installing sound system to facotry HU
Old 10-27-2009, 04:10 PM   #1
02crewcab's Avatar
as the title says im looking into buy a sub, box, and amp. and with $$ being tight i was wondering if the factory HU has a preamp out to hook up the amp to?
thanks
Old 10-27-2009, 05:36 PM   #2
TheMcCumbers's Avatar
Re: installing sound system to facotry HU
They don't have facotory RCA outlets but you can get an adapter that you splice your speaker wires into and then then it outputs them to a set of RCAs. All you would need after that is a remote wire to power your amp on.
Old 10-27-2009, 05:57 PM   #3
firstgenon24s's Avatar
If you go that route I would almost use a relayed switch for the amp.
Old 10-27-2009, 11:13 PM   #4
forum idiot
orangesonoma's Avatar
a few companies make line output converters with turn on circuits built in..PAC makes one
http://www.ritzcamera.com/product/EP...ource =google
Old 10-28-2009, 04:30 AM   #5
you have to use whats called a high to low converter. basically, it converts speaker outputs(from the factory deck)and has rca's you can run to your amps. it's that simple. even walmart sells them under a brand called scosche. seriously, i can answer all of your questions but i cannot figure out how to attach pics to my reply's?? can anyone help, i can help out more if i can show you with images??
Old 10-28-2009, 06:15 PM   #6
02crewcab's Avatar
thanks for the quick replys guys, im new at the stereo stuff n it gets confusing.
can any1 recomend a 10" powered sub? i want it to thump but i dont need xcesivily loud bass so i thot maybe a powered sub would be fine. ps i listen to country n rock
Old 10-28-2009, 06:23 PM   #7
992drjimmy's Avatar
I have a 10" infinity powered sub i added to the infinity system in my caravan. It has the remote bass controll also. Plus it can be connected byRCAs or the hi- level speaker input. Its not a big thumper, but it sounds nice.
Old 10-29-2009, 12:03 AM   #8
02crewcab's Avatar
got a link? it sounds like something that would be perfect for my situation
Old 10-29-2009, 02:50 PM   #9
992drjimmy's Avatar
Sorry i dont have a link, I bought it a couple years ago at best buy. It was like 179. Ill see if i an find you a link or something.
Old 10-29-2009, 02:53 PM   #10
992drjimmy's Avatar
Ok, heres a link to the one i have. I paid 179 plus tax, but that was actually like 3 years ago.
http://cgi.ebay.com/INFINITY-BASSLIN...item2ea8324851
Old 10-31-2009, 12:12 PM   #11
http://www.bazooka.com/products/mobi...-Subwoofers-C6
Old 10-31-2009, 12:33 PM   #12
Its that dam ADD!
Forklift's Avatar
if your doing a powered sub, typically it will take a high level input, meaning from the speaker wires so no converter needed
Old 10-31-2009, 01:14 PM   #13
992drjimmy's Avatar
The infinity sub i linked to has both 4 channel high level and 4 channel rca inputs and also you can hook up remote wire to turn it on, or set it to detect the audio siganl to turn it on. Thats the way i have it. Plus has numerous setting on the sub as well as the remote volume control. Ive never personally heard a bazooka except in a store display. I really like the infinity. Very nice added sound and bass to stock infinity sytem.
Old 10-31-2009, 03:27 PM   #14
forum idiot
dont crew cabs have no space for subs? where you going to put it??
Old 10-31-2009, 03:28 PM   #15
forum idiot
how are you trying to post pics??? you have a photobucket account right??
just use the img links under the pic..copy and paste that here..
Old 10-31-2009, 04:08 PM   #16
02crewcab's Avatar
theres a little bit of space behind the rear bench seat and the back of the cab. i found some demensions on s-10crewcab, and as long as the bottom of the box/powered sub is less than 8" and the top of the box is less than 4" i can fit a sub box. im still messing around with the idea, but i found some subs & boxes that can fit behind the seat like...
http://www.sonicelectronix.com/item_...10TG-W1v2.html
and
http://www.sonicelectronix.com/item_...e+P3L-S12.html
Old 10-31-2009, 09:50 PM   #17
forum idiot
**** a back seat build a wall with 4 12's
Old 11-03-2009, 09:34 PM   #18
Blazin across Fort Worth!
93_Blaze's Avatar
Detailed description on how to wire? I am trying this right now but dont know how to wire. Please help.
Page generated in 0.58203 seconds with 31 queries
[Output: 100.12 Kb. compressed to 92.77 Kb. by saving 7.35 Kb. (7.34%)]
