Site Sponsor
L.E.D.'s Flashing too FAST or SLOOOOW?
It's a simple fix! All you need to do is add a L.E.D. Flasher. We offer 4 different flashers to meet your budget and needs. No Load Adjustable Pulse Flasher No Load Adjustable Flasher No Load Fixed Flasher Heavy Duty 12v Flasher 552 All of the above flashers are round units. They will not work on the 1998 and up S10's ![]() Pictured: No Load Adjustable Pulse Flasher Last edited by Adam@Autoloc : 11-16-2009 at 01:57 PM. Reason: error in copy |
Just Some Guy
Re: L.E.D.'s Flashing too FAST or SLOOOOW?
How/Where exactly do you install these?
Also, when i switch my brake lights to LED, they blink fast. But when I switch my front blinkers to LED, they don't blink at all, and the dash indicator lights stay lit. Will one of these fix THAT problem too? |
Site Sponsor
The S-Series truck flasher is located behind the glovebox. Just remove it and replace with this. This should correct the issues you are having. The stock flasher cannot handle the load. |
Just Some Guy
Ouch the flasher the original poster linked to is only $10, but the shipping is $8, which kind sucks considering it will only cost them $1.56 to ship it
do what!!!!!
No Load Adjustable Flasher No Load Fixed Flasher Heavy Duty 12v Flasher 552 what is the difference in them or are they basically the same? |
Site Sponsor
No Load Adjustable Flasher is the flasher we recommend. If you get a fixed flasher sometimes itll either flash too slow or fast still. With the adjustable you can pick the speed YOU LIKE.
Just Some Guy
Site Sponsor
Just Some Guy
forum idiot
it is behind the glove box door on 98+ on older models its under the dash
94 was a funny year for s10s..i have seen them on the firewall and i have seen them under the radio.. 95-97 its under the radio in the lower dash panel.. 82-93 its under the dash on the firewall in the fuse box also its not that the flasher cant handle the load...leds draw way less current and the electronic flasher in a 98+ reads the resistance and thinks a bulb is out..hence the fast flash.. in the other years its a thermal flasher that when the flasher has a load it heats up a small film of metal and when it gets to hot it bends away..then cools and returns...over and over... |
Just Some Guy
I have a 98+ . . . but i still don't get where it is. Behind the door? I open my door and I don't see anything but the glove box. Do I have to remove the whole glove box? If so, how do I do this?
forum idiot
Just Some Guy
Found it! Ok last question, how do I get the green strap off? I mean I'm sure if I pulled hard enough, it would have came right off. But how do I remove it without breaking it?
forum idiot
i just push it up and over the flasher...and you are going to want to reuse that cause vibrations will make it wiggle itself loose then you will lose brake lights and blinkers...learned that the hard way
Just Some Guy
OK soooooo now what?
Stock Height
Should have just modded the stock one to blink normal with the leds. Post #184
http://www.s10forum.com/forum/f62/le...75/index4.html |
Just Some Guy
So does Sales@Autoloc want to tell me why the part I bought doesn't fit at all?
forum idiot
what you have fits a 82-97 |
forum idiot
uh oh...looks like kris is gone..
Site Sponsor
yes Brian, Kris is gone. My name is Adam. I am doing about the same thing for the company, so if there is anything I can help with or any questions I can answer hit me up.
forum idiot
hi adam! glad to have you aboard
Site Sponsor
so I just talked to the tech guy about the square flasher. we do not have one yet. so sadly we cannot fix this issue. I love starting out with a bang!
and thank you brian, I am glad to be here -adam |
Just Some Guy
#24 |
Site Sponsor
I just edited the original post. Sorry about the confusion.
