Fatmat?
Im wanting to do the entire interior of my truck, and was wondering if fatmat is any good, i found it on ebay for a good price? also any tips on installing, would be much appreciated... thanks
They took our jorbs.
Re: Fatmat?
As far as installing you will want three things: A hardwood roller A good cleaner (I like acetone, and make sure you have gloves) A sharp box cutter Remove everything from the truck, vacuum up any loose crap, and then clean the area very well. A typical thing to do when dealing with asphalt is to heat the area of application with a heat gun or a blow dryer. I like to carry this over when dealing with butyl as I feel like it promotes adhesion. Just take your time, make sure your mating surfaces are clean, and expect it to be a good day or two worth of work. Last edited by Heathd : 08-01-2008 at 01:02 PM. |
The How-To Guy
Location: Cache, OK User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: Fatmat?
Here is a really good site that compares different brands of sound deadener at tests each one.
http://www.sounddeadenershowdown.com/ |
Re: Fatmat?
Re: Fatmat?
Re: Fatmat?
Two Weeks!!
Re: Fatmat?
I have used both Accumat and Fatmat (both butyl based) with great results. The Fatmat was a bit thinner than the Accumat but they were basically the same. The Fatmat had an odor for a couple of days but then it went away.
Re: Fatmat?
thats how its been down here in austin.. |
Re: Fatmat?
Thank you for your help... it will be probably about a month before i am able to do this, but i think i will be using fatmat because its pretty cheap. i will definitely post pics when i get all dont, thanks again.
Re: Fatmat?
I just bought some Fatmat...its a little thinner than Dynamat Xtreme. If anything, just double layer it.
Po Po
Re: Fatmat?
I used the dynamat xtreme I got 2 36 square feet boxes for 250. I've had no problems with the Dallas heat so far. I have 2 layers on the roof and back wall. Going to put a second layer on the floor and doors.
Nario
Re: Fatmat?
how much fatmat does it take to do a extended cab s10?
Re: Fatmat?
