stock 4x4 to ZR2 - S-10 Forum
post #1 of 13 Old 03-05-2008, 09:10 PM Thread Starter
User is: M866 is offline
Send a message via AIM to M866
stock 4x4 to ZR2
I want to turn a standard 1998 4x4 into a ZR2. What is the difference between the to...I don't have 4 hours to look at all the post to find out..so if someone can help me, I would really appreciated it. I work at a GMC dealership. What do I need, or is there a lift kit that does the same thing. I have read about a lot of problems with a 2-3 inch lift kits. Any info would be great.
M866 is offline
post #2 of 13 Old 03-05-2008, 09:15 PM
3 Leaf Fab
Donahue's Avatar
User is: Donahue is offline
Send a message via AIM to Donahue Send a message via MSN to Donahue
Re: stock 4x4 to ZR2
the frames, fenders, axles, suspension components, etc are different. you could achive the zr2 look with some flairs, a small lift (maybe shackles and t-bar crank or BL) and wheel spacers. but to make it actually a zr2, you would really have to build if from scratch, from the frame up. you would think it would be simple, but in reality its a complete waste of time and money. for the amount of money and work, you could have a SFA s10 that would be 10x better than the zr2 anyways.
btw, welcome to the forum
Just an old dad now...for now at least
Donahue is offline
post #3 of 13 Old 03-05-2008, 09:17 PM
Baggey22's Avatar
User is: Baggey22 is offline
Send a message via AIM to Baggey22 Send a message via Yahoo to Baggey22
A ZR2 is different in a few ways. They are a few inches wider and the suspension is a few inches higher. I don't know the actual numbers. They also have a stronger rear end, which also comes limited slip. Finally in looks they have fender flares to cover the 31" tires that come stock.
To achieve the look of a ZR2 at minimum you'd have to get a 2" body lift and put 31" tires on your truck. Then get fender flares. The fender flares won't look exactly like what comes on a ZR2 but you can get ones that are pretty close. Then get a locker or mini spool or something for your rear axle to match that of a ZR2.
If you want to go bigger you can either get a 5 or 6 inch suspension lift kit OR do a solid axle swap.
1995 S10 4x4 HPD30/8.8(LS) geared 4.10 on 34/10.5/R15 LTBs SOLD
Click here for SAS build thread
MY 1995 S10 HAD A MOTOR SWAP FROM A 1993 BLAZER AND A TRANSMISSION FROM A 1994 BLAZER!!!!!!!
FS: 2" lift shackles(one pair). PM me an offer!
Baggey22 is offline
post #4 of 13 Old 03-05-2008, 09:41 PM Thread Starter
Well I don't care about the wheels and tires and rear end, fenders are the same(fender flares) and the width is the same too... Just different offset wheel's.. I was looking at the lift. What is the different? I was told the rear leaf spring are different, But what about the front??
M866 is offline
post #5 of 13 Old 03-05-2008, 09:41 PM
3 Leaf Fab
Donahue's Avatar
3.9" wider (100 mm), about 3" taller, they have the disked 8.5 with a gov lock. the gov lock is fairly common in s10s or so i hear, and the 8.5 gov lock can be found in a lot of full size trucks.
Donahue is offline
post #6 of 13 Old 03-05-2008, 09:45 PM
3 Leaf Fab
Donahue's Avatar
in a nut shell, the mounting points are lower on the frame. there is some debate on the difference in the springs, and i have yet to figure that one out, but the front frame is different, allowing the control arms to mount lower, and the rear uses a combination of different springs, and different brackets that mount the springs.
Donahue is offline
post #7 of 13 Old 03-05-2008, 10:26 PM Thread Starter
I am very sorry, I just talk to my man at work...and You guys are right...I can not bolt on a ZR2. Thanks for the info... I really like the fact the guys responded right away.
M866 is offline
post #8 of 13 Old 03-05-2008, 10:33 PM
Supa
Gushers's Avatar
User is: Gushers is offline
Fenders are completely different, I have the zr2 fenders and box and the normal fenders and box, I'm just waiting to finish body work and paint it to put it on. larger tires, 3.73 rear end so its a lot easier to just try and get the look than to 'build' a ZR2
Matt
sold.
Gushers is offline
post #9 of 13 Old 03-05-2008, 10:45 PM
goin broke but n style
S15vortecpwr's Avatar
do a body swap with a Zr2 fame. That will get you a ZR2 using your truck
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #10 of 13 Old 03-05-2008, 10:46 PM
blah
Layn Dime's Avatar
User is: Layn Dime is offline
just buy a zr2?
Danny
post #11 of 13 Old 03-06-2008, 01:22 AM
foxracing584's Avatar
User is: foxracing584 is offline
Originally Posted by Cluster View Post
just buy a zr2?
sounds good to me. i would.
post #12 of 13 Old 03-06-2008, 11:48 AM
Banned
User is: 4x4zr2GA is offline
Send a message via AIM to 4x4zr2GA
actually no, the fenders are NOT THE SAME. lol. there cut out about an inch wider opening than regular fenders and have a lip that stick out about an inch inside the flares that the flares bolt to. also the fenders have lik 8 holes drilled in them. it would take some work to put actual zr2 flares on a regular s10 fender. just get the bushwhacker look a like zr2 flares. as for the suspension and frame. completely different. the frame has more reinforcements, the suspension mounting points are dropped slightly giving it the "lift" and its wider up front. not to mention stock 3.73 gears and a eaton g80 gov-lock out back. and of course factory 31" tires. all you would really have to do to make it resemble a zr2 is get a small lift, some wheel spacers + wider rims, bigger tires, and some flares. it would look close, but you would still see a difference.
4x4zr2GA is offline
post #13 of 13 Old 03-06-2008, 05:35 PM
sapperb's Avatar
User is: sapperb is offline
just buy a zr2?
YUP!! Thats why I did. I love having a bowtie for the dezert and bowtie for the mud!!!
sapperb is offline
