#251 |
Zr2USA = B_Rich
Re: How To: High Output AD244 Alternator for ~$80
#252 |
well i was thinking after, maybe both trucks have the 105 amp? but, in the pics ive seen online, like yours, your old alt is rounded corners, mine doesnt look like your old one, but i might head over to the scrap yard and check their 145 amp out and see if its the same size as mine on my truck. ill try and get pics today.
#253 |
ok sorry i got the 145 amp alt, and put mine beside this and you can tell mine is the same as your old on, so i bolted this right up, put a 96" belt on it, works good, but i noticed my tensioner moves up and down constantly, is this normal? and i noticed the big "wheel" for the crank? is also moving back and forth.
#254 |
Zr2USA = B_Rich
#255 |
yea lol so is it normal for the tensioner to move up and down all the time? i took it for a good 2 hr drive test, and worked fine. didnt fix my problem totally though lol, so i need a battery asap also. but on my 145 amp alt i did have any numbers on it like yours does vortec. neither did my stocker.
#256 |
Zr2USA = B_Rich
Hm interesting.
The tensioner pulley will move some, but it shouldn't be all over the place. How long was your belt you said? And what year 4.3L is this going on. |
#257 |
its not going all over the place, just up and down all the time, the belt is 96" long, 1999 4.3L
#258 |
Zr2USA = B_Rich
That's the exact same length belt that I have on my '99 4.3L
I've noticed that mine does move a little bit.... but I've had the AD244 on there for about 8 months now with zero issues. |
#259 |
yea so far it works fine, so ill just leave it! but i def have to invest in a battery hopefully within 2 weeks as my voltage likes to dance still. but in a month or 2 i will be getting the ad244 "built" thanks for all the help and fast replys vortec!
#260 |
Zr2USA = B_Rich
Yeah dude no problem.
Do take this into consideration though when you get your AD244 "built". Your output at idle (voltage AND amperage) can, and probably will decrease. Of course, once the alternator comes to full tilt, then it will do what it says it will (depending on how hot the alternator and engine bay are). I've done some research on this and I've come to the conclusion (after talking to a couple shops and calling some shops that do this for a living) and they've told me that you will always loose output at idle (voltage and amperage) unless you get a double wound stator installed. Even then, the output at idle still won't be the same as stock. The "cheap" alternators out there only have a single wound stator, and output at idle will decrease tremendously. It's also key to have a good rectifier installed. The rectifier converts the AC current (which the alternator originally produces) and converts that to DC current, which is what the truck uses. The AD244 and CS130D both have ~210A rectifiers, so if you go above 210A on the stator without upgrading the rectifier, then the alternator won't last very long. If you don't wanna take my word for it, I totally understand. But talk to the guys who you're gonna have build your alternator (or unless you're gonna buy one) and ask 700 questions until you get the answers you want. I spend $200 on a 160A CS130D that had shitty output at idle, but did great at full tilt. The 12.8v and lights dimming at idle got old though. I would just hate for you to drop $200+ on an alternator that you aren't happy with. Good luck man. Oh and when you do get it built up, post up your results. I'm interested to see them. |
#261 |
i got a 290 amp alt on the sonoma now from DC power inc. it will benched to do 165a at idle and 308 at 1400rpm. ![]() ![]() best HO alt i ever used |
#262 |
Got Art?
#263 |
Zr2USA = B_Rich
Whats your voltage at idle? I'm assuming that's in an AD244 case, too? |
#264 |
![]() heres a couple pics of it ![]() ![]() ![]() |
#265 |
Zr2USA = B_Rich
Ah that's right, I remember you starting that thread.
You don't need an amp hooked up to check the voltage of the rest of the truck. Is the AD244 installed? |
#266 |
#267 |
Zr2USA = B_Rich
Dang, very nice
#268 |
whats the cost of a HO alt like yours stephen, rather then getting one built?
#269 |
Zr2USA = B_Rich
His is "built" you could say. I think you're referring to getting a used one and having bigger internals put in it, rather than buying a new one and getting internals put in it.
Can I take a guess at the price of it? Please don't be offended by it at all, It's just a guess. ~$300? |
#270 |
i think its a little over 500 but they are having a 20% off sale right now.
my buddy just bought a alt from the same guy that does 150 idle 220 1400rpm for $216 shipped. mines a 290sp |
#271 |
thats a lot of money, wonder if it would be cheaper to run dual stock 145amps
#272 |
Got Art?
#273 |
isnt there a premade one you can buy? maybe i was just reading things i was hoping to read lol. anyone know though? or have measurements to make one, my dad has cnc machines at work so he can make up anything.
#274 |
Zr2USA = B_Rich
I think they do make a kit, but don't quote me on that.
Personally, I'd just pay the $216 shipped for that 2nd alt that Stephen C mentioned. 220A and 150A at idle for only $220 is a great deal. |
#275 |
hmm yea, well when the time comes ill def look into how much to go each route and figure out something, would def be easier to run 1 alt. but im just heading out to get my big battery so ill see what my voltage does with this battery. but then again im doubling my watts real soon, so who knows lol
#276 |
ZzzzZZoooOOOmMmMMmm
so do we still not know if this fits on the 2.2, I just got a new Die Hard Platinum today, now it would be complete with a better alt.
#277 |
Zr2USA = B_Rich
^that just takes you to post #232 in this thread. He got it working on his 2.2 cavi motor. I'm not sure if the motors are the same though, considering the fact that I don't own a 2.2 ![]() I kind of doubt that the PCM's are the same from the cavi to the s10, so I guess you'll just have to try it out and see ![]() |
#278 |
ZzzzZZoooOOOmMmMMmm
Yeah, definitely different. On the s10 the alt is underneath a bunch of shit, that's why I don't want to tear into it if its won't work... oh well... maybe I'll try it sometime.
#279 |
Zr2USA = B_Rich
#280 |
are there any external markings on the alt itself that would tell if its 105 or 145
I got an alt with my 5.3 package, but idk what amperage it is |
#281 |
Got Art?
#282 |
not all the time, my stocker and and used ad244 both dont have any numbers on them i searched all over on them, cleaned and nothing. so i dont know why. |
#283 |
Zr2USA = B_Rich
#284 |
Tacklin Fuel
Just put in my AD244
my stocker was getting weak or at least I just noticed how weak it really is what with summer coming, the AC going, and acc. running. I ditched the CS. Bought it remanufacturered unit from a local wholesaler that I know. Paid 156 bucks plus 36 bucks for a Gates 96" belt. The belt number was already mentioned, #4060960 is the Goodyear Gatorback version. This belt is 1" longer than my stocker's 95" belt. I'm not sure if it was needed, but it works and the old one was exactly that.....old. I've noticed my amp gauge in my dash does not drop nearly as low when everything is on. I've also tested it with my multimeter while the truck is HOT and confirmed the guage. With system up, high beams, brake lights (brick assisted lol) AC Max high, etc I recorder a low of 13.90v to the battery. Straight off the alternators power and battery's ground- it's 14v. With everything off, it's an average 14.5. The stock CS was 12.5 and 14.4. Let me mention a couple things. The AD244 I have does not have any numbers on it. My stock CS also had no numbers on it. They both however do have the AC Delco remanufacturered stickers labeling them. My stock CS was not the original unit from factory, that died long ago. The AD244 fits perfect. My 2001 only had two bolts holding it, so it was a direct swap. It is tight though, the wires are moved some and my heater line is now touching the alt. Might wrap it to prevent chafing or heat distribution. Dunno, here are some pics. Next is the Big Three ![]() ![]() belt tension ![]() heater line ![]() wires ![]() two bolts, snug as a bug in a rug ![]() |
#285 |
Zr2USA = B_Rich
Alternator looks great on there man. Nice work.
I don't remember having any clearance issues with the heater hose like you did...... maybe I do have issues and just never noticed, I'm not entirely sure *goes out to truck and checks heater hose*I hope the reman AD244 treats you better than those that I've seen in the past. |
#286 |
Tacklin Fuel
^^^ can u elaborate(sp?)?? There something I need to look out for lol
#287 |
Zr2USA = B_Rich
See the "Remanufactured in China" sticker? From what I've read, they don't use the greatest quality parts to remanufacture them ("cheap" chinese parts"), so they don't last as long. I'm assuming you got a lifetime warranty with the alternator? I guess you can return a burnt alternator 4 or 5 times, and they've still made money off of them. But dude, don't loose any sleep over this.... run the alternator just as you would normally. Whenever people have probs with their AD244 I always ask if it's a reman or from a salvage yard. 95% of the time, the salvage yard will be a true AC DELCO alternator, because it came off of a full size truck. I don't wanna rain on your parade dude..... run the shit outta that alternator, and who knows, you might not have a problem at all. |
#288 |
Tacklin Fuel
damn, o well, I'll run the piss out of it, then get it either rebuilt, fixed with quality parts, or turn it into a mace.
#289 |
Zr2USA = B_Rich
#290 |
Need LSx swap.....
my heater hose is touching the alt in the same spot, no issues as of yet.
#291 |
#292 |
Zr2USA = B_Rich
Weird, it should say it on the top brim of the case. Oh well. |
#293 |
lol i know, i thought at least 1 of them would have a number. both have a white sticker with a number on it, but thats about it. but oh well, it works, and ill get it beefed up sometime this summer. my amp power is doubling faster then i can keep up so it will be sooner then later. and i also added my battery. and huge help from that. does about the same as yours. 14.5v warm. 14.8 14.9 cold. then after ive been bumping for a while it sits about 14.2 14.3 |
#294 |
Got Art?
#295 |
Slap my meat on your pita
I got my Alt in yesterday. Guy at NAPA told me stock alt length was 96 5/8. Closest size they had that was an inch longer was 97.5, I put that on and it was waay to big. I went back and got the next styep down he had in stock and that was 97. I put it and and while its tight, It does slip from time to time if I have a couple things running. I need to double check my tensioner, but Im half tempted to see if my stock belt fits.
Oh and my Alt came from a 2000 Burban and its on my 98 Blazer. |
#296 |
FYI Since the 97in belt was slipping and my tensioner is good I put the stock belt back on. No slip, no noise and its not super tight; works great.
#297 |
#298 |
Hope this isnt a dumb question but are all the 145amps on the listed trucks the ad244 model?I dont see why GM would put two different style alternators of same amperage but you never know. The reason I ask is because I've looked on ebay and a few junkyard sites and the only option might be 105/145 amp and it doesnt necessarily say ad244 . thanks
#299 |
Zr2USA = B_Rich
"145A" should be engraved right on the case. There are a couple pics of it in this thread (I don't feel like going to photobucket and looking for the pic, sorry). Hope that answers your question. Last edited by B_Rich : 06-30-2009 at 10:09 PM. |
#300 |
Alright thanks for the help man. Glad i found this thread before i dropped 2 to 3 hundred on a H/O alternator.
