can i use the stock Gm fuel sender?
Go Back   S-10 Forum > Sponsor Forums > Aurora Instruments
Old 10-11-2009, 03:15 AM   #1
91 S10's Avatar
Hey I have the full aurora gauge set, I made a nice custom cluster for my 91 s10 i was wondering if i can use the stock Gm fuel sender to the aurora fuel gauge? I do not want to drill a hole in the tank and mount the one that comes with the kit, Any suggestion or will it work?
Old 10-12-2009, 01:50 PM   #2
Site Sponsor
Adam@Autoloc's Avatar
Re: can i use the stock Gm fuel sender?
no the ohm range is different. it will work but it will be no where near accurate. it'll be way off.
Old 10-12-2009, 02:51 PM   #3
91 S10's Avatar
ok, so what do i need to do to make my gauge work correctly? Do i have to put a hole in the tank? any other options, that you sell that would correct this?
Old 10-12-2009, 03:02 PM   #4
Site Sponsor
http://www.thehoffmangroup.com/autol...?itemid=GARSE5
Old 10-12-2009, 03:12 PM   #5
91 S10's Avatar
the link didnt work?
Old 10-12-2009, 03:27 PM   #6
91 S10's Avatar
ok the link worked, it showed a part for 42 dollars, with no discription, what is it? will this solve my problem? Can you pm your work p# so i can give you a call, and order what i need?
Old 10-13-2009, 05:29 PM   #7
Site Sponsor
Our tech is saying that you will need to cut hole in the tank for it to work properly.
Old 11-12-2009, 03:19 PM   #8
Site Sponsor
91,
Did you get your fuel gauge working? Pm me if you need any help
-adam
