loud noise coming from sub after car turned off?? - S-10 Forum
post #1 of 21 Old 01-19-2006, 02:17 PM Thread Starter
User is: ryankk49 is offline
whenever my gf turns off her car, there is a loud noise that comes from the sub. it's a 12" JL sub and i did all the wiring but can't figure it out. it's hooked up to the stock deck with an rca adapter. the last time it happened i changed the ground for the amp and it went away for a little while but it came back now and it's wired exactly how my truck is but my truck doesn't do this. anyone had this problem before?
2003 dark blue extended cab
Strictly-S
ryankk49 is offline
post #2 of 21 Old 01-20-2006, 02:08 AM
MisteRSkeetZ's Avatar
User is: MisteRSkeetZ is offline
Send a message via AIM to MisteRSkeetZ Send a message via Skype™ to MisteRSkeetZ
Re: loud noise coming from sub after car turned off??
this happens with a lot of stereos. its just your sub popping from the power being turned off from your amp. i wouldnt worry too much.
post #3 of 21 Old 01-20-2006, 02:17 AM
I'm on a boat
andocommando's Avatar
User is: andocommando is offline
mine does it too whenever i change stations or something, its not real loud, but it does pop. i dont think it is too serious though
post #4 of 21 Old 01-20-2006, 02:28 AM
User is: toslow4u is offline
Send a message via AIM to toslow4u
its just feed back, get some better rca wires and or make sure the ground is grounded real well.
toslow4u is offline
post #5 of 21 Old 01-20-2006, 11:21 AM
01 CHEVY S-10
izusu472's Avatar
User is: izusu472 is offline
Send a message via AIM to izusu472
That is a type of ground noise. What kind of amp are you using and also on the high to low converter there is a brown ground wire comming out of it. If you havn't grounded that wire you might wan't to try that. I came across this noise alot in my 9 years of installing and found it most popular with either lower brand stereo's or amps.
izusu472 is offline
post #6 of 21 Old 01-20-2006, 03:25 PM Thread Starter
yesterday i turned on the car and the sub just started to blast and it wouldn't turn off...and the radio wasn't even on. so i had to disconnect it. it's connected to the stock deck with an rca adapter. do i have to ground that? i'm going to try and sand down the point where i grounded the amp better.
Strictly-S
ryankk49 is offline
post #7 of 21 Old 01-20-2006, 04:19 PM
355 member
scrubz's Avatar
User is: scrubz is offline
no, I'm not sure what it is but my buddy's car has the same problem. I rag on him all the time about it. You turn off the factory unit, and the subs just go apeshit. Like one long continous hum. It's funny
Zomg, joo are not teh hardcorz if joo don't destroi ur framz!!!!11!1!!111!!!!11ELEVEN!!111
Originally Posted by 01cherryreds10 View Post
It's probably the truck I like the most on this forum because it was the first I ever saw bagged and laying frame. Thank you
scrubz is offline
post #8 of 21 Old 01-20-2006, 04:19 PM
355 member
scrubz's Avatar
but it's on a Celica
scrubz is offline
post #9 of 21 Old 01-20-2006, 06:29 PM
99ExtremeSS's Avatar
User is: 99ExtremeSS is offline
http://www.stingerelectronics.com/we...lectronics.asp
The very bottom item is a pop stopper and should solve the problem. I'm sure other places sell them.
post #10 of 21 Old 01-20-2006, 06:32 PM Thread Starter
is that pop you're talking about really just a pop (like a short burst)? because the noise i'm hearing is kinda long. the last time it happend it went loud and didn't stop so i disconnected the subs.
Strictly-S
ryankk49 is offline
post #11 of 21 Old 01-20-2006, 06:35 PM
I have a buddy whose subs "hum" when he turns the car off. Is that what your talking about?
post #12 of 21 Old 01-20-2006, 06:39 PM
I'm on a boat
mine goes "pop" its about 1/4 second long, whenever i change stations or turn it off, but not when i go through CD numbers
post #13 of 21 Old 01-20-2006, 06:45 PM
Look at the link I posted above. The last item on the page is a "pop stopper" and it delays the amp turn on/off so you shouldn't hear it anymore.
post #14 of 21 Old 01-20-2006, 07:17 PM
Broken Handed Superman
MeltingPlastic's Avatar
User is: MeltingPlastic is offline
Send a message via AIM to MeltingPlastic
what it is is a feedback through the rca's when u turn off ur radio, ur amp didnt turn off.. its actually stil processing the signal. unfortunately i've yet to find a good way around this. we had a customer come back and complain about this but unfortunately there was nothing we could do to correct it.. we tried changing where we go the amp turn on to using a different LOC and it was even grounded.. so in short, just dont turn ur radio off
Mike Grounded 4 Life
2002 X-Cab S10...
Project: The Cursed S10
post #15 of 21 Old 01-27-2006, 10:33 AM
01 CHEVY S-10
izusu472's Avatar
The high to low converter needs to be grounded. Its the brown wire on the converter. That noise is feed back.
izusu472 is offline
post #16 of 21 Old 01-27-2006, 11:03 AM
355 member
scrubz's Avatar
Yeah, but the car don't have to be shut off. When the entire car is off it don't, but when it's on and he turns the HU off they go crazy, lol
scrubz is offline
post #17 of 21 Old 01-27-2006, 12:20 PM
91 S-10 Pickup 4x4
91S104x4's Avatar
User is: 91S104x4 is offline
Send a message via AIM to 91S104x4
I have same problem, and still cant figure it out. I may try a ground loop isolator and see if that works.
2002 S10 ZR2 extended cab 4x4
2007 Suzuki GSX-R600
91S104x4 is offline
post #18 of 21 Old 08-15-2011, 03:22 PM
User is: malik292 is offline
It won't harm your subs unless the noise is much louder than normal. Yeah its annoying, but if your amp has a 'gain' knob, you can turn that down everytime before you turn off your car, and it won't happen. I run 2 12' p2's and the noise is so loud sometime it vibrates the hair on my goatee, but its normally that loud anyway
malik292 is offline
post #19 of 21 Old 08-15-2011, 07:50 PM
always something new
S10dude's Avatar
User is: S10dude is online now
i would re-ground deck and also ground rca's , beandip had same popping proplem and it ruined the voice coil on his FI....he had to re-cone the sub
All truck pics
post #20 of 21 Old 08-15-2011, 10:49 PM
Its that dam ADD!
Forklift's Avatar
User is: Forklift is offline
Send a message via AIM to Forklift
wow, first post a an OLD DIG!
04 EC Silverado 4.8L,Pioneer, Rockford Fosgate, K&N, Viper, ACT, USSpeedo, Matrix, Whelen, Blackbear, 22" Eagles, Nittos,Russel,Magnaflow
85 S-15 2.5L/4spd, RF T4004, sub & highs, SD 4-link, AIM LCAs, 1/2 valves & compressor, Blazer interior, 17" Eagles w/BFGs, Tailgate skin, phantom grill, 140 amp alt
Project thread:
http://www.s10forum.com/forum/f30/pr...ymbagd-464481/
Forklift is offline
post #21 of 21 Old 08-15-2011, 11:20 PM
S10dude's Avatar
why not , everyone else is.............
All truck pics
