S-10 Main Wiring Harnesses - S-10 Forum
post #1 of 21 Old 07-17-2009, 04:50 PM Thread Starter
Ron@Autoloc's Avatar
User is: Ron@Autoloc is offline
We have been receiving a lot of questions about which wiring harness the S-10 needs. So we have put together 2 Main Wiring Harness Kits for you!
S-10 Main Wiring Harness Basic $185 (CLICK HERE FOR MORE DETAILS)
S-10 Main Wiring Harness Deluxe $350 (CLICK HERE FOR MORE DETAILS)
post #2 of 21 Old 07-18-2009, 05:20 AM
HAND MADE
corkyw123's Avatar
User is: corkyw123 is offline
Re: S-10 Main Wiring Harnesses
Hey, for some reason my computer wont load you wiring harness chart section. So I'll ask you here.
I'm looking into converting my EFI 4cyl to a carbed V8. Of course I'm keeping stock S-10 steering column and seen where you said your harness has the connections for that. So here's the rest of my questions:
With the V8 swap, am I able to keep factory gauge cluster?
Well basically, instead of asking a bunch of questions, do you have a harness that will utilize most stock components (gauge, lights, brakes etc) but hook up the V8?
And no, I dont have power anything inside the truck, but I am converting manual tranny to auto. I'll be running the normal no a/c & heat, have compressors & air guages, radio, etc. Shaved doors aswell
'00 'Noma Stepside
Currently being HACKED ON!!!!
post #3 of 21 Old 07-18-2009, 06:40 PM Thread Starter
Our wiring harness is just the MAIN harness. You will be using your existing engine harness. Our harness will utilize most of your stock components. Sounds like our basic harness will work fine for your project. Have you checked out our instructions?
post #4 of 21 Old 07-22-2009, 11:18 AM
User is: gijoeoif3 is offline
since i would be keeping my engine harness when i install this. what is the best way to separate the 2 wiring harness's on my truck.
i have a 2000 s10 2.2l ext cab
post #5 of 21 Old 07-22-2009, 05:09 PM Thread Starter
Do you mean how you would run it differently? Hide it?
post #6 of 21 Old 07-23-2009, 03:31 AM
oh i should of been more specific. i was talking more about if the wiring harness's are separated in the truck. or are they both wired together and i will have to get a wiring schematic to separate the engine harness from the harness that this will replace. and will i have to leave the original fuse box's in for just one or two engine harness fuses. that kinda stuff. i don't need you to get truck specific for me but just kinda a ruff idea so i know how much work i got ahead of me and if i need to start tracking down the schematics. thanks for all the help i have a strong feeling that this wiring harness has a good chance from saving me from getting more mad at the original one and doing something stupid
post #7 of 21 Old 07-23-2009, 03:54 PM Thread Starter
There are some helpful tips in our instructions. Click here to check em out!
post #8 of 21 Old 09-09-2009, 04:43 PM
boricua4_life's Avatar
User is: boricua4_life is offline
is this the harness i need to drop my 305 in place of my 2.2 on my 01 s-10? what exactly will work with this? i have no power windows or seats. thanks in advance.
post #9 of 21 Old 09-09-2009, 04:44 PM Thread Starter
This is a MAIN wiring harness. We do offer Engine Compartment harnesses. I will need more info on your engine to provide you with a quote for a complete wiring harness.
post #10 of 21 Old 09-29-2009, 12:02 PM
its a standard chevy 305.80s i think
post #11 of 21 Old 09-29-2009, 04:55 PM Thread Starter
$90 for the engine compartment harness. Does NOT come with OEM connectors. You will need to purchase new from an auto parts store or reuse current connectors.
post #12 of 21 Old 10-04-2009, 12:00 PM
RockerDragger's Avatar
User is: RockerDragger is offline
how much for a complete harness for a 2000 4.3 truck going to 350 v8.
truck has all power besides ac and heat?
how would it work with my factory sterring coloum?
post #13 of 21 Old 10-05-2009, 04:03 PM Thread Starter
Engine Compartment Harness: $90
Main Wiring Harness: $350
Our harnesses will plug into your steering column
post #14 of 21 Old 10-07-2009, 10:38 PM
User is: lifeat0psi is offline
with the main harness does it have all the light switch connectors and will it eliminate the computers? i have a 2000 s10 2.2l that i have gutted and dropped a 383 carbes into. none of the stock wiring is in the truck ecept column. will the main harness and engine harness be all i need?
post #15 of 21 Old 10-08-2009, 03:43 PM Thread Starter
Our harnesses do NOT include the connectors. I recommend visiting your local auto supply store. NAPA seems to have the best prices and quality.
Yes the main & engine harnesses will be what ya need. But what are you doing for a headlight switch and other switches?
post #16 of 21 Old 10-08-2009, 10:21 PM
want to use stock switches that are in the dash, and stock turn signal and windshield wiper switch on column
post #17 of 21 Old 10-09-2009, 03:39 PM
92 305 so-blaze-10 xtreme
55mikey55's Avatar
User is: 55mikey55 is offline
Send a message via AIM to 55mikey55
i have a 305 tpi i want to put in my 92 sonoma so all i need are the connections that hook to the harness for the engine. i have the ecm for the tpi. pm me for more info
Project: Old Yeller <- click it
post #18 of 21 Old 10-09-2009, 05:16 PM Thread Starter
Shouldn't be a problem! Here is a link to the instructions for our basic kit so you can see how it installs
http://files.thehoffmangroup.com/ins...ons/KICKBB.pdf
post #19 of 21 Old 10-09-2009, 05:16 PM Thread Starter
You will need to purchase the connectors from Napa or another auto supply parts store.
The engine compartment harness is $90
post #20 of 21 Old 02-05-2010, 09:51 PM
...Icewater...
I.C.all day's Avatar
User is: I.C.all day is offline
i have a 99 s-19 2.2L and the wire for the headlights underneath my stearing column burnt up inside the connector for some reason and headlights don't come on anymore. what type of harness would i need? (engine and everything staying the same)
post #21 of 21 Old 03-02-2010, 03:58 PM
joster's Avatar
User is: joster is offline
hi how much would it cost for a engine compartment wiring harness for my 1987 chevy s10 regular cab 2.5. thank you.
joster is offline
