LinkBack (15) | Thread Tools |
#251 |
Got 20's?
Re: Teaching Fiberglass (part one and two)
i must say that looks amazing! what kind of wood is that? particle board? just wondering why that was used instad of mdf.
how much money/time have you put into this project so far? |
#252 |
I Like Fire....HaHaHa
But, MDF could have been used and certainly someone could use it if they have experience with it. You know what I mean. Particle board to me is like fiberglassing to others. Some know it and how to construct with it and others don't. I just used what I had experience with. But, the particle board is 5/8", not 3/4". Because the pieces of particle are short in length and seriously braced, there is very little doubt in my mind of the 5/8" flexing. If the pieces were larger, then I would have used 3/4". The 5/8" also allowed me to stay within dimensions and keep internal volume for the woofers. I've probably got roughly $150 in it right now with materials. And by the time the glass is on and bondo'd, it'll have roughly $250 into it. If I were to sell it, considering the materials involved, the hours of labor involved, its utererly precise fit in the cab and its design work allowing for the 3 woofers and 4 amps in a regular cab with 2 click loss on the seats, I'd sell it for no less that $800. You seriously have to see it in person to appreciate all the intricate angles, bologne cuts, construction, and fitment. Its dead nuts on the money. I'd honestly say its probably +/- 1 - 2mm off on measurement at the most. I invested in a couple tools to help me to this one. I bought a bandsaw, scroll saw and some squaring clamps. Enclosure wise, its the best I've made and by far the most intricate. Chappy316 will see it, he can report on it. Its probably the most stout box I've made too. That damn thing will probably survive and accident that I'm sure the truck wouldn't |
#253 |
SOLD!
thanks again man! |
#254 |
#255 |
flat blue and layin frame
i want to ride along
#256 |
SOLD!
#257 |
SIC FL Chapter prez
Hey nick saw the picts. I promise not to use fleece anymore and go with spandex now....lol.
#258 |
Update:
Because it was cold as hell here I let the resin cure for 2 days before handling it. With polyester and even epoxy based resins, you need to be mindful of the climate you are applying it in. If its too hot, the resin or epoxy will cure really fast. Sometimes too fast and in such case that is referred to as Cook Off. Also be midful of the 14 drops per 1.5oz of resin. When hot outside, sometimes less drops will be sufficient. However, when its cold, the cure time slows dramatically. And, you will need to add more drops of hardner per 1.5 oz of resin. For example: When I applied the resin on this enclosure, it was exactly 48 degrees in my garage. I mixed one 3oz batch and was adding 60 drops of hardner to the resin. After that, I heated the resin. Thats 30 drops per 1.5oz of resin at 48 degrees. You will, in colder temperatures, need to add more hardner or the cure may not even occur fully or penetration into the fabric is more difficult. Here is the trick of the trade. Heat up the resin. When its cold, the resin seams thicker, like molasis rather than runier like slightly thickened syrup. DO NOT get too hot. All you need to do is grab a bucket and get hot ass water and put it in the bucket. Then submerge your resin container 3/4 deep in to the water. Do not fully submerge as you don't want water mixing at all with your mix. After 15 minutes, pull the resin container out and dry it with a paper towel. Then you can proceed as usual using 14 - 20 drops of hardner per 1.5oz of resin at 48 degrees. Here are the pics of it installed. They show a bit better the amount of room gained with this box over the last one. Also notice how the box edges are flush as a mofo with the cab walls. Fits snug as a bug in there. PERFECT. |
#259 |
Got 20's?
that looks amazing... Just wondering...When you'll be putting the mat/cloth over the whole thing, aren't you gonna go over the edges too? If so that would make them thicker and the box won't fit anymore... Thats how i ****ed up my jumpseat boxes, so then i had to trim plastic around the box
Also, do you have any back shots of the box, just want to see what you did with the fabric. Overlap over the edges or it just ends on the side. Last edited by x00 : 01-25-2006 at 10:41 AM. |
#260 |
I'm about to get started on the center console. After which I'll fab up the new dash bezel and then I'll make one large order for glass. When I get that in I'll spend a weekend glassing all three (box, console, bezel) and then its all on like a pot of stew with the bondo work. But, the spandex stretched really nicely so after the glass, ther shouldn't be much bondo to do. Thank God. As far as pictures of the rear. I don't have them, I'll shoot a couple tonight. But, I stretched it completely around the bottom and the sides, fully enclosing the skeleton. Then I trimmed the access off. Like I said, I'll shoot some of the back side tonight. |
#261 |
Hey you all,
Check out the video I made. The link is in my sig. I downloaded all kinds of small videos and then chopped them all up and put them into one. Lots of various footage you all may have seen before. Music is Korn and I shot some footage of fire in my garage and added it in along with an atom bomb explosion to give it a little bit of a dramatic appeal. Enjoy. Just a little something back for you all. 3+ minutes long. 56K guys beware. Last edited by JACKEL : 01-25-2006 at 11:09 AM. |
#262 |
![]() And it looks great stuffed in there. Hows the smoothness of it so far? Im curious to all the sanding you'll have to do |
#263 |
BiggerIsBetter,
The spandex is very smooth. I'll use probably 100 grit, really quick on it (nothing crazy) just to score the surface so the resin and glass have a good bonding surface when I lay it on. I'm telling you, if you use spandex, you'll save money and a shit load of time. I'm not kidding. All the sanding involved with fleece is long behind you if you use it. It may cost more than fleece, but the savings in resin, time, effore, etc, more than offsets that cost. |
#264 |
Beer, Bait and Ammo
you are a monster....
#265 |
Serves function and looks awesome. |
#266 |
You may have read my thread in the Off Topic section about the other sub box in this thread.
Until I hear other wise, I'm considering it to be a stolen item. DO NOT part-take in transactions with Dropped01X, YOU WILL get burned. God Damn, I'm pissed. |
#267 |
Super short vid of me working on the sub bow.
Just in case you all were curious on how its done. Well you can now sort of put the face behind the name. I'm using a 2" diameter drum sander on a die grinder to even up some surfaces. http://www.filecabi.net/u.php?file=1138219493.wmv |
#268 |
Got 20's?
#269 |
My friends, thats the hardcore way of doing it. Brings you closer in your relationship with your truck when you breathe and bleed its creation, lol. pssssssssst, I also talk to her while I work. Just kidding. |
#270 |
SOLD!
hahaoh yea, and its "on like donkey kong" for future reference... Last edited by Chappy316 : 01-25-2006 at 06:36 PM. |
#271 |
I love the smell of resin. Maybe I'll be glassing when you get here. My shop smells like a resin factory. |
#272 |
body droppin'
lookin good. thats the same jig saw I have. works good for the price.
#273 |
SOLD!
lol |
#274 |
SLASH - S.I.C. St. Louis
I drive a 01 regular cab, Pewter in color, currently half-bagged! Last edited by jherrell : 01-26-2006 at 09:02 AM. |
#275 |
#276 |
#277 |
#278 |
BIG NEWS!!!!!!!
I'm A Dad!!!!! Kelly, my wife, gave birth to our daughter, Lily, this morning at 10:26 central. Just in case you all thought I disappeared today. Thats what was going on. Note to self: You know you're addicted to this forum when; you go home real quick to get some shit and you squeeze in a few minutes on the forum to announce the news and hit up some pm's. ![]() |
#279 |
body dropped
Congrats ! Who knew you had time to %@#$ with all the glassing goin on.
#280 |
Thanks guys. Its pretty damn sureal. I've seen some shit in life (prior service and all) but this is the first time the world seemed to move in slow motion as it was coming out. Fvcking unbelievable that women do that shit. And, actually want to do it. Makes me glad as hell that the day I was born, I had a dick, constituting me as a male so that I didn't have to go through that shit. God Damn !!!!!!!!! is all I have to say about that. I'm heading back to the hospital. You guys have a good weekend and I'll hit up pm'd questions some time this weekend when I can. Thanks, -Nick |
#281 |
SOLD!
dude thats awesome news, CONGRATS!
#282 |
Wow.. congratulations to you and the wifey ! Heh.. now the hard part starts
#283 |
BodyDropped Member
congrats nick!
#284 |
ANGRY BABY!
first and foremost, congrats on the little one.
that box fits like a glove. im amazed, really. and i dont know whats worse, breathing in fiberglass dust, or galvinized metal, heh. |
#285 |
Congrats to you & your wife. Post some pics of the family. I remember the night when our daughter was born. You are correct I was amazed when I saw Donna born. It gives you a new outlook on the female gender. I hope ya'll have a daughter as good as ours.
#286 |
Family Update:
Baby and mother are healthy. Lily, My Wife Kelly and Myself ![]() Lily ![]() Life is good. |
#287 |
Tech. Update:
While I have down time with the kid for a little while, I thought I'd give you guys some FYI related items that would be useful. Here's what you do. Go to Home Depot and get a graduated cup with ounces. Also get some masking tape and a one ounce cup. I will provide the necessary things to write on it but follow the pictures. This is a "Drops of Hardner per OZ. of Resin, per Temperature Table" that I did up for you guys. This is based on my experience given the temperatures and humidity (two factors highly influential on the cure rate of resin. These drop counts might not be exact for your humidity levels so experiment a little. Remember, in lower temperatures, drops of hardner significantly increase. In high temps, the counts significantly decrease. Also in high temps, DO NOT MIX BATCHES LARGER THAN 3-4oz. You have to mix smaller batches because of the SIGNIFICANT!! increase in cure rate which could cuase "Cook Off" Get the graduated cup and pour (using the 1 oz cup) pour an oz at a time and mark the cup on the tape. The lines on the cup marking measurement are not entirely accurate. Here is the conversion for you all. Table for Temperatures 40* - 57* Range (DO NOT MIX BELOW 40*) Ounces / Drops 1 / 33 2 / 66 3 / 99 4 / 132 5 / 165 6 / 198 7 / 231 8 / 264 9 / 297 10 / 320 11 / 343 Table for Temperatures 70* + (DO NOT MIX ABOVE 87*, DO NOT MIX LARGE BATCHES of 4+ Oz.) 1 / 9 2 / 18 3 / 27 4 / 36 5 / 45 6 / 52 7 / 57 8 / 60 9 / 63 10 / 66 11 / 69 Remember to experiment as these figures will fluxuate with the temperatures and humidity levels in your region. |
#288 |
life is good congrats on the new daughter. Why is Kelly flippin everybody off? lol
#289 |
Cornerin Demon
wow congrats man, but uh there goes your free time, right out the window
but really dude, congradulations and many happy memories. (and my she be as good at fabing as you are) ![]() |
#290 |
Thanks for all your wishes of luck with the baby. Honestly, I think I can balance the time with the baby. But obviously the baby will win on my time, which is why I already allocated and mentally prepared myself for a June completion of the interior and a June 07' completion of the entire truck, mods, paint and all and ready to drag. |
#291 |
SOLD!
congrats again man, and its still funny that you make time to post on here with a baby thats only a few days old... haha!
#292 |
#293 |
Cornerin Demon
ouch, 07? she better be worth it
#294 |
thanks for the chart bro.. theres always the question of how much of what w/ how much of what. And Goodluck! shes a cutie
#295 |
SOLD!
#296 |
-Sorry to toot my own horn there. |
#297 |
#298 |
Update, Back to Business:
I started working on the switch panel for the center console. as with the theme of the rest of the fiberglassed items such as the TV and Amps, the switch pabel will be pushed to create a 3D appearance. I have (4) DPDT 7/8" X 1 1/8" rocker switches and (1) Carlington Marine Rocker push/pull DPDT rocker switch. The 4 smaller switches are for individual bag control and the marine rocker is for pancake up/dn. In these pictures I'm using 1/4" thick plywood. I mapped out the switch arrangement and positioned them to give them a little flare and create a nice effect on the glass when its streched over it. Much like the guages in the last console in this thread. In case you were curious on how to cut the holes for the switches, use a hand held scroll saw. Drill a hole into the area where the switch will be and fish your saw blade through. Then reattach it to the saw and start cutting. Then use a file to line up the edges. Remember, for wood working, a file isn't actually what is used. Its actually called a 'Rasp" but, it looks very similar to that of a typical file. This series of pictures will show what I have just explained. The switches are a perfect fit. they are snugg as hell but are easy to pull out. You need a fit such as this because you DO NOT want to mount the switch permanently in the event that a switch fails and needs replacement. Mounting them permanently may result in making a whole new console. Sorry. A little blurry. I should have the guage platform cut tomorrow as well as the capacitor's mounting ring. |
#299 |
Cornerin Demon
hahaha would never have remembered to use a copeing saw, would have just gone and grabbed my rotozip and dived in headfirst, then wondered my everything was too loose.
looks really clean BTW, can't wait to see more. congrats |
#300 |
body droppin'
where did you get those switches from?
