Keyless entry range fix
Old 08-12-2008, 01:01 AM   #1
NESS NOOB!!
raven2510's Avatar
raven2510 is on a distinguished road
thread on zr2usa.com
extend the range of your keyless entry
http://www.zr2usa.com/mboard/index.php?showtopic=29423
Ok, I was fed up with the range (or lack there of...) of the factory keyless entry.....
So after a little inspection.....& 20 minutes invested, my remote now works from around 300 ft.
Here we go:
You need the following:
->4ft. length of 28gauge wire.
->Drill with a bit that's the same size, or just larger than the wire.
->soldering gun & solder
->A little skill....and patience..
1st.....and foremost......DO NOT HAVE THE VEHICLE RUNNING......TAKE THE KEY OUT FROM THE IGNITION.
*Under the dash, drivers side, remove the black plastic panel (where the OBDII connector is), usually 5 screws.
*Lower the panel, behind the OBDII connector, you will find a square black box, this is the RKE module. There are 2 clips that hold the module in, release these clips, and lift the module out.
*Unplug the RKE module, and remove.
*Once removed, unscrew the cover, there are 2 clips on either side of the module, CAREFULLY unclip the cover.
*Remove the circuit board from the housing.
*Turn the board over, with the connector facing you.
*On the upper right hand corner, you'll see four (4) black surface mount transistors, Now, above the third one you will make a notch in the edge of the board, approx. 1/16 of an inch. (See third pic)
DO NOT GO NEAR THE CIRCUITS.......
*The notch is only the give the wire room to fit between the board and the housing.
*Turn the board over, one the outer perimeter of the board, you will find a circuit that ends about 1/4 from the edge of the board, with a small solder stop at the end......just short of where you made the notch. (See pic 4)
*Scrape about 1/4 inch of the protective GREEN layer away from the end of that circuit. (pic 4 aswell).
*Now "tin" the exposed copper trace. (pic 5)
*Tie a not in the wire about 1 1/2" from the end (So that the wire, if stressed, does not pull out of the board) (Pic 6)
*Solder the length of wire to this trace. Make sure that the knotted end of the wire is the end that is attached to the board. (Pic 7)
*Cover the exposed solder connection with melted candle wax to protect it. (Pic 8)
*Drill a small hole (Almost the same size as the wire, into the box. (Pic 9)
*Feed the wire through the hole, FROM THE INSIDE OUT. (Pic 10)
*Put the circuit board back in the box, re-install the cover, and the screw.
*Pull the new antenna (wire), till the knot seats against the inside of the box. (PLEASE...DON'T PULL TOO HARD......)
*Re-install the RKE module under the dash.
*Feed the new wire antenna out to the drivers side of the dash, should come out near the fuse panel.(Pic 11)
*Remove the "A" pillar trim, and tape the new antenna to the existing wire conduit on the piller. (Pic 12)
*Re-install the pillar trim.
*DONE.
Attached thumbnail(s)
Reduced 75%
770 x 358 (58.45K)
Reduced 72%
708 x 532 (72.31K)
Reduced 70%
659 x 495 (53.49K)
Reduced 72%
708 x 532 (102.88K)
Reduced 72%
708 x 532 (102.19K)
Reduced 72%
708 x 532 (29.14K)
Reduced 72%
708 x 532 (83.69K)
Reduced 72%
708 x 532 (82.71K)
Reduced 72%
708 x 532 (42.92K)
Reduced 72%
708 x 532 (86.73K)
Reduced 93%
2832 x 2128 (1012.63K)
Reduced 72%
708 x 532 (70.26K)
Credit goes to CanadianMoose on ZR2USA.COM
Page generated in 0.10136 seconds with 12 queries
