No Illumination
Checked my fuses and all are good, but I have no dash illuminations lights. My headlaps and parklamps switches both work, and when I move my dimmer all the way to the right the interior light will come on but no dash lights?
Bad lights in the cluster or dimmer switch? Any help would be greatly appreciated. |
88 S10 Owner
Re: No Illumination
assuming you have an older s10, i have the same problem with mine besides 1 or 2 lights come on when i start but nothing after that. i pulled the cluster, bulbs were all fine, i check the wiring and so forth and all good. im assuming my cluster just has a bad circuit on the plastic board that wraps around the back, or whatever term its called. also, my lighs in my temp control dont work either and never checked the wiring to see if that ran off the cluster or not.
Useless posting member
Re: No Illumination
Mines the same way.. no gauge lights, but all of my dummy and interior lights work.
94 2.2, feel the power?
Re: No Illumination
Probably a bad dimmer switch.
88 S10 Owner
Re: No Illumination
i cleaned the dimmer switch contacts on mine and checked the wiring also and cleaned the part where the clip clips onto and still no luck for me. i ran 2 leds which i put above the guages off the dimmer switch which work and to get me by until i pull the dash to do work to that.
88 S10 Owner
Re: No Illumination
as i am searching and reading more on this from other years and blazer's trucks.. one of the fixes seem to be the clusters ground. so anyone know the ground wire color for the cluster's? i got an 88, and im guessing the colors remain the same for most the years or close to. id like to trace the ground down and mess with that and see what i get, or if u know where the clusters ground is at that would be better.
Re: No Illumination
same search results i came up with another guy in a another tpic i started in 1st gen said to check the grounds.
nyone know what ground and were this ground should be located |
88 S10 Owner
Re: No Illumination
Re: No Illumination
k thanks. may just have to go by adavnce and flip through a chiltons and see. the chiltons I use to have had wiring diamgrams but i'm not sure if it'll show the location of the cluster grounds
88 S10 Owner
Re: No Illumination
here is a reply i got from a guy i seen that posted on one of them help sites and left his email for anyone that needed help with this.
Re: No Illumination
may have to run down real quick and check. I had the kick panels off yesterday while I was cleaning the carpet but didn't see any grounds. I'll have to dig around sum more
