Harness Question
Was wondering what you charge in total for a harness for a v8 swap into a 97 s10, the motor I have is 5.7l Vortec from a 99 gmc yukon and i have the full engine harness and computer but was also wondering are ur kits more plug and play then messing with the stock original harness?
Makin Sparks
Re: Harness Question
It would be easier/cheaper if you were starting with a 4.2L truck instead of the 2.2, but we can make a new harness for the swap with no problem.
Figure around $750 for that particular harness |
alright, now wat about your MAF and O2 sensor's with the harness for a complete match as ur site says?
Makin Sparks
That depends on the exact combination of parts and programming being used, but the MAf is $85, and the O2 sensors range, but the common ones are $45 ea.
Aight, so was wondering if you would be able to give me a ruff est of wat it would cost for a whole harness plus the maf and 02 sensor added in to Ontario? and also i take it the harness would have the plugs on it for the tranny?
