sway bar - S-10 Forum
sway bar
Old 09-12-2003, 10:37 AM   #1
Project: Sabriel
MuddyS10's Avatar
sway bar
would bad bushings on the sway bar make a loud clunking noise when i turn left, and when i go over just about nething thats not smooth? the only other thing i can figure is that its the t-bars up front, but no one can explain how to see if theyre both keyed the same. the left front bump stop is also sitting directly on the a-arm, no space in between. this is starting to drive me crazy
Old 09-13-2003, 09:55 PM   #2
sign_in_name51's Avatar
alot of s-10s are having this problem. and i'm not sure what it is. maybe someone else has figured it out
Old 09-13-2003, 10:04 PM   #3
I BURN THINGS
Flamed 98's Avatar
This might sound stupid, but check your hood hinge bolts. I've heard of dealers replacing the entire front suspension looking for a clunck, only to find out it was the hood hinge was worn out.
heres a pic. Piece #2 is a bushing they use to fix the problem.
Old 09-14-2003, 12:35 AM   #4
Project: Sabriel
MuddyS10's Avatar
yeah ive heard about the hood hinge problem. when the truck was in the shop, i asked them to look at the front end, but they didnt say nething when i picked it up. and another thing, the drivers side bump-stop is sitting directly on the a-arm w/o ne space at all between. the rubber part is actually compressed cuz its sitting like it is. would that have nething to do with it?
Old 09-14-2003, 08:14 AM   #5
WWJD for a klondike bar?
GotRoxBlazer's Avatar
My hood bolts were actually loose to the point where they were actually going to fall off, both sides. I had the same noise in my blazer though, turned out it was control arm bushings. I replaced them w/ energy suspension bushings. No noise 8O)
Old 09-14-2003, 10:08 AM   #6
Project: Sabriel
MuddyS10's Avatar
dont fmale me - whats the control bar? the u-shaped bar that looks like the sway bar in the front? or is that just the front sway bar...
Old 09-14-2003, 05:23 PM   #7
Control ARM (A.K.A. "A-arm")
Old 09-14-2003, 05:37 PM   #8
Project: Sabriel
MuddyS10's Avatar
oooo....the bushings at the top near the shock mount?
