How do I hook up 3 Subs with one amp? - S-10 Forum
post #1 of 12 Old 01-05-2006, 03:00 PM Thread Starter
Salvage Title
ajsproaudio's Avatar
User is: ajsproaudio is offline
Send a message via MSN to ajsproaudio Send a message via Yahoo to ajsproaudio
I recently purchased 3 1200Q Audiobahn subs and a Tri-Box. I have everything to hook up these subs just no amp. I am curoius on what type of amp I need and can run. I don't watn to spend to much money but don't want no RADIO SHACK AMP. Any Suggestions. I also need to knwo on how to wire them for that amp rather it be a 1 channel or 3 channel or whatever. PLEASE COMMENT
I really want to finish my system.
95 S-10 Blazer W/Front Conversion 4.3 Mulitport Vortec, Gibson Exhaust, Pro Mod Chip, Air Mod Filter, along with many other mods...
Salvage Title-Former Rollover
Car Domain- www.cardomain/ride/816022
post #2 of 12 Old 01-05-2006, 03:02 PM
Daily Draggers 4-LyF!
XtReMe FrOm HeLL's Avatar
User is: XtReMe FrOm HeLL is offline
Send a message via AIM to XtReMe FrOm HeLL
Re: How do I hook up 3 Subs with one amp?
u can get a mono amp meaning it only has one channel but get a powerfull one and just hook it up to that one channel (like bridging) or just get an amp with 3 channels or you can get a regular 2 channel amp and bridge it
post #3 of 12 Old 01-05-2006, 04:00 PM Thread Starter
Salvage Title
Well that doesn't answer my question
post #4 of 12 Old 01-05-2006, 04:02 PM
C's_S10's Avatar
User is: C's_S10 is offline
i suggest the 2 channel amp and bridge it.
C's_S10 is offline
post #5 of 12 Old 01-05-2006, 04:04 PM
Resident Wetback
suicidal's Avatar
User is: suicidal is offline
Send a message via AIM to suicidal
more info would be helpful. What are the subs impedence? are they DVC? what are they rated RMS? this info would be helpful, if you want to get your question answered.
LUIS
2014 Nissan Altima - just because
2002 Sonoma Crew Cab - Daily *FOR SALE*
1995 S-10 - BD project
1991 Cadillac Fleetwood
1991 Honda Prelude
1980 Cadillac Coupe DeVille - bag project
Originally Posted by TobyTheSandwich View Post
...the biggest pain of it all was getting my hands up in there. It's tight. And alot of moisture can build up in there. I had alot of trouble fitting my whole hand up in there honestly. But it took some time to work it in.
suicidal is offline
post #6 of 12 Old 01-05-2006, 04:16 PM
un banned
Baggd's Avatar
User is: Baggd is offline
Send a message via AIM to Baggd
first off, bridge the amp (if it allows you to) if its a 2 or 4 channel (4 channel not reccomended) if its a mono amp, you dont have to worry about it cause its only one channel. also, a 3 channel amp doesnt neccessaraly mean one channel for each sub. a 3 channel amp usualy has 2 stereo channels for speakers, and one mono for a sub, and theyre usualy hybrid class ab/d. more made for powering an entire system.
second, im assuming theyre dual voice coil.. if so,
or
if so, the first configuration will give you a final impedence of:
Dual-6 Ohm Subwoofers: 4 Ohms
Dual-4 Ohm Subwoofers: 2.67 Ohms
Dual-2 Ohm Subwoofers: 1.33 Ohms
Dual-1.5 Ohm Subwoofer: 1 Ohm
and the second one will give you:
Dual-6 Ohm Subwoofers: 1 Ohm
Dual-4 Ohm Subwoofers: 0.67 Ohm
Dual-2 Ohm Subwoofers: 0.33 Ohm
Dual-1.5 Ohm Subwoofer: 0.25 Ohm
and if you have single voice coil subs, you get this:
2 Ohm Subwoofers: 0.67 Ohm
3 Ohm Subwoofers: 1 Ohm
4 Ohm Subwoofers: 1.33 Ohms
8 Ohm Subwoofers: 2.66 Ohms
12 Ohm Subwoofers: 4 Ohms
Baggd is offline
post #7 of 12 Old 01-05-2006, 04:59 PM
skinnyg's Avatar
User is: skinnyg is offline
Send a message via AIM to skinnyg Send a message via MSN to skinnyg Send a message via Yahoo to skinnyg
how are the subs wired in the box? Is there one output for the subs or 2? And what impedance is that at? That would determine what amp tp buy, not how many speaker you have.
skinnyg is offline
post #8 of 12 Old 01-05-2006, 05:47 PM
un banned
Baggd's Avatar
what are you talking about? those diagrams explain everything. nevermind what name is on the amp in the picture.. that doesnt matter. i got it off their website.
Baggd is offline
post #9 of 12 Old 01-05-2006, 05:56 PM Thread Starter
Salvage Title
Ya but Those diagrams say i need either a 1/4 ohm amp or my subs need to run off from 6 ohms. The subs are dual voice coil they are 700watt RMS and I would liek to run about 1000 watts each. I am not sure if they are 6ohm capable that is why i would liek some info on what amp to buy. I would liek to give them 2ohms to 4ohms If I can
post #10 of 12 Old 01-05-2006, 06:20 PM
black culture thief?!
truckramrod's Avatar
User is: truckramrod is offline
Send a message via AIM to truckramrod
are these the ones you have?http://www.sonicelectronix.com/item_131.html
if so they are 4 ohm DVC woofers therefore you can only wire them up to loads of 2.67 with the woofers wired in series parallel (picture 1) or 0.67 ohms with the woofers wired in parallel parallel (picture 2).
That means you need an amp that is stable at one or the other load, whether it is a 2channel amp that is 2 ohm bridged mono stable (2.67 ohms is higher than 2 ohms so it will be stable) OR a monoblock Class D amp that is .5 ohm stable.
As far as powering those woofers, they are rated at 700 watts rms each and if you pat anymore than that to them, you'll probably be replacing them shortly (700 watts doesn't play well with 2 inch voice coils) and I've had problems with Audiobahn overrating the powerhandling on there subs.
R is for RACE right???
95 Ext cab red 4.3TBI 5spd ZQ8+2/3 drop Caddy/K&N CAI,Taurus Efan, Flowtech Afterburner/ gutted cat...
Kappa60.5cs comps (everything else was stolen)
Coming : repairs and zq8 wheels
post #11 of 12 Old 01-05-2006, 06:33 PM
User is: tprj82 is offline
i think a mtx 1501d, or maybe even a oion/viper 2500d would be a nice amp for that setup, just be responsible when setting the controls
tprj82 is offline
post #12 of 12 Old 01-06-2006, 07:48 AM
un banned
Baggd's Avatar
the impedednce doesnt come from the amp. it depends on how you wire your subs. your subs will be either dual 2 ohm, dual 4 ohm or dual 6 ohm most likely. those diagrams show 2 different ways to wire them up and what your final impedence will be when wired that way, depending on what ohm load your subs carry. if you want your subs to see 2 ohms, it wont happen with 3 subs, no matter how you wire them. if you want 4 ohms, youre gonna have to get 6 ohm subs.. which alot of companies dont make anymore.
however in my blazer i had 3 dual 4 ohm subs, wired to 2.67 ohms, running of a kicker kx/1200.1 and it rocked em pretty good. didnt have any problems with it. theres no law saying your impedence needs to be an even number. just as long as your amp doesnt have a problem with it.
if that didnt make any sence, get ahold of me on aim. my sn is ronjeremy62081. ill walk ya through it. once you see whats going on, its not really complicated at all.
Baggd is offline
