♠ Camber'd ♠
Popper question
I installed your Bolt in Door Kit(works great btw), which poppers do you recommend?
Site Sponsor
Re: Popper question
Here are a two that I personally recommend:
DP3000 ![]() DP4000 ![]() Either are adjustable. The non-adjustable door poppers will pop your door open too far. The cheap Chinese ones with the rubber tip will fall off with little use. Then your stuck buying a new pair. You have an existing hole in your door as well. It's right above the latch. Just remove the plug and install your spring loaded door popper there for the best results. |
Site Sponsor
Re: Popper question
Which Popper did you get? are they in yet?
