Grounds
Old 09-27-2007, 04:41 PM   #1
Sold da SS and gota Jimmy
97SSindiana's Avatar
97SSindiana is on a distinguished road
Grounds
Is it a good idea to use a distribution block for grounds so they can all be grounded at the same place?
Thanks
Old 09-27-2007, 04:45 PM   #2
ASASN8
bladehines's Avatar
bladehines is on a distinguished road
Re: Grounds
i don't think it matters just as long as you get them all to a good ground. i will be running mine to pretty much the same spot on the frame with my batteries in the bed.
Old 09-27-2007, 06:33 PM   #3
JED
juddspaintballs's Avatar
juddspaintballs is on a distinguished road
Re: Grounds
a distribution ground block is perfectly fine
Old 09-27-2007, 10:37 PM   #4
beaniebmx's Avatar
beaniebmx is an unknown quantity at this point
Re: Grounds
a ground is a ground, it doesnt have to all be grounding in the same spot, its best but its no big deal.
i personally like to ground my stuff all in one spot if possible
Old 09-27-2007, 10:48 PM   #5
I lead the blind
Speedy2222's Avatar
Speedy2222 is infamous around these parts
Re: Grounds
WRONG if you don't ground them in the same spot you will create a ground loop
Old 09-27-2007, 10:48 PM   #6
99S10LS's Avatar
99S10LS is on a distinguished road
Re: Grounds
As long as its grounded to a good spot(chassis) a dist. block is fine.
Old 09-27-2007, 11:12 PM   #7
Breakin shit
brokeitagain's Avatar
brokeitagain is on a distinguished road
Re: Grounds
what exactly is a ground loop?
PIC FROM INSTALLER.COM
Old 09-27-2007, 11:26 PM   #8
addicted... to RC !
xdude2001's Avatar
xdude2001 will become famous soon enough
Re: Grounds
ha ha ha ha ...........................
Old 09-27-2007, 11:30 PM   #9
i can read
paint toad's Avatar
paint toad is a jewel in the roughpaint toad is a jewel in the roughpaint toad is a jewel in the rough
Re: Grounds
x2
that is my plan
Old 09-27-2007, 11:31 PM   #10
Breakin shit
Re: Grounds
I used a dist. block with mine and have no ill effects. I drilled a hole in the floor of my blazer and attached the main ground wire to the frame. FYI
Old 09-28-2007, 12:31 AM   #11
JED
Re: Grounds
i'm using a fused power distribution and ground distribution combo block. 1/0 in one side with 4 4awg out (for power) and then 4 4awg in and 1/0 out (for ground). i'm grounded to the frame too
Old 09-28-2007, 10:16 AM   #12
Re: Grounds
I only have one amp but plan on having one more soon, so I could run 1/0 to the frame and 2 4's out?
Old 09-28-2007, 10:24 AM   #13
skinnyg's Avatar
skinnyg is on a distinguished road
Re: Grounds
sure
Old 09-28-2007, 10:53 AM   #14
ASASN8
bladehines's Avatar
Re: Grounds
i will be running around eight 0 gauge grounds to the frame in 1 spot. the more the better on comp systems!
Old 09-28-2007, 02:44 PM   #15
JED
Re: Grounds
you might as well just solder those grounds to the frame. i can imagine your frame is going to have more resistance than 8 runs of 1/0 to the same spot.
Old 09-28-2007, 02:46 PM   #16
ASASN8
bladehines's Avatar
Re: Grounds
true.....
Old 09-28-2007, 02:49 PM   #17
JED
Re: Grounds
or have your frame copper plated, lol
Old 09-28-2007, 02:53 PM   #18
ASASN8
bladehines's Avatar
Re: Grounds
heyyyyyyyy now there is a thought!!!!!!!!!
Old 09-28-2007, 03:22 PM   #19
skinnyg's Avatar
Re: Grounds
I have seen alot of guys weld grounds to the frame
Old 09-28-2007, 03:53 PM   #20
Re: Grounds
Wouldnt the heat of the weld damage the wire?
Old 09-28-2007, 05:02 PM   #21
bellcranks no more
greencactus3's Avatar
greencactus3 will become famous soon enoughgreencactus3 will become famous soon enough
Re: Grounds
i would solder. not weld...
the frame is thinner than the wire. so it wont be TOO hard with a torch
Old 09-28-2007, 07:24 PM   #22
Breakin shit
Re: Grounds
weld a 3/8'' bolt to the frame then attach the ground to that. CRIMP and solder a copper lug to the end of the cable attach it to the bolt and then seal it with paint. Soldering lugs on without first crimping them can create a resistance, but if u crimp one on them solder u have an excellent electrical and mechanical connection to the wire
Old 09-28-2007, 07:34 PM   #23
Sasquatch's Avatar
Sasquatch is on a distinguished road
Re: Grounds
I never heat my wires, it changes the characteristics of the wire. I use only compression style connections, I never crimp. Use a common ground location, clean all paint and crap off of the metal. And then grease the spot so no rust appears.
Old 09-28-2007, 07:55 PM   #24
Breakin shit
Re: Grounds
if u heat copper hot enough to change its characteristics when soldering u dont know how to solder, it takes much more heat to change it that it takes for most standard electrical solders to melt.
Old 09-28-2007, 09:27 PM   #25
i can read
paint toad's Avatar
Re: Grounds
crimping before soldering???
use compression fittings instead of solder???
changing the characteristics of wire by soldering???(paraphrasing)
wow.....3 years of electronics in high school and having a father that was an electrician and 20 + years of installing stereos don't quite have me prepared for these statements!
i guess solder or printed circuit boards should never have been invented,huh?
wow....i'm just shaking my head in disbelief
Old 09-28-2007, 10:39 PM   #26
Breakin shit
Re: Grounds
fien ok im fuking wrong whatever
Old 09-28-2007, 10:45 PM   #27
i can read
paint toad's Avatar
Re: Grounds
had a car that was wrecked......it would not run.....there was a broke wire that was repaired with a butt connector.....it was some sensor wire.....
cut off the connectors solder the wires...heatshrink...wrapped with electrical tape....the car ran!
so if there was an arguement that says butt connectors create resitance....solder does not....then i'd be agreeing right now!
Old 09-28-2007, 10:48 PM   #28
Breakin shit
Re: Grounds
what i should have said:
Improperly Soldering lugs on without first crimping them can create a resistance, but if u crimp one on them solder u have an excellent electrical and mechanical connection to the wire
i guess i could have been a little more clear. I have seen many "cold soldered" joints that failed because of solder being flowed on to instead of "in to" a solder joint
Old 09-28-2007, 10:59 PM   #29
i can read
paint toad's Avatar
Re: Grounds
i solder.....no crimp.....i used to crimp then solder but thought it was a waste of time.....
that's 4 ga. soldered to a 4 lug with no crimp......lifting my vice off the bench....mechanically strong enough for me bro...but i have a tough time seeing greater resistance
Old 09-29-2007, 02:03 AM   #30
JED
Re: Grounds
i've soldered 4awg with no crimp plenty of times and i'll be damned. the only way to get that lug back off is to melt the solder again.
i still don't understand the statement about changing the characteristics of copper w/heat. copper is copper is copper. when copper is molten it's still copper and when it cools it's still copper. still conducts electricity the same once it's cool
Old 09-29-2007, 02:58 AM   #31
Sasquatch's Avatar
Re: Grounds
I am not saying that soldering does not work well, it is the strongest connection, I am talking about the audible properties. I had extremely highend audio when I was first married, the kids changed all that, but I tried listening to soldered connections vs the compression style, and man, what a difference. Crimped is garbage, compression is awesome.
Old 09-29-2007, 03:18 AM   #32
JED
Re: Grounds
i see your point i guess. compression is pretty nice and always looks good to boot
Old 09-29-2007, 08:38 AM   #33
i can read
paint toad's Avatar
Re: Grounds
on that note......i've got high end audio at home.....i've got straightwire level 3 interconnects(4 pairs) and a pair of level 3 speaker cables....all terminations are soldered and i just double checked...they are not crimped!
Old 09-29-2007, 09:11 AM   #3
