#201 |
Re: How To: High Output AD244 Alternator for ~$80
#202 |
Zr2USA = B_Rich
Ohh!! I've seen that alt before!
*sigh* Ok..... here is my background with that alternator. airnathan over at Zr2USA bought one of these from cknaffle through a group purchase. He was told that the alternator had low mileage (which it did in fact have low mileage) but he couldn't get the thing to work how he wanted it to. I remember this because I was like "are you sure it's a genuine AC Delco AD244?" and he was like "well no, it has DR44 stamped right on the case" and I was baffled by this because it was a 145A alternator.... it just wasn't an AD244 (it very well could be an AD244, but it wasn't the same AD244 that I've known to love). Now..... that alternator may very well work for your application. But please do have caution that it MIGHT not work (meaning you won't get the output that you want out of it). The only reason I say this is because airnathan over on Zr2USA had this same problem and we couldn't figure out why it was acting up on him (bad output). So, take the install with a grain of salt knowing that you could potentially have problems. I'm not saying that it won't work, just saying that there is definitely a possibility that it isn't what you're looking for. Sorry man ![]() |
#203 |
"The two systems are not cross-compatible. Both systems receive a modulated signal back from the regulator, but that does not mean that the signal is the same. The PCM provides a PWM signal on the regulator input, and reads the field duty cycle as well as system voltage to adjust charging with the DR44G alternator. Your older AD244 is managed in a similar fashion, but the old regulator still has the capability to run without feedback - that is why you could make it start with a jumper to B+ ( I strongly recomend a current limiting resistor in that jumper circuit!)" I assume dr44g is the same is the dr44 that I got. I don't completely understand what this guy is saying, but the just of it seems to be that it wont work. lol. That sucks. Last edited by djj00000 : 03-27-2009 at 01:39 PM. |
#204 |
Zr2USA = B_Rich
Yeah that makes sense. I was guessing that for some reason the DD44 alternator wouldn't be compatable with our PCM's, while the AD244 would bolt right up.
Do you happen to know what vehicle the DD44 alternator that you bought came off of? I'll be on later this afternoon after class. |
#205 |
Zr2USA = B_Rich
Oh and if the alternator does in fact NOT work for you, I'll be sure to have it included in the OP to clarify that you shouldn't buy the DD44 alternator.
Sorry if that sounded harsh lol, but I only call it a mistake if you don't learn from it ![]() If you could give us some voltage readings, amperage readings would be great too, of the DD44 alternator installed on your truck, that would just be awesome. Use a DMM, not the volt meter on your gague. Thanks man |
#206 |
#207 |
Zr2USA = B_Rich
I see.... well I guess the only thing you can do is install it and try it out.
The alternator will naturally put out more when cold than when warm, so keep that in mind before you decide to keep the alternator or not. Good luck. |
#208 |
As far as seeing how it works goes I should basically just check the voltage once its installed and see how high it is at idle cold and once warmed up, right? If it is in similar ranges to what was shown earlier it should be good, right? Is there anything else I should be watching for? |
#209 |
Zr2USA = B_Rich
Just take a DMM to the battery and see what the voltage readout is. 14.4v is what you're looking for. You'll probably be at 14.7-14.9 when it's cold. |
#210 |
#211 |
Zr2USA = B_Rich
Sounds good man.
#212 |
What's the real difference between the older style 4-pin plug AD244, the new ('05-06 up) 2-pin plug, and the DR44G?
Shouldn't it all be in the voltage regulator? I scored an '07 DR44G alternator with the 2-pin plug for free today, I do work on the guy's computer network and built a few machines for him. We both think I should be able to take the alternator apart and swap out the voltage regulator (both units look the same, diff. plug, we looked online). The cover won't work correctly, so I can either trim it or try and find one... I think I'm going to try it. I found some regs for ~$50 shipped, which will be cheaper than any of the other yards around here (they all want $120+ for the 145A version). The my "good" yard doesn't have any older ones available... Last edited by Sherk : 03-28-2009 at 01:54 PM. |
#213 |
![]() ![]() 4.3 alt is very similar to the 2.2. you can see why you need a longer belt when you switch to a ad244 ![]() |
#214 |
Need LSx swap.....
just did this over the weekend in my 99 Blazer, along with the big three upgrade (only 4ga, thats all i had on hand). bought a "new" 145 amp alt off ebay (looks like a reman to me), and it appears to be a AD244. $95 shipped and includes a one year warranty. there are no markings on the case except for the "delphi automotive systems" or whatever printing on the front. i havent stuck the DMM on it yet but the gauge is above 14v at cold start and settles right at 14 after warm.
i did take the alt to autozone to have it tested before i installed it. the ebay auction listed it for an 04 H2, so thats what i told the guy at autozone. he didnt give me readings, but he said it passed all the tests...so i guess thats good. |
#215 |
Need LSx swap.....
forgot to add that i used a 96" belt also, fits perfect. Duralast part #960K6 at autozone.
#216 |
Zr2USA = B_Rich
#217 |
Need LSx swap.....
#218 |
But voltage isnt amperage, and thats not the only thing we are worried about here. Granted, a higher voltage IS better for an amp, but if the amperage isnt there... its a moot point. |
#219 |
Need LSx swap.....
i only mentioned that as a reference since I didnt compare voltages with a DMM between the stock alt and the new one. ill have a look at it with my DMM to see the exact numbers. i dont have my amp (alpine pdx-5) installed yet, but that would be the only amperage thristy (its got two 30 amp fuses) thing i will have added.
#220 |
So I got the DR44 alternator installed and so far so good.
![]() When it was cold it was putting out around 14.4-14.6v. I let it warm up a bit and the voltage dropped slightly but was still above 14v (14.2/14.3v). Then my e-fan (lt1/ls1 fans) kicked on and the voltage dropped to about 14v, still WAY better then its ever been. That was also with my stereo cranked up and the headlights on. So I think this alternator is going to be good, I let the truck run for about a half hour and everything seemed to be operating well. I'm gonna carry my old alternator, the old belt and the tools to change it in the truck for a couple days, just in case there are any problems. Thanks for the help getting all of this sorted. |
#221 |
Zr2USA = B_Rich
No problem man, that alternator looks great on there. I'm glad to hear that you got things working the way you wanted.
#222 |
does anyone know the size or part number of the belt that is needed for sure? or is it still a trail and error thing?
#223 |
Zr2USA = B_Rich
#224 |
rolling work in progress
will the AD244 fit a 2.2
#225 |
#226 |
Zr2USA = B_Rich
#227 |
lol thanks vortec my selective hearing is starting to turn into selective reading lol
#228 |
crippled bastard
#229 |
Zr2USA = B_Rich
96" belt seems to be the popular one. I would start there.
#230 |
does any one know what size belt would be needed for a truck that the ac comp is removed from.?
#231 |
Need LSx swap.....
gatorback #4060882 duralast #882K6 no idea if those will work, but they are a inch longer than the stock non-a/c belt... |
#232 |
bolted on just fine on my 2200 cavalier
large case looks huge in there ![]() stock alt ![]() ad244 on and charging ![]() size comparison ![]() |
#233 |
Zr2USA = B_Rich
That alternator sticks out like a sore thumb...... that's awesome lol
#234 |
2005 gmc and chev 145 amp alts def bolt up the same, just called a scrap yard and found 3, and he said they all bolt up different from 99-05, i told him i had a list of years they fit and he says he didnt care they all bolt up different. can some one confirm this, so i dont drive all the way and find out it wont fit. the guy was a real dick and it would be funny to prove him wrong.
#235 |
Zr2USA = B_Rich
It will work, I promise, just as long as it's an AD244. Print out a picture or two for comparison, then see if the real one matches the one in the picture. The guy at the junkyard is a ****ing douchebag and is just pissed cause he has no life to go home to at 6 o clock that night and feels the need to TRY and prove other people wrong just for the hell of it so he can feel better about himself. Sorry for that rant, but I know exactly the kind of people who you are talking about, and they're a waste of space IMO. Good luck getting the alternator, I'm sure you'll do just fine in finding it ![]() Last edited by B_Rich : 04-24-2009 at 08:47 PM. |
#236 |
haha thanks man, after i hung up the phone i was pissed, lol, i cant stand people like that, but yea i know about the number i asked a few scrap yards about that number and they had no clue what i was talking about, if it doesnt have that number on it, i wont take it.
#237 |
Zr2USA = B_Rich
#238 |
oh ok, so is there any number on it to look for? or just hold it up to mine and check to see if it bolts the same?
#239 |
Zr2USA = B_Rich
Yeah you pretty much just need to recognize the alternator. I mean, it's pretty easy to see the difference between the two. Just make sure you know what it came off of (link in the original post) and print out a picture or two so you know what it looks like. Here is the picture of the "145A" ![]() ![]() ![]() ![]() ^see how you can see the "DELPHI" that is just to the right of the pulley? If it doesn't have that engraved right on the case, then I would keep looking. Good luck. |
#240 |
awsome, thanks so much for the pics!!, ill for sure check for the 145a on it, and im hoping they will let me take it to my truck in the parking lot and compare them. as i dont have a printer lol but ill try and get one printed off. thanks!!
#241 |
Say lowered d
The one I got from the same Ebay seller as listed above is a reman I'm afraid. It doesn't have the etched numbers in the case. When I get back home, I will put it on the Blazer and see what happens.
#242 |
Zr2USA = B_Rich
Btw, what part of Iowa are you from? Last edited by B_Rich : 04-25-2009 at 11:52 PM. |
#243 |
Say lowered d
Ah, OK. I sent them a question if I could exchange, I'll see what they say. The Blazer doesn't NEED one, just replacing the stocker with dry bearings. This is cheaper than buying a new reman.
I live in Struble. |
#244 |
... i dont know?
#245 |
Zr2USA = B_Rich
![]() Do you have a pick of yours old skool? |
#246 |
... i dont know?
#247 |
Zr2USA = B_Rich
Ah I see
#248 |
i just went to pick one up and they sold all 3 they had, now they said a local guy sells the 145amps alt brand new, but its some aftermarket company, and the guy said he doesnt know what company makes them for $150, or a local scrap yard has one off a 2004 yukon 145 amp for $100 plus tax!! what should i do, wait till i find a different one, because the place that had 3 sold them for $50!! should i buy my battery first then the alt, or def get an alt first?
#249 |
... i dont know?
just get the battery and then shop around for the alt, i got mine for 35ish
#250 |
i just checked the yukon with a 5.3l out in the driveway, and my alt and the one on the yukon look the same size. and i cant find numbers on both of them. so i dont know if the yukon has a small alt or my truck already has the bigger alt??
