Got some new subs need help with an amp
Old 10-17-2009, 07:51 AM   #1
TheMcCumbers's Avatar
Hey guys just picked up 2 JL 12W3V2-D4 for $50 WOOT! Seemed like a damn good deal to me. Now I was wondering if anyone had any suggestions as to a good amp to power these. I'm more than likely gonna stick em in a ported box and as far as wiring and what not goes I am open to suggestions.
Old 10-17-2009, 08:27 AM   #2
Knowledge is power.
s10pimpin209's Avatar
Re: Got some new subs need help with an amp
least 4 gauge wire. a 1200 watt amp and definitely a nice capacitor.
Old 10-17-2009, 10:11 AM   #3
Oh sorry I guess I kinda worded that wrong, I meant wiring for the subs. Paralell, series, Mono off the amp etc. And why in the world would I need a 1200 watt amp, the RMS for these subs is only 300 watts.
Old 10-19-2009, 11:25 AM   #4
iroc2nv's Avatar
Use a JL amp
Old 10-19-2009, 02:31 PM   #5
Knowledge is power.
depends on the amp you get, but usually bridged is the best. 300 is the rms not he peak for the driver. 1200watts divided by 2= 600 peak for the amp and divided by 2 drivers = 300 watts for each.
Old 10-20-2009, 02:28 PM   #6
BelowBassAudio.com
94projectcustom's Avatar
800a2 800a2 800a2 i can say it all day a rockford phosgate 800a2 perferably punch series but both good...best amp probably ever made!!! then just wire them + to + - to - each channel to each sub.no need to bridge
Old 10-20-2009, 02:59 PM   #7
bman194's Avatar
alpine makes a nice 600 watt amp, mrp-650 i believe, i used to have it with a couple type s's, worked great, and you measure subs based on rms not peak btw
Old 10-20-2009, 03:10 PM   #8
BelowBassAudio.com
it only takes 100watts to move a sub. most subs are underrated
Old 10-20-2009, 10:39 PM   #9
Team Lethal Beatz
Id say if you have the cash go with the 500/1 slash series amp from JL my buddy had his 500/1 on his 2 w3 12s and it was the cleanest sounding setup ive heard...
Old 10-22-2009, 07:58 AM   #10
Well I did a lil looking around and I was thinking about this Hifonics amp... What do you guys think about it?
http://www.sonicelectronix.com/item_...+-BXi610-.html
Old 10-22-2009, 10:18 AM   #11
BelowBassAudio.com
if you can make them subs 1 ohm then go for it bro!
Old 10-22-2009, 06:53 PM   #12
Well I can wire em down to 1 ohm no problem, I was just wondering if this was a good amp. I've heard Hifonics subs before but never seen or heard anything about their amps. One more question... If I wire these TWO subs down to 1 ohm and then wire them into the 600w X 1 channel on the amp, that means that each sub will get 300w each right?
Old 10-23-2009, 12:22 AM   #13
Team Lethal Beatz
correct if it has two inputs that just makes it easier for slower ppl to wire in without blowing stuff and the amp will bridge them internaly.
Old 10-23-2009, 10:47 AM   #14
BelowBassAudio.com
hifonic amps are good yes.but if i were you if you wanted to get on the amp and brigde the two subs so the amp turns into a 1200. 600w a peice to the sub
Old 10-23-2009, 11:28 AM   #15
delinquent266's Avatar
bridging that amp will not turn it into a 1200 watt amp, if that's what you are saying.
that's a nice little amp for those subs if they're only 300rms each. Should match up pretty well. just wire em in parallel and drop it to 1 ohm like you said. Good luck!
Old 10-25-2009, 05:28 PM   #16
skunk0526's Avatar
Agreed. will also run 500w rms regardless of the ohm load (1.5 to 4) I always liked the signal sensing to eliminate the turn on. Makes life a lot easier. less wires is always better.
It will SLAM your w3's in a vented box.
Old 10-27-2009, 02:15 AM   #17
Got Art?
old_skool_noma's Avatar
mmm w3s ive got a single 10w3 set up for home theater with only 100 watts, i cant turn it up much or the window sounds like it will fall out, the response is flat down to about 20 hz, 5 cubic foot box tuned to 21 hz
