Site Sponsor
FREEBIE Special!
Purchase ANY Shaved Door Kit and get this for FREEEEE ![]() This is our FLIP KEY SYSTEM $49.95 Value *Key Blank NOT included Autoloc’s™ new switch blade key can accomodate any vehicle with the use of that vehicle’s specific key blank. Get the right blank, have it matched to your vehicle’s current key, and you’re done! Use the buttons on the key fob to operate your door locks or shaved door solenoids, and always have a back up key or your ignition key with you. |
Negative 10
Re: FREEBIE Special!
thats so sick. i want one.
How many buttons? Could it be programed for the stock lock/unlock and hatch on my blazer?
Site Sponsor
It's 8 channels. So yes you can.
Ok so dumb ? for me to buy this what would be involved to make it Lock/unlock and hatch relase on my blazer?
Site Sponsor
I am not 100%. But I am going to assume you would hook it up just like a door lock motor. This is something I plan on doing with my 97' but haven't gotten around to it yet.
Well if/when you do let me know.
If I can do it to my 04 without adding more stuff I will. |
Site Sponsor
I will look at the assembly tomorrow to see how it would work and what you will need.
Cool, thanks!
UN-BANNED B!TCHES!!!!!
can i buy the kit, get the "key fomble" free and return the shaved door kit within 30 days and keep the key fomble?
Site Sponsor
You would only get credit for what is returned. |
WWW.CAROLINATRUCKSCENE.
Site Sponsor
lol
forum idiot
is this going to even work on our trucks?
![]() see how far the key slides in |
Stock Height
Another question is can any key cutter cut them, or would they have to be sent somewhere special. Example, I always get my spares made at lowes, could they cut that thing?
♠ Camber'd ♠
any key place should be able to cut the key.
the blank should come out of the housing.
and yeah how long is the blank to flipper body? |
Site Sponsor
Site Sponsor
Site Sponsor
From one of our techs "The key as a blank part on top, this allows for the key to clear the tabs on the side"
I showed him the pic that Brian posted |
forum idiot
Site Sponsor
Please let me know if you have any more questions.
can you kick one out on jsut a computer ordr i walready hve my 4 75lb poppers im jsut sick of the computer i have its got an alarm on it that wont stop going off
#24 |
Site Sponsor
#25 |
i think hes drunk
#26 |
*INDEPENDENT*
nicee
#27 |
forum idiot
so i guess by the name change that kris no longer works there
#28 |
Negative 10
damn kris now what happened.
#29 |
Site Sponsor
Kris will be handling our other forums. She can still be reached via email or AIM
kristina.ash@thehoffmangroup.com Email KrisHoffmanGroup AIM/AOL |
#30 |
#31 |
Site Sponsor
. You will need to purchase a keyless entry system first. How many channels do you need? |
#32 |
need at least a 4 channel i have a crew cab. would love to be able to remotly lift and drop the truck but dont know how well that would work at. One time I rigged up a setup to do it but i had to use so many relays it wasnt pratical. the set-up is a FBSS so it had 8 relays so that it wouldnt backfeed all the valves when using the ten switch box. I think for it to work, to open the four doors and control the air i would need a 12 channel system. then run a completly seperate alarm system. I probly sound drunk again but this time im jsut sleep deprived
#33 |
♠ Camber'd ♠
Do you have any more info on the aftermarket adapter kit?
http://www.thehoffmangroup.com/autol...o?itemid=TRKA1 |
#34 |
Site Sponsor
![]() You should only need 6 channels to control 4 doors,UP and DOWN. We do have a 8 channel remote system. This way you have two extra channels in case you want to add something else. Click here for 8 channel remote system |
#35 |
i was thinking the 12 chanels would control each valve independently with out having to wire in 8 relays. as the valves dont require alot of power the output from the keyless entry box should be suffecient i would think. that would be the 4 outputs 1 for each door then the 8 for each conrner up and down. not reall big on the digital controlers i like my 2 switches on the dash(pulled them from a 10 switch box one for front and one for back)
#36 |
Site Sponsor
Sounds like you got it figured out. We have our 16 channel with BIRT. Click here Closest thing I have to 12 channels. S10Forum discount would work on this product. |
#37 |
yea thats looking like its what i need i will call in the order sometime next week. Is that good? Or would i need to call it in this week? thanks for the help also is it possible to send me a copy of the instructions (the websites were unable to load) want to make sure the remote wont be too complicated.
#38 |
Site Sponsor
#39 |
firefighter5325@yahoo.com thanks!!
#40 |
Site Sponsor
#41 |
♠ Camber'd ♠
Is the box on the the right the reciever? i dont see it on the site?
#42 |
Site Sponsor
Pictured is an Autoloc Keyless Entry System.
