was fine.. havent heard of the switch thing like brian said but he does more isntalls than me seeing as i havent done installs in a while.. but the n2 bypass is a bitch.. and VOIDS ur warranty... and pioneer is wrong with their manual.. i know it says power side, but they really mean the side that switches.. cause almost every parking brake wire ive ever tested was a negative wire... so
Mike Grounded 4 Life
2002 X-Cab S10...
Project: The Cursed S10
post #17 of 19 Old 09-07-2005, 11:45 AM
forum idiot
i never said anything about the n1...the n1 you can just ground the lt green wire and it works fine...the n2 is easy you just need to know what you are doing...
Brian
post #18 of 19 Old 09-07-2005, 12:26 PM
i know u didnt.. im just stating how each pioneer is essentially the same yet the newer ones require diff bypasses....
2002 X-Cab S10...
post #19 of 19 Old 09-07-2005, 02:32 PM
Akatsuki Attack Squirrel
winkyhead's Avatar
User is: winkyhead is offline
Send a message via MSN to winkyhead Send a message via Yahoo to winkyhead
i had the same prob with getting my Pioneer to put video out on the front screen, but i fixed it a day or 2 later. All you have to do is ground the light green wire to a ground. Think of it like this, the positive side of the parking brake that it lists in the manual and the negative side are both just a ground, and when you put on your parking brake, it serves as a big switch to connect the wire letting the grounds connect.
DoNNiE
Originally Posted by Wrkn prgs View Post
Edit: Why the hell do you keep editing your posts?
00 X - K/N, Granatelli MAF, Dual Ex., Cleared lights with LEDs, Checkmate Cover, and SS signal mirrors. Envoy Bumper Cover (modding to look factory w/ X-kit)
Comin one day - Pass. suicide door, Cervini's SS ram air hood, shaved parts, car pc, Caddy 3rd brake light, and led tails
My Cardomain Gallery
