#351 |
Zr2USA = B_Rich
Re: How To: High Output AD244 Alternator for ~$80
#352 |
4x4 v6 blazer
14 volts is just what the reg is set at and a alt should never read above that (unless it is indeed a racing 16volt model but thats another ballgame).
VVVAll numbers just pulled out of thin air and shouldn't be used for anything more than me trying to explain something.VVV If the alt is being taxed this voltage will drop as the alt heats up and the performance drops. This often happens with the smaller factory alts installed on vehicles with greater than factory loads. Take a s-series for example. The factory alt is rated at 105 amps, just say the stock electrical draw is 103 amps (number out of thin air as I don't remember the exact one). The factory load is less than the alts amp rating but real close to matching it. This means the factory alt is just barely capable of handling the factory load. This is also in ideal conditions and temps. The engine bay with the heat, oil, and water is about one of the worse places any electrical component can be placed. With that being said say the engine bay stays at 100 degrees (fictional figure) the alt de-rates from 105 to exactly 103. You add more electrical load (that nice fancy stereo you always wanted) you jump the load to 120amps. The alt will try to keep up but start over heating and its output gets even worse. As this happens the battery takes up the slack and this is why you see the volts drop. ^^^All numbers just pulled out of thin air and shouldn't be used for anything more than me trying to explain something.^^^ Voltage readings give you somewhat a clue the alt is not big enough but shouldn't be used solely as a testing measure. Truth be known damn near ever alternator out there in an ideal environment with ideal conditions should put out 14.4 volts at any RPM. Last edited by neo71665 : 09-04-2009 at 10:56 PM. |
#353 |
I'm sure glad I found this forum ,alot of great info from some smart ppl .I look forward to learning some new stuff and sharing some of my tricks.....Have a great day to all of you.........Jimmy
#354 |
i was wondering if u put a high output alternator and then you put the performance pulleys with a loud sound system will it make a difference or anything.
#355 |
Zr2USA = B_Rich
I've heard the performance pullies will potentially decrease your output at idle, but don't quote me on that as I've never done it.
#356 |
Laying hard on zq8s!
Well I don't know if any of the guys in this thread have ever put a ad244 alternator on a 2.2 s10 before, but I did this today.
I got the alternator for $10 at a local junkyard, my buddies dad knows them quite well as he is a mechanic, so they hooked me up. First off will say this is NOT a direct bolt on for the 2.2, there was some major cutting/grinding of the side of the alternator and had to drill the holes out a tad larger to make it fit. I bought a 1" longer belt thinking I would need it. Turns out i grinded it just right, the stock belt fits on great! went right on. Will get more pics of the alternator tomorrow when it is daylight, but i just got this finished,took me a while, cause i wanted it all to look nice and smooth. So far the alternator works GREAT, I am going to drive the truck more tomorrow and will post my results. here are some crappy night sell phone pics just for shits and giggles. It is getting painted tomorrow or the next day, i wire brushed it good tonight. enjoy. ![]() ![]() compared to the stocker you can see in this pic a little ![]() Last edited by colbye32 : 10-26-2009 at 10:57 PM. |
#357 |
Zr2USA = B_Rich
Very nice dude! Someone correct me if I'm wrong, but I believe you're the first to get an AD244 on a 2.2L?
Awesome job, well done. |
#358 |
i saw that one on the cavi, but i never saw on on a s10.. Will get more pics tomorrow after its all painted and cleaned up and daylight. thanks man, I will post pics of the grinding/cutting i had to do to make it fit, wasn't much to me, it was so well worth it, best 10 dollars i ever spent on my truck. |
#359 |
I pee standing
congrats. the other 2.2 guys will thank you
#360 |
im going to put a stock 105 amp in the stock ac location tomorrow or the next day= so that will be 250amps of power. that should be enough power to keep my 1200rms going and my massive dc7500 compressor, and my electric fan, and headlights going and then some will post more pics of the install tomorrow |
#361 |
Zr2USA = B_Rich
Good luck man, this is awesome lol. |
#362 |
Well guys, as promised,the dual alternator mod is complete. I am running 1 ad244 large case in the stock location, and 1 cs130d in the stock ac compressor location. Turns out one of the bolts was a direct line up, just needed a nut on the back, i did have to grind say 1/4" from the housing on the right side of the cs130d, that made that side of the alternator pulley line up with the rest of the accessories, made a small custom bracket out of some 1/4" stock, and drilled 2 holes in it, and mounted that up. Got a belt from part store for 14.99. Had a 4 pin connector already here at the house, along with the wiring for the alternator. For right now, i am running 8 guage wiring from the cs130d to my distribution block. the ad244 has 0 guage wiring from the back of the alternator to 1ft in front of it to the dist block.
Truck runs great, no lag or anything, I get 14.4-14.5 volts at idle cold or warm - and a constant 14.4v all the way through the rpm range. On the 4-5pin connector whatever it is, there is 1 red wire, i cut it and soldered another wire to that wire, and ran it over to the other alternator, and had a 4-5pin connector laying here, just a standard 1 wire one, soldered it on there, and heat shrinked it, easy as pie. enough the talk, onto the pics. ![]() ![]() ![]() ![]() ![]() ![]() |
#363 |
what?
WOOT WOOT, im glad someone actually tried this!!
I dont guess you took any pics of how you had to mod the AD244 to make it work did you? |
#364 |
4x4 v6 blazer
Its all cool but one thing I don't understand. If you were gonna add the factory one back to it why even move it? Why didn't you make one custom bracket and just add the AD244 to where the AC was?
I can understand if it was for height clearances or what not but it looks like you had the room and just done double the work. Very cool still, good to see more of us running 2 alts. I've got my 2nd one removed right now but I put it down where the AIR pump is on a 1st gen. Right under the factory one so unless you know what you are looking at my bay still looks somewhat stock, lmao |
#365 |
Just an FYI for everyone...There was a link to Nations Starter and Alts...DO NOT BUY FROM THEM...They are a local company and their workmanship is horrible. Many of our customers went to them for custom alts, and not a one lasted over a few months. Then they made up BS reasons not to warranty them.
#366 |
Like it or not, this is highly functional, the best $25 mod I've ever done to this truck right here. My trucks lights do not flicker one bit even with the heater on 4, electric fan on, system going full blast, or the massive air compressor going. |
#367 |
4x4 v6 blazer
Cool, makes sense now |
#368 |
From what I have been told and been able to research....
Regarding to the DR44 and DR44G alternators more commonly found on the newer GM trucks, besides having the two pin regulator connector.. another major difference with this unit compared the the AD244 alternators is that on the DR44 and DR44G the bridge rectifier is embedded and fused into the rear casing to form one single part where as on the AD244 the bridge rectifier is completely removable and upgradeable. Standard on the DR44 and DR44G are 50 amp diodes in the bridge rectifier and double wound stators which is the same as in the AD244, however the on the AD244, the bridge rectifier can be easily replaced with one that utilizes much larger rated diodes (up to 70 amps). This makes the AD244 much more versatile and durable from a rebuilding standpoint. With slight modifications, the 2 pin and 4 pin voltage regulators on these two units can be interchanged with one another. This is more so a mounting modification as there are some slight clearance issues. In my opinion, it would make more sense to just get the older AD244 units versus the newer DR44 and DR44G units. However, if you already have a DR44 or DR44G unit and want to be able to use it in your older vehicles that uses the 4 pin connector, it would be much easier to just replace the 4 pin male connector with a newer 2 pin male connecter and wire it appropriately (local scrap yard has plenty of connectors). Check with your local alternator guru for proper wiring. I believe there are some connector adapters/converters available that would be able to accomplish the same as well. This might be easier and cheaper than taking the alternator apart to replace the voltage regulator. I have no personal experience with this but this is the information that I have been able to find. |
#369 |
Zr2USA = B_Rich
That is awesome information. And one hell of a first post at that lol.
#370 |
Robert
just cause i am kinda slow this is what i need right?
#371 |
Zr2USA = B_Rich
Yeah it looks like that's the one. That's the 130A version, you could go with the 145A version if you wanted? It's up to you.
From my understanding, it takes some custom mounting work to get the AD244 to work on the 2.2L. I've never done it, that's just what colbye said a couple posts above this. |
#372 |
Location: Riverdale (fresno county) CA User is: OffLine |
#373 |
#374 |
Zr2USA = B_Rich
All of the readings that I'll be talking about, I'll be referring to output when warm unless stated otherwise. I realize that an AD244 will put out more AMPERAGE at idle than a CS130D. It's bigger, more powerful, etc. But if I have a stock CS130D, put a bigger stator in it (as in, 160A stator), why does my VOLTAGE drop at idle when it's warm? I realize that it isn't spinning as fast, thus it won't create as much output. But the stock CS130D put out 14.4v at idle (with only 40 or so amps). Why doesn't the "beefed up" CS130D do the same? (14.4v and 40A at idle). Instead, what I've read and expereienced myself, you'll get 12.8v and 40A at idle, thus causing the entire voltage of your vehicle to drop to 12.8 (obviously). Thus causing your lights to dim and your stereo to become weak. If you, or anyone, knows why this happens (bad voltage output at idle with the "beefed up" alternator) then I would LOVE to know why. I don't want a "that's just the way it works" answer. If some science and/or math can be put to it and explained why, then you have my respect and appreciation. I've laid low the past couple of months as to why this happens, since I've got an AD244 now, but I've always wanted to know, and everyone I've asked doesn't have an answer for me. That Mr. Alternator guy was the closest that I've came. Sorry to blow up here lol. I don't wanna sound like an asshole or anything, just want to clarify my situation and my questions. |
#375 |
I have a question..and I did read the whole thread...but I have a 91 4.3 Blazer and need the ad244 for my system. I saw the link to the 2 wire plug but was wondering if I could just make a plug (I have the resources)? I just need to know what each wire goes to. Thanks in advance.
Ben |
#376 |
guess i can't edit...but I just checked my stock alternator and it has a 4 position plug with just 2 wires...will this work on the ad244?
