Big Three (Big 3) Upgrade How-To
LinkBack (5) Thread Tools
Old 10-06-2009, 02:55 AM   #101
ptbll's Avatar
Re: Big Three (Big 3) Upgrade How-To
I have 4 ga for the big 3 & 2/0 going to the amp&cap and it still dims the lights a little, I'm running an alt from a 98 lumina on an 86 jimmy 2.8, the 2/0 is actually welding wire, will this actually have something to do with the dimming, or do I need to go bigger than 4 ga.
Old 10-06-2009, 06:07 PM   #102
I pee standing
juddspaintballs's Avatar
What system are you running? You might be exceeding the capacity of your alternator.
Old 10-07-2009, 02:39 AM   #103
ptbll's Avatar
I'm running a pheonix gold 800 watts class d amp pushing 4 8 inch kicker comp v's with a 3 farat cap, amp has 2 power input and according to the manual I can put the cap in the 2nd input. It says its connected inside, the cap registers 14.5 volts so I know it has power.
Old 10-26-2009, 05:49 PM   #104
Just curious....Does anyone sell the big three kit pre-made ?
Old 10-26-2009, 09:34 PM   #105
I pee standing
I don't think so (it would be easy for a simple entrepreneur to get into making a kit for specific vehicles), but most HO alternator companies sell you a thicker gauge cable for the main charging wire.
Old 10-29-2009, 08:03 PM   #106
Its that dam ADD!
Forklift's Avatar
I was doing it for the v8 GM full size crowd, but with no normal S-10, I cant do it for you guys here
Old 10-31-2009, 11:54 PM   #107
Hillbilly Mechanic
i highly suggest running the same size or bigger wire for your big 3 that you use to run front to back.
your alternator could be on its way out if your dimming with 800 watts, or if your battery isn't the greatest, that could be another reason.
i always suggest a good battery to be installed with the big 3 with any kind of power being used, as it makes a huge difference.
Old 11-22-2009, 03:32 AM   #108
Thanks For Your Support
terryl's Avatar
Well this is the first time I have seen this. Anyone know if a kit for this is sold anywhere? I'm really lazy nowadays. Great how-to!
Old 11-22-2009, 11:51 AM   #109
Zr2USA = B_Rich
B_Rich's Avatar
I know there is a link to a kit over on Zr2USA.com that some guy makes. I really don't think it's worth it though since it's upwards of $100 and it isn't 1/0ga wire. I got my 1/0 Stinger hyper-flex wire for $55 shipped on ebay, and 10 gold ring connectors were $10 more.
Old 01-06-2010, 12:43 PM   #110
tenor39's Avatar
Actually, for the short runs of wire needed for the "Big 3", 4ga. is absolutely fine. Remember, you need the larger guage wire over distance because of its internal resistance being lower, hense the capacity to deliver more current. 4ga. in the lengths needed can handle many hundreds of amps without power loss or internal heating of the wire.
As far as a pre-made assembly goes, $100 is pretty reasonable, especially if it's done right. You have to include your labor in building it as part of the cost, as your time is worth something, too. Gives me some food for thought... Would folks be interested in a well made kit? It could be tailored to any S-10 as long as I had the correct measurements.
Old 01-13-2010, 12:15 PM   #111
Got Art?
old_skool_noma's Avatar
after doing some research on conductivity, gold connectors arent really worth the extra money unless corrosion is a major concern, their best use is for audio becasue of resistance to corrosion and that is all, silver is the most conductive element followed closely by copper and gold in third. here is a list of the top 10 most conductive elements. and a few others that may be interesting to see
Element Measure of Conductivity
1. Silver .63 10^6 /cm Ω
2. Copper .596 10^6/cm Ω
3. Gold .452 10^6/cm Ω
4. Aluminum .377 10^6/cm Ω
5. Beryllium .313 10^6/cm Ω
6. Calcium .298 10^6/cm Ω
7. Magnesium .226 10^6/cm Ω
8. Rhodium .211 10^6/cm Ω
9. Sodium .21 10^6/cm Ω
10. Iridium .197 10^6/cm Ω
_______
14. Zinc .166 10^6/cm Ω
15. Nickel .143 10^6/cm Ω
_______
22. Iron .0993 10^6/cm Ω
23.
Platinum .0966 10^6/cm Ω
_______
25. Tin .0917 10^6/cm Ω
_______
27. Chromium .0774 10^6/cm Ω
_______
37. Vandium .0489 10^6/cm Ω
_______
39. Lead .0481 10^6/cm Ω
40. Uranium .038 10^6/cm Ω
_______
48. Titanium .0234 10^6/cm Ω
_______
54. Neodymium .0157 10^6/cm Ω
_______
63. Mercury .0104 10^6/cm Ω
_______
66. Bismuth .00867 10^6/cm Ω
_______
70. Plutonium .00666 10^6/cm Ω
71. Carbon .00061 10^6/cm Ω
_______
74. Silicon 2.52E^-12 10^6/cm Ω
Here's where I got the info in case there are disputes
http://environmentalchemistry.com/yo...lectrical.html
Old 02-02-2010, 11:21 AM   #112
PFlanagan's Avatar
when you guys do this, do you leave the stock positive->alternator wire? or do you somehow delete it out and just use one of your new big 3 wires?
Old 02-02-2010, 12:17 PM   #113
I pee standing
Some notes
2) You do not have to disconnect any stock wires and it is actually recommended you leave stock wires in. Unless you're sure you know what you're doing, leaving the stock wires in is not a bad idea. You can take them out if you'd like, but it is not necessary. Your choice. Just don't let them dangle around inside your engine bay.
Leave it in and plugged into the alternator.
Old 02-15-2010, 08:29 PM   #114
very helpful thread will definitely will be doing this, this summer.
Old 03-04-2010, 08:08 PM   #115
just did this today while I was working on some other things on my truck. Happy with the results, just need a upgraded battery and I'll be at full force
Old 03-13-2010, 02:57 AM   #116
acknowledge it.
joyride's Avatar
sorry if this has been asked before, but is using 2 gauge wire a bad thing for the big 3? im installing an efan with my motor swap and i figured with my taurus fan since it eats up so much power, i'd go a step bigger than 4gauge and use 2 gauge...bigger the better right?
Old 03-13-2010, 03:43 AM   #117
Got Art?
pretty much. 2 ga wont hurt a thing
Old 03-13-2010, 03:51 AM   #118
acknowledge it.
joyride's Avatar
cool, thanks man. i didn't think it'd matter but felt the need to ask to be sure...appreciate it.
Old 03-17-2010, 07:17 PM   #119
i just ordered my new system, and am worried about power drain. my battery is a year old and i just got my alternator tested and it checked out good. i ordered a 2010 cvx and a hifonics amp, that i will be running at 750rms. would 4 gauge big 3 and 4 gauge power wire to the amp be enough?
Old 03-17-2010, 09:35 PM   #120
I pee standing
It would suffice for that, but if you ever think you're going to go larger, I urge you to use 1/0 or better. It's cheaper in the long run and it sucks to have to run your wire more than once.
Old 03-18-2010, 04:14 PM   #121
so today i got my wires all cut and put ring terminals on them, and am wondering, which wires do you keep from the factory? orr are you replacing all?
Old 03-18-2010, 04:32 PM   #122
so there are NO factory wires that get plugged back into the battery or do they?
Old 03-19-2010, 12:49 AM   #123
ßɭĬƮƵ's Avatar
Old 03-19-2010, 10:43 AM   #124
so every wire gets plugged back into the battery? the factory positive and negative ring terminals go back on? and it all of the pictures it looks like people removed the factory wire from the back of the alternator
Old 03-19-2010, 01:45 PM   #125
ßɭĬƮƵ's Avatar
Leave everything how it is and just add yours...
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f27/big-three-big-3-upgrade-how-to-321309/
Posted By For Type Date
:: View topic - hmm??? This thread Refback 12-19-2007 11:24 PM
alternator/battery prob. - Page 2 - JeepForum.com This thread Refback 11-25-2007 08:52 AM
alternator/battery prob. - JeepForum.com This thread Refback 11-23-2007 06:34 PM
alternator/battery prob. - JeepForum.com This thread Refback 11-23-2007 05:51 PM
alternator/battery prob. - JeepForum.com This thread Refback 11-23-2007 05:28 PM
