Ungodly slow
98+ gauge cluster with aftermarket gauges
Wondering if anyone has pics and a quick "how you did it". Throwing around a couple ideas in my head and thought I would see what others are doing
Registered Pimp
Re: 98+ gauge cluster with aftermarket gauges
I changed my bulbs same thing, lower the column, pop plastic shit off, , 4 10mm bolts, take off harness, put in new guages, all done!
Ungodly slow
I'm talking about installing aftermarket gauges such as autometer in the place of the stock cluster
Registered Pimp
Ooh no clue.
ROLL TIDE!!!!!!
i plan on doing this soon since i swapped to a 98+ dash instead of the 95 and also i have a v8
but it will be after christmas before i get to do it |
I have one in progress because im doing a V8 swap.
Here is the only pic i got ![]() |
ROLL TIDE!!!!!!
that looks real good man what is that panel you are using to mount them?
i was thinking of fiberglassing a panel then cut out for the gauges are you making it to where you can snap the clear back over the gauges? i want to make it look as factory as possible |
Ive got a very thin piece of lexan to go back over front, it will probably get glued in.
the back is thick acrylic(1/2" maybe), im trying to decide if i should put LEDs around it to make it light up, or paint it and be done. Should be real clean and factory when im done |
ROLL TIDE!!!!!!
dont forget about lights for your blinkers and highbeam indicator
meh, who needs dummy lights
![]() I will probably just use some LED's, maybe one on each side of oil for blinker, and one between tac&spedo for hibrights |
give me an opinion on thisIm bagging the truck too. Do they make mini air pressure gauges? I could put two over the spedo and two over the tac ![]() Id have to find the perfect size and black faces to do it right |
88 S10 Owner
this is the smallest i can find (1 1/2)
http://www.egauges.com/vdo_mult.asp?...essure&Units=E not sure if its of your look tho. |
ROLL TIDE!!!!!!
i dont think i would try to put more gauges in it
it would look too crowded to me i think its fine just the way you have it |
Yeah I just measured, the gauges would have to be less then an inch in diameter.
There is no way I could get em to look right and not be overcrowded. And they would be to small to read easily Im just gonna put normal ones where the heat/ac controls go..... |
ROLL TIDE!!!!!!
haha we have like the same ideas
i am fiberglasssing all the vents and holes in my bezel except the headunit location and cutting three holes where the a/c controls used to be for air guages lol Last edited by draggindime072010 : 11-08-2009 at 02:40 AM. |
s-clusive oh. prez
kinda ot here but this is how i did my air gages basically the same as his idea but i just cut a piece of 1/2 acyrlic and milled out gage holes and stuck teh tank pressure in the hole for the 4wd delete plate.
... i dont know?
damn, jake, you need a radio/hvac panel like mine too, plenty of room for gauges then, i know i need to fix the cracked paint and the epoxy around the radio
on my v8 swap we cut the cluster apart, took the clear face off and put new gauges in the overlay. oddly enough 2 1/6 gauges slide right into the cut outs.. add a couple idiot lights for turn signals and high beam indicator and your good to go. we just took a peice of plexi and painted it black to cover the rest of the holes as i dont have a speedo or the rest of the idiot lights anymore due to the lack of a computer.
