#51 |
former title junky mod
Re: Grounds
#52 |
drunk and bored
Re: Grounds
![]() you gotta try harder to get me on a technicality (and just FYI...my clip tool was at home so i used a hook tool to release the clip and it went for a ride......it sprung out the backside.....hit the backside of the door jamb and bounced back in my lap!) |
#53 |
ASASN8
Re: Grounds
i have a pencil solderer, but everytime i use it i burn the hell out of something. my leg, hand, where ever the solder drips.... etc.... lol
so that is why i want a cold soldering iron, a cold soldering iron heats up super quick when you want it too, and cools off even quicker so you can't burn your self on the tip when you are not soldering http://www.epemag.wimborne.co.uk/cold-soldering.htm |
#54 |
drunk and bored
Re: Grounds
#55 |
bellcranks no more
Re: Grounds
since the cold soldering is brought up. does that work better than the usual soldering i do with my iron?
ive heard the radioshack's cold soldering thingy sucks ass |
#56 |
I pee standing
Re: Grounds
i have that coldheat soldering iron. SUCKS ASS! wouldn't melt the smallest solder radio shack sells on a 18awg wire. i don't even know where that piece of shit is. its no where around my soldering gear though.
#57 |
R/C Guru
Re: Grounds
Tried to use one of those cold heat soldering things myself. Boss bought one at work to have me use instead of a reg iron, and I couldnt get the solder to melt, let alone get the wire to the inner part of the tip where its actually hot all the time either. Those things suck ass unless youre working with 30 ga wire and solder just as small and shitty.
#58 |
Re: Grounds
to get a good ground u should go to ur frame right? could u ground to ur cab(inside) and then on the bottom side of the cab(outside) ground to ur frame/chassis? or would it not be worth the effort to ground the cab to the frame/chassis?
#59 |
I pee standing
Re: Grounds
you could do that and it would work. but its still better to go straight to the frame. why interrupt high conductive copper wire with a 1/16" steel plate and a crappy bolt. it just makes a choke point is all i'm saying.
#60 |
Diztorted Dreamz
Re: Grounds
Just one of them random things i've heard and i'm not wanting to start anything but the only semi-valid point I have ever seen to not relying on solder only is that some solders the electrical conduction properties are not as good as the copper wire and copper terminals. Now there are some solders out there that are great but other cheaper solders well we know they suck. I mean the difference is minuscule but the point is valid none the less.
Oh yeah i know i brought up and old thread but ahh poop happens. |
#61 |
4x4 v6 blazer
Re: Grounds
Yawn, yes its true lead doesn't allow the exchange of electrons as easy as copper but the difference is so small you'll never notice it. I can see if I can find some numbers for you if you want to split hairs but I'd rather not have to look through my electrical books for it. |
#62 |
drunk and bored
Re: Grounds
#63 |
Re: Grounds
Damn, so what kind of equipment do you guys use? I do a lot of soldering over here but it's always what's on hand...I'd like to get myself some good quality stuff,
What do ya'll use for Solder: Flux: Rosin: Gun/pencil/iron, etc Anything else: |
#64 |
drunk and bored
Re: Grounds
i use rosin core solder and either a pencil iron or a propane torch depending on what i am soldering
#65 |
Re: Grounds
A good cleaning makes a difference, even with rosin. Crimp first is a crutch for poor job. Pencil tip torch is nice for the big stuff that you can pull out. Quicker heating means less time for it to soak back and melt insulation, if any. Common electronics solder is tin/lead mix but you can get lead free (mostly tin) like plumbing solder.
#66 |
Boobies
Re: Grounds
holy thread digging batman!
#67 |
Re: Grounds
Oh, didn't notice. "And you may ask yourself-well...how did I get here?" I just did. "My god!...what have I done?"
#68 |
not low enough
Re: Grounds
is there any easy way (with no special tools) to crimp a 1/0 wire? or should i just find someone to solder them? gonna do the big 3 soon and dont want any problems with it.
#69 |
Re: Grounds
Visegrip, or hammer & cold chisel or flat blade screw driver could be used to dent in length wise, so that you can fold the sides tighter. Or center punch or phillips head to dimple it in, in the middle. Doing it in an angle (L) or grove (cut in wood block or such) will help to keep it from just flattening. Sealing it (silicone or grease) will help it last in the weather. A good soldering job makes solid connection that strong, & resists weather/movement.
#70 |
rolling work in progress
Re: Grounds
i ran a 4ga from my starting batt to the alt bracket then to the firewall then to the left side of the frame. in the back a 4ga goes from the left side of the frame to the system batt then to a split bolt junction from the junction to the right side of frame, the amp grounds go to the junction also
#71 |
Re: Grounds
I use a propane torch for large wires and a weller gun for smaller. Couldnt be happier. I had a iron at some point, but I ALWAYS burned myself, then Id get pissed. Not to mention my gun heats up in 10 seconds, and the iron takes 15 minutes to get to temp.
I saw someone tow a car with a soldered 1/0 one time, was neat. |
