12W6's or 3's?
Old 11-06-2009, 07:30 PM   #51
mattclifford's Avatar
Re: 12W6's or 3's?
oops, i didn't see this one before. you really think three w3's would sound as good as two w6's? hell, since we're on the subject again what about two 10w7's? i know they need a ton of air space so i hadn't even really considered them before.
Quote: Originally Posted by Forklift
As far as the ohm load, that would be a 2.66ohm off of 3 8ohm speakers. That JL amp reconfigures its power supply based on the ohm load sent to it, it was fine.
To the OP, if your going to do the 750/1, Id rather see you do 3 W3s than 2 W6s. It would cost less, have more cone area, and be a great match.
I tried to edit, couldnt do it
Old 11-06-2009, 09:16 PM   #52
Zr2USA = B_Rich
B_Rich's Avatar
Re: 12W6's or 3's?
2 10W7's > 2 12W6's
That's a lot of money though
Old 11-07-2009, 04:04 AM   #53
Re: 12W6's or 3's?
Quote: Originally Posted by iamlayinframe
bad ohm load i said you must had a great ohm load. there is no way to have a 2 channel amp to run three and get a great watts per sub. you can do it if ur volts are right but still your ohm load will be off even if you had 6 ohm 8ohm subs. and you will get half the power + amp will run really hot thats how you **** amps up. if you had a 2 channel 1000 watt amp hooked to three you would be probly around 200 watts per sub not alot if you want to be loud
not trying to be rude but i beg to differ kicker use to have the zr and zx amps that you could run three subs on that where 4 ohm and get good wattage to each sub and the amps where bad ass the only draw back to any kicker amp is they draw so much voltage from your electrical system
Old 11-07-2009, 05:00 AM   #54
drunk and bored
Sir Toad's Avatar
Re: 12W6's or 3's?
.lovely......all these tight ass s10 owners that can't afford jl crack me up!!!!
granted..jl mAy not be the end all of audio...but the haters can swuck my peter!!!!
yes, i did say swuck!!!!
Old 11-07-2009, 12:49 PM   #55
... i dont know?
old_skool_noma's Avatar
Re: 12W6's or 3's?
Mr Toad, Sir, Youre back!!! May the swucking continue.
and just so you know, i love my w3
Old 11-07-2009, 02:27 PM   #56
NOS make light brighter!
danssoslow's Avatar
Re: 12W6's or 3's?
I'd ask where Toad's been; but his avitar looks like he's been in France. OOH LA LA!!!
Old 11-07-2009, 02:28 PM   #57
Zr2USA = B_Rich
B_Rich's Avatar
Re: 12W6's or 3's?
wee wee?
Old 11-07-2009, 05:44 PM   #58
danssoslow's Avatar
Re: 12W6's or 3's?
Mercee bookoo pee wee?
Old 11-07-2009, 11:58 PM   #59
Its that dam ADD!
Forklift's Avatar
Re: 12W6's or 3's?
I said hit harder on that amp, yes
2 W7s on that amp, no, one W7 on that amp, yes (I know its over powering it, dont whine, most good subs like that)
Old 11-18-2009, 09:50 PM   #60
Re: 12W6's or 3's?
little update... although i don't have any of the goods yet, i'm planning on going with one 12w7 and the hd750/1. maybe double that later on..? what do you guys think?
btw, so far i've got a premier deh-p710bt with c2-400x's in the dash and c2-650x's in the doors.
Old 11-18-2009, 10:59 PM   #61
Zr2USA = B_Rich
B_Rich's Avatar
Re: 12W6's or 3's?
1 12W7 > 2 W6's and 2 W3's
IMO
Page generated in 1.47503 seconds with 31 queries
[Output: 75.86 Kb. compressed to 70.98 Kb. by saving 4.88 Kb. (6.43%)]
