#51 |
WILL WORK FOR PARTS
Re: Different gm steering wheel that fits?
the new wheels do fit, but the actual column is different. i just tried all of this on saturday.
you just have to unbolt the wheel and put the new (99+) wheel on and voila! |
#52 |
Local Tech
#53 |
Have a nice day!
It does, but the steering wheel bolts up and works perfectly. The airbag connectors were different, so I cut and spliced the wires and nothing bad happened.
My 98 had the steering wheel with the big ugly horn button so i found a leather wrapped one off an 03 extreme with the smaller horn button |
#54 |
Have a nice day!
Old:
![]() New: ![]() |
#55 |
Local Tech
yea, thats the same ugly wheel i have lol (the first one that is)
#56 |
Jeep lover
Yeah thats what I thought, great pics. I knew they were different but I've never seen them side by side..
You can see the 1st one is starting to wear down a with that cheap foam stuff on it. Looks like I need a wheel as well as an airbag |
#57 |
Have a nice day!
Yeah man the leather is nice. Doesn't make a bunch of squeaking noise when you turn the wheel lol
This swap really should be a how-to, because the newer wheels will swap into the earlier years too I believe. |
#58 |
I had the 94-97 style wheel too and decided to ditch it for a nice wood wheel. I would look into the new grant wheels with airbags. They make em for all of the new full size chevys idk if they have one for the s10s yet. Any chance an hhr wheel would fit?
#59 |
Finally got a day off work, so I'll try the Colorado wheel today. And I would NEVER EVER splice airbag wiring. Just the thought that a little corrosion on the splice or it grounding out, or even the wrong voltage could put a 200MPH balloon in my face seems bad.
#60 |
Local Tech
great! let us know as soon as you can! Thanks
#61 |
id really like to have this one on my 01 if it poss. any one know if it is?
![]() i have this one but the ring around it is all rotted and flaky ![]() |
#62 |
Build them right....Mod
If you have a 98-02 S10, the Yukon/Escalade wheel for the same year will work.
The airbag is the same ![]() |
#63 |
Local Tech
^^^ perfect! thats good enough for me if they have a nice charcoal or black one
#64 |
What wheels will fit a 97?...
#65 |
snapdaddy
what does that look like installed?
#66 |
Nick |
#67 |
Any link to said plugs?
#68 |
Local Tech
thats all well and good........ if the pins are the same
#69 |
I know NOTHING about it... but I would always have that thought in the back of my head saying "the connector was different cause this bag needs XX signal/voltage, and the other was more/less".
While you're at it, might as well look for a wheel with stereo controls though. ![]() I have a '94... no airbag, so I can put whatever I want on there ![]() |
#70 |
I picked one up with stereo controls that's going into my 2000 Blazer project. This style wheel will work on 99-05 S10's. (the airbag has two steel pins) It will also fit a 98 S10, if it has option package ZN4. 98's without ZN4 use an airbag with 4 steel pins. Last edited by philntx : 01-07-2009 at 03:43 PM. |
#71 |
Pickle Puss
I wantd a Cadillac wheel for mine, however the price of the wheel alone is enough, I didn'twant to kno what the airbag was going to cost me. I might s well just go with an aftermarket wheel.
#72 |
Road Racing Blazer
#73 |
There are quite a few choices for this style steering wheel. It uses the same airbag as the S10 for 99-02
#74 |
I think that textured leather looks like shit!
#75 |
Pickle Puss
I'd agree. Looks awful.
#76 |
Low life or No life
i never would have thought to do a different stock wheel thats awesome gave me alot of ideals thanx alot guys
#77 |
#78 |
i found this on yearone..figured it'd contribute somehow.
http://www.yearone.com/serverfiles/f...p?hid=P26CE744 edit:: WOW i just saw the price of those wheels. |
#79 |
Registered Boozer
I highly doubt it but, does anyone know if the 2nd gen steering wheels fit the first gens?
#80 |
real names Chris
The trailblazer wheel posted above looked like it would possibly or atleast be a close fit, with a custom or home made adapter im sure you could make it though. Also, how in the hell do you actually get the airbag out of the new style wheel's without destroying them!?
#81 |
Registered Boozer
Thanks Chris
Anybody know for sure????? I don't have the finances to buy one and have it not fit. Thanks |
#82 |
real names Chris
ok, I've been looking at alot of pictures of them and comparing, not positive but im pretty sure they would fit, only thing im not 100% on is the size of the spline, otherwise they look pretty much the same. A couple months ago I was at the junk yard and found a perfectly good tb steering wheel but i did not know exactly how to get the air bag out, so my friend tried and ended up cutting it, well then it looked like shit and I did not want it, next time im up ill look for another one and grab it
#83 |
snapdaddy
has any one installed the Yukon/Escalade wheel yet.....??
#84 |
Center your wheels!
I'm debating either a TB/FSC steering wheel or maybe a C5/C6 vette wheel... anybody know if either of those will fit on a 2002 column??
