Big Three (Big 3) Upgrade How-To
LinkBack (5) Thread Tools
Old 10-30-2007, 10:46 PM   5 links from elsewhere to this Post. Click to view. #1
she's wearing pink undies
juddspaintballs's Avatar
What is the Big Three (Big 3) upgrade?
The Big Three upgrade, simply put, is upgrading the main three electrical charging wires in a vehicle's electrical system. These wires are the power wire from the alternator to the battery positive, the engine block to a ground, and the battery negative to a ground.
Why should I upgrade the Big Three?
The stock big three wires are often inadequate to handle the extra electrical draw of anything other than a stock electrical system. Since the majority of us like to upgrade our trucks, we often add on to the electrical system. People that see the most noticeable need for the big three upgrade are those running aftermarket lighting, just about any stereo setup that includes an amplifier, those running compressors, e-fans, ect.
Upgrading the big three often solves many people's electrical shortcomings by decreasing the resistance to the flow of electrical current in the vehicle's electrical system. This upgrade should always be the first step in attempting to solve electrical shortcomings (such as dimming headlights, your voltage meter reading 12v on the dash, etc.). It's by far the cheapest upgrade you can do for your electrical system. Also, if you already have, or plan on getting a high output alternator, upgrading the big three is an absolute must. The stock wiring is too small and can easily melt and catch your engine on fire. Then people like me get to come and jam a nozzle through your hood and fill your engine bay with water.
What does the Big Three Upgrade do?
Stock wiring for the big three in our engines can be as little as 8 awg wire. This was actually the case in my 1996 4.3L Jimmy. Very very few of our trucks actually came with 4 awg stock wires for the big three.
Ok, so what's wrong with 8 awg wire? Well, since no wire is 100% conductive, all wire has what is called resistance: the characteristic of the wire that impedes the flow of electrical current through it. Larger thickness (gauge or awg) wire has less resistance/impedence than smaller thickness wire. Longer wire has more total resistance than shorter wire of the same thickness. So to decrease the amount of resistance in a wire, you want to keep it as short and thick as possible. 8 awg wire is not very large and therefore has considerable resistance. If you try pushing/pulling a large amount of current through the wire, it will heat up (a form of electrical loss) and you still won't get the current through any faster (actually a hair slower because heat slightly changes the characteristics of the wire). It's like the difference of the flow of water in a garden hose and a 4" water supply hose from a hydrant to a fire truck. A hydrant can feed either hose, but the larger hose will move more water easier. An alternator can feed small wire or large wire, but larger wire will move more current easier.
How do I upgrade my Big Three?
Very simply, you upgrade the wires in the big three with larger gauge wires.
Things you'll need:
- About 5-10' of 4 awg or larger wire. The larger wire you can afford the better
- Several ring terminals for your size wire (6 usually: one for each end of each of the three wires)
- Wire brush (to clean your ground)
- Extended battery posts if needed
- Other tools as needed
First, disconnect your negative battery terminal like you should always do for safety when working on your vehicle. Next, while you have the wrench for the negative battery terminal, disconnect the positive one as well.
Measure your length of wires out by test fitting them into place before cutting. It is not a bad idea to follow the stock route for the alternator to battery positive wire so you don't get it caught in the serpentine belt or resting on an exhaust header. Go ahead and cut to length your wires and add the ring terminals.
Connect your new power wire to the alternator power location (usually the bolt on the back of the alternator where the stock wire is connected). Thread that wire through how you are going to run it to the battery and connect the ring terminal to the positive battery post.
If you need to use post extenders, now is the time to add the positive one.
pic of side 'post' extender:
My alternator with the engine block ground on the front of the alternator:
Now you need to focus on your grounds. As usual, a ground at the frame is best. The frame is conveniently located almost directly below our battery trays. You have no excuse not to use it. Especially since you can use the bolt location for the tow hook on the passenger frame rail so you don't even have to do any drilling. Even if you don't have hooks, the holes should still be there. Make the metal shiny before you bolt the ground to it. Then take that ground up to the battery negative terminal. Now your battery is solidly grounded. Note: you can ground to the body/chassis but you must scrape paint away until you're on bare metal, but the frame is still the preferred method.
My OLD 4 awg frame ground (it's now 1/0 awg)
Now for the third and final wire: the engine block ground. Basically, find any bolt on your engine that you can safely (don't be stupid) bolt a wire to to ground the engine block. Don't use the alternator power wire (that defeats the purpose and will short your electrical system and cause a fire once again). The easiest bolts to use are the ones holding the alternator to the bracket or one of the bolts holding the case of the alternator together. You can run this wire either to the battery negative terminal or directly to the same ground location on your frame as the battery negative to ground. Either way is acceptable.
Ralphie's entire big three complete:
He chose to ground to the chassis (I still strongly recommend the frame but this is OK). You can see his extended battery posts in this picture too.
Picture of alternator power wire and engine grounds courtesy of Joe (Paint Toad). He's using two engine grounds (one to frame and one to battery) as a little bit of overkill, but it isn't a bad idea.
Some notes
1) Fuses are NOT necessary. Fusing the power wire is pointless because power flows from both ends (either battery positive terminal or the alternator)
2) You do not have to disconnect any stock wires and it is actually recommended you leave stock wires in. Unless you're sure you know what you're doing, leaving the stock wires in is not a bad idea. You can take them out if you'd like, but it is not necessary. Your choice. Just don't let them dangle around inside your engine bay.
3) This upgrade takes about 30 minutes if you comprehend what you're actually doing. All you're doing is replacing three wires with larger wires basically.
4) Leave a little slack in the wires. The engine moves within the engine bay.
5) Use dielectric grease on your battery and wire terminal connections when you bolt them to parts of your truck to help prevent corrosion and help maintain a better contact.
Also, here's the link I learned from in case I've failed to explain this well enough
http://forum.sounddomain.com/forum/u...=5;t=007801;p=
Old 11-03-2007, 01:14 AM   #2
drunk and bored
Sir Toad's Avatar
Re: Big Three (Big 3) Upgrade How-To
Quote: Originally Posted by williambriggs
gonna do this eventually...is there some kinda special crimp tool to lock those copper terminals on the wires? seems like i try using a vise and channellocks and they just fall off...
http://www.s10forum.com/forum/f27/gr...1/#post4505439
read that......don't just skim it........then make your decision......
but yes.....they make a stupid crimp tool you hit with a hammer
Old 11-03-2007, 02:43 AM   #3
drunk and bored
Sir Toad's Avatar
thanks alot..never thought of soldering them on..i have a nice solder gun that i never used sitting in the tool box too lol..
you need a torch for heavy gauge wire
Old 11-03-2007, 02:57 AM   #4
Resident Wetback
suicidal's Avatar
How exactly do you do it? i'm interested. just need some instruction.
Old 11-03-2007, 03:19 AM   #5
drunk and bored
Sir Toad's Avatar
it is 100% impossible for me to explain so you could understand,sorry.....different types of soldering are 2nd nature to me....my dad(an electrician) had me soldering before i was 10
someone might give you a good description....
tinned wire is key......as well as pre-tinning your lug
then,depending on the type and gauge of lug/wire you need to clamp either the lug or the cable........now it's just heating and melting solder.....making sure it flows into the wire strands and flows to the lug.......
that is the best i can describe it,sorry.
Old 11-25-2007, 12:55 AM   #6
Like my Boobies??
s10junkie98's Avatar
thanks bud any advice on how to solder the large wires?
Old 11-25-2007, 02:20 AM   #7
ask joe, he's more of an expert on it than I am. my method is to heat up the wire with a little rosin on it, then melt the solder onto the wire then heat up the terminal, and put the wire in, crimp it and melt solder onto the terminal and wire. and when I say crimp...I mean use a chisel or punch and pound the terminal onto the wire because I don't have one of those fancy crimping tools
Old 11-25-2007, 10:29 AM   #8
drunk and bored
Sir Toad's Avatar
basically the same except i use rosin core solder and i don't crimp
Old 02-04-2008, 01:09 PM   #9
badboy69's Avatar
on the big three what do you do with the little black box that holds the mega fuse and the power wire coming from the engine bay fuse box
Old 02-04-2008, 01:28 PM   #10
drunk and bored
Sir Toad's Avatar
leave it alone....as stated a couple of times....you leave the factory wiring intact
Old 02-08-2008, 03:45 PM   #11
drunk and bored
Sir Toad's Avatar
cleaned it jed
updated this as well as the how-to(added a pic to the how-to)
http://www.s10forum.com/forum/f202/b...how-to-321330/
Old 02-16-2008, 09:09 PM   #12
badboy69's Avatar
i did the big three today, and it says it should solve the problem of reading 12v on the dash gauge, well it didn't for me just wondering what else can i do here,oh yeah i don;t have anything hook up right now other than the man wires. any sugestions would help
Old 02-16-2008, 09:11 PM   #13
Negative 10
KENNYMO's Avatar
if i do this will it bring my gauge back up to 14. i have underdrive pulleys so when im at an idle it drops to 11 or 12.
Old 02-16-2008, 09:14 PM   #14
Negative 10
KENNYMO's Avatar
also whats the point of the frame to cab mount?
can i just use normal amp wire for this? the same wire everyone uses to power there amps.
Old 02-16-2008, 09:41 PM   #15
there was no promise to bring your voltage back to 14. it helps power flow in your system and it usually can bring it back to 14 unless you're seriously drawing from your system or have alternator problems. but even if it didn't solve your problem, you have to do this upgrade before you add a high output alternator.
Old 02-16-2008, 09:44 PM   #16
Certified Auto HVAC Tech
layinlow88's Avatar
agreed....thanks to this...i solved my compressor problems....with both running...they would literally kill my truck
thanks for the write up judd!
Old 02-16-2008, 11:17 PM   #17
Negative 10
KENNYMO's Avatar
what about my question? any answers to it?
Old 02-16-2008, 11:26 PM   #18
drunk and bored
Sir Toad's Avatar
frame to cab is because the cab is mounted on rubber mounts......rubber does not conduct electricity very well
bypass it if you drill a hole in your floor and ground directly to the frame....i have not done that....yet.
Old 02-16-2008, 11:28 PM   #19
Negative 10
KENNYMO's Avatar
oh that makes sense. ok well can i use amp power wire for the big 3?
Old 02-16-2008, 11:35 PM   #20
drunk and bored
Sir Toad's Avatar
what else would you use?
Old 02-17-2008, 12:35 AM   #21
Negative 10
KENNYMO's Avatar
well everyone is saying to order wire off the internet
Old 02-17-2008, 12:38 AM   #22
AFFILIATED KREW
AVNCHRIS's Avatar
it cheaper to order wire.. off the internet...
Old 02-17-2008, 12:46 AM   #23
drunk and bored
Sir Toad's Avatar
sorta.....but you still get tagged with shipping......on 1/0 that can get pricey.......i'm lucky,i've got local hookups..........for everthing
Old 02-17-2008, 01:24 AM   #24
i got my 1/0 when the price of copper was down. $89 shipped for 50' with my name printed on it.
Old 02-17-2008, 02:02 AM   #25
AFFILIATED KREW
AVNCHRIS's Avatar
yup me 2.. lol got it for free..
shhhhhh next door does not have power wire..
nahhh just kinding... got it from my dad.. they ran over some welding wire.at is work..so they were throw it away.. but my dad got for me...
Old 02-19-2008, 08:01 PM   #26
Dime Bagged
10Droped's Avatar
hey paint toad was size fuse are you running from your alt to your batt?
Old 02-20-2008, 12:05 AM   #27
drunk and bored
Sir Toad's Avatar
none
Old 02-20-2008, 02:46 PM   #28
Dime Bagged
10Droped's Avatar
my bad that was another truck pic above yours. so you have had no problems then without one?
Old 02-20-2008, 04:05 PM   #29
it's only going to help if you get a short in the wire. and like stated in the first post, since power flows from either side on the power wire (battery and alternator), a fuse isn't going to do any good if you get a short.
Old 05-03-2008, 02:51 AM   #30
Its that dam ADD!
Forklift's Avatar
great write up man, lovin it. If youd like I could bring over a few of my write-ups from Blazin Low and GMFS on radio, alarm, and amp wiring
I also posted up in the classifieds about selling some big 3 kits made out of 4ga for $25 shipped, to get rid of all the etra wire I have around. Im working on getting some 1/0 due to the 100 or so 1/0 connectors I have left over. Bolts are extra.
Old 05-06-2008, 03:13 AM   #31
iFail
is the same amount of the wire needed the same for a first gen?
Old 05-06-2008, 03:25 AM   #32
layinlow88's Avatar
its universal...you can Big 3 Upgrade anything...
not sure what you mean by amount..like..gauge or length?
Old 05-06-2008, 02:02 PM   #33
the length of wire needed was only an estimate (but pretty close to actual). it'll be about the same for just about any front engine car with the battery in the engine bay. when they start putting the battery in the back seat or trunk or moving the engine to the rear, that changes a few things.
Old 05-07-2008, 10:43 PM   #34
mburns5us's Avatar
i couldnt find any 4 ga wire around here so i bought battery cables with terminal rings on both ends they are 4 ga,hope this will work for now.Let me know if it wont.
Old 05-07-2008, 11:41 PM   #35
wire is wire. the first time i did the upgrade i used battery cables too. walmart had them on sale (for whatever reason). $1 for 42" 4 gauge battery cables with ring terminals on one end. i bought every single one they had in the store. funny thing is, the 36" ones were still almost $4.
Old 05-09-2008, 11:10 PM   #36
iFail
length
Old 06-14-2008, 08:04 AM   #37
Awesome write up man, really helped out, jus got one problem, after i got done with the wire hook ups (i didnt remove the stock wiring) my truck fired right up, at idle i was sittin at 15 to 16 volts, i went out about an hour and a half later and my truck wouldn't start, so i disconnected the alternator to positive battery wire, and it fired right up, the alternator is brand new, like not even a week old, and the battery is about a year old. Im afraid to hook it back up, dont wanna cause any damage. Any idea on what might cause this?
Old 06-14-2008, 04:57 PM   #38
Ok, false alarm and major coincidence, i replaced my starter about a month ago and i guess i got a bad one, it just decided to act up the same day i upgraded my wires, thanx anyway
Old 06-14-2008, 08:49 PM   #39
I'm a GIRL! :)
XtremelyYellow's Avatar
Here are the links to what I used for mine:
Wire:
http://cgi.ebay.com/MONSTER-CABLE-6-...QQcmdZViewItem
Battery Terminals:
http://cgi.ebay.com/STINGER-DIGITAL-...QQcmdZViewItem
Wire Terminals: 1/2" ring ones
http://happyterminals.com/index.php?...karg l7p08bl1
Braided Sleeving: He has some other colors too.
http://cgi.ebay.com/ebaymotors/3-4-E...74QQtcZ photo
Heat shrink:
http://www.partsexpress.com/webpage....Group _ID=245
Old 06-16-2008, 07:04 PM   #40
very clean dana, thanks for the links. they'll ward off a few dozen PM's for me
Old 06-16-2008, 07:05 PM   #41
I'm a GIRL! :)
lol... I know exactly what you mean
Old 06-23-2008, 10:57 PM   #42
blazerxtreme18's Avatar
I APOLOGIZED FOR ALL THE ?'S REMEMBER....
Old 06-23-2008, 11:16 PM   #43
I'm a GIRL! :)
I was not talking about you... paranoid
Old 07-10-2008, 03:44 AM   #44
lwrd93's Avatar
where do most ppl run there 0 gauge threw the firewall at? at to the amps.. anyone have pics of the big 3 on a first gen how much wire did it take??
Old 07-11-2008, 01:30 AM   #45
lol just sayin it anyway lol
Old 07-11-2008, 01:38 AM   #46
lwrd93's Avatar
come one someone has done this on a first gen..
Old 07-11-2008, 01:52 AM   #47
Blazin_Jason's Avatar
Ya no pics though. Maybe tomorrow but I don't know how much wire I used.
Old 07-12-2008, 09:31 PM   #48
Pics aren't the best. For the batt to frame I cleaned up a spot on the frame down to shiny steel, drilled and tapped some holes for the ring terminals. After being bolted in I sprayed some undercoating over them. My engine ground goes to the bolt where the alt mounts. Cleaned up the underside of the bolt head and threads and used star washers as well. I also don't have my + to alt output fused.
Old 07-13-2008, 02:08 AM   #49
lwrd93's Avatar
nice thanks...
Old 07-13-2008, 12:13 PM   #50
lwrd93's Avatar
we should have a post your big 3 sticky...
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f27/big-three-big-3-upgrade-how-to-321309/
Posted By For Type Date
:: View topic - hmm??? This thread Refback 12-20-2007 12:24 AM
alternator/battery prob. - Page 2 - JeepForum.com This thread Refback 11-25-2007 09:52 AM
alternator/battery prob. - JeepForum.com This thread Refback 11-23-2007 07:34 PM
alternator/battery prob. - JeepForum.com This thread Refback 11-23-2007 06:51 PM
alternator/battery prob. - JeepForum.com This thread Refback 11-23-2007 06:28 PM
Page generated in 0.66119 seconds with 31 queries
[Output: 230.65 Kb. compressed to 211.78 Kb. by saving 18.87 Kb. (8.18%)]
