Overhead Console Temp Sensor
I have recently installed my short overhead console with Mode Functions. I have read I need to calibrate the compass, which I haven't done yet, but will. My question is my temp sensor says its 104 outside when its like 75-80. I have the ground wire direct to the battery, ( I may move it) and the other wire into the harness. Is my sensor bad?
The next question is, is there a way to reset the module so that it resets the average speed? Thanks, Nick |
Re: Overhead Console Temp Sensor
thats what calibrating is supposed to fix.
try to calibrate first then see if its still wrong. |
Calibrating the compass will also calibrate the Temp sensor or the resetting of the average speed?
Sorry. |
lol, durr. sorry. I am at work and apparently wasnt paying attention.
There has to be a test for the resistance at certain temperatures for the sensor. you might just have a bad sensor. |
