2 or 4????
Old 06-29-2008, 01:52 AM   #1
RED ROCKET52 is on a distinguished road
2 or 4????
Wondering what i should go with here im looking into a new pioneer premier sub and wondering if i should go 2 ohm or 4.... just wondering the advantages/disadvantages of each and which one in your opinion is better
Old 06-29-2008, 02:09 AM   #2
tuckin' fx4
zachmartin83's Avatar
zachmartin83 is on a distinguished road
Re: 2 or 4????
same thing.
just depends on how you wire them to the amp really.
Old 06-29-2008, 03:05 AM   #3
takin it easy
triple r's Avatar
triple r is on a distinguished road
Re: 2 or 4????
what kind of amp do you have and what kind of power does it put out at 4 ohms/2 ohms
Old 06-29-2008, 01:29 PM   #4
Panda s10 driving mofo.
PandaS10's Avatar
PandaS10 has a little shameless behaviour in the past
Re: 2 or 4????
if you get the two ohm subs, you can wire them down to one ohm, or up to four. if you get the four ohm ones, you can wire them down to two, or up to eight. really it just depends on wether your amp is one ohm, two ohm, or four ohm stable. you want the lowest ohm load so you can get the most power from your amp.
Old 06-29-2008, 01:30 PM   #5
Re: 2 or 4????
that was my next question the premier sub is 3000 watts max and i was wondering what i should push it with. And Does the 2 ohm or 4 ohm effect the sound quality or what is the actual difference? what setups do u guys have??
Old 06-29-2008, 01:33 PM   #6
Re: 2 or 4????
So if i buy the 2 ohm Premier at 3000 watts what kind of amp should i use?
Old 06-29-2008, 01:34 PM   #7
Bovine on NOS!!
Tuteuk's Avatar
Tuteuk is on a distinguished road
Re: 2 or 4????
if you get the two ohm subs, you can wire them down to one ohm, or up to four. if you get the four ohm ones, you can wire them down to two, or up to eight. really it just depends on whether your amp is one ohm, two ohm, or four ohm stable. you want the lowest ohm load so you can get the most power from your amp.
the answer is there...
Old 06-29-2008, 01:46 PM   #8
PandaS10's Avatar
Re: 2 or 4????
are they dual vc? assuming they are not dual vc, and they take 3000w max, you can probably feed them 1200-1500 rms. and you are going to run two of them, so you would need to be able to run 2500-3000w rms. thats a shitton of power, you would need to upgrade your electrical system. big three, extra battery, hi output (200amp) alternater. after that, you would need to choose an amp that is either stable at one ohm, or two amps that are stable at two ohms. that is your choice. i personally would go with sundown, they make a great product.
Old 06-29-2008, 01:58 PM   #9
Re: 2 or 4????
They're Pioneer Premier 3000 watt max Subs if that helps and yes they are dual vc and actually i was only going to run one of them. RMS is 1000 watts and any other suggestions besides sundown haha
Old 06-29-2008, 03:32 PM   #10
PandaS10's Avatar
Re: 2 or 4????
infinity, alpine(you'll pay a pretty penny), us amps, older ppi, there are others.... i think sundown will be nicest on your budget. you could run kicker but there are a hundred reasons not to starting with it's kicker, and ending with...it's kicker... if you want to run one, and they are dcv, get the two ohm model and run them in parallel for a one ohm, or run them in series for a four ohm. or get the four ohm model and run it in parallel for a two ohm or run it in series for a 4ohm...
Old 06-29-2008, 03:51 PM   #11
Re: 2 or 4????
thanks for all the help have u ever heard of lanzar? i hear they're cheap and they can push alot of power but i dunno if they are anygood.....
Old 06-29-2008, 04:04 PM   #12
JED
juddspaintballs's Avatar
juddspaintballs is on a distinguished road
Re: 2 or 4????
the only lazar that is any good is the opti2000d
Old 06-29-2008, 04:17 PM   #13
takin it easy
triple r's Avatar
Re: 2 or 4????
i put in some lanzar subs for a dude, they were kinda cheap for what he paid for them
Old 06-30-2008, 10:25 PM   #14
Distracted Longbed Driver
old_skool_noma's Avatar
old_skool_noma will become famous soon enough
Re: 2 or 4????
on the subs it doesn't mater but it does on the load of the amp, every time the resistance is cut in half, you THD will double, which isn't normally a problem becasue most of the time it is .01% or something and it isn't noticeable at all. im not sure if the load affects signal to noise ratio or not.
Old 07-02-2008, 09:51 AM   #15
takin it easy
triple r's Avatar
Re: 2 or 4????
it does once you get into the .5-.35 area but not many setups run that low. im fact, im one of the only ones that i know of that is running that low. i think im at .38 on my hk401sx on 3 type r dual 2 all in parallel
Old 07-02-2008, 04:34 PM   #16
** Sik Addictions **
sLonoma22's Avatar
sLonoma22 is on a distinguished road
Re: 2 or 4????
wow didnt realize how bad of a taste Kicker has left with A LOT of people on this forum. I would run a kicker amp..
the sundown SAE1000D would be a good choice, powerful - reliable - clean - power.
Old 07-02-2008, 10:07 PM   #17
PandaS10's Avatar
Re: 2 or 4????
kicker amps put out dirty signals. so i don't run them, and the sundown sae1000d is what i plan on getting next.
Old 07-03-2008, 05:50 PM   #18
takin it easy
triple r's Avatar
Re: 2 or 4????
wow, i have never heard that b4, everyone that has run them has always told me that kicker amps put out some clean power
Old 07-03-2008, 11:02 PM   #19
that short kid
shortS10owner's Avatar
shortS10owner is on a distinguished road
Re: 2 or 4????
Mine hasnt had any problems, but what i may think sounds good, which is anything above stock, and my last cheap ass setup, is different than what Judds, or someone else on here might think. Kicker's amps are also usually underated a good bit. My zx250.2 had 293 on the test sheet that came with it
Old 07-04-2008, 09:16 AM   #20
takin it easy
triple r's Avatar
Re: 2 or 4????
my 200.2 on my highs and mids had 229 on the b-sheet
Old 07-04-2008, 02:18 PM   #21
PandaS10's Avatar
Re: 2 or 4????
they definately put out tons of power, its just that signal quality is in question by many. this is of course in comparison to alpine jl and such
Page generated in 0.18879 seconds with 11 queries
