fabing my own shackles
Old 02-05-2009, 07:00 PM   #1
im fabing my own shackles for my 2wd 00 noma, but i want to know wich is the width of the bolts, iwould mesure it by myself but right now dont have my truck with me
Old 02-05-2009, 10:13 PM   #2
BLZR1's Avatar
Re: fabing my own shackles
coming from my own experience, get 2 new bushings first, then build the shackle to the width of the bushing. I built my shackles inner width at 2 5/8" n even tho the leafs r 2 1/2 my shackles still weren't wide enuf, so we grinded the crap out of the bushing. For bolts, I think mine were 1/2" thick by 4" long. I hope I helped ya a lil bit
Old 02-05-2009, 11:28 PM   #3
I was thinking on building them 3" inner so i could use the stock bushings cause they are in good shape and maybe use the 1/2" bolts of 4" long
Old 02-06-2009, 09:25 AM   #4
BLZR1's Avatar
yeah if you can reuse the stock bushings, that will save you $20. In my case, I had to melt the stock bushings out with an acetylene torch and hammer away at them with an air hammer to get them and the old bolts out - but I also live in michigan where there is more salt on the roads than snow
Old 02-06-2009, 12:12 PM   #5
thank you very much man for your help, if anyone has more ideas or suggestions be free to tell them cause right now its rainning around here so all the welding will have to wait for 2 or 3 days.
Old 02-08-2009, 09:09 PM   #6
wait...what?
ura HOE call me's Avatar
for my rear shackles, we got 2 pairs of stock shackles. flipped one and laid them together. welded the seem inside and outside, ground the welds with a flap wheel, then used 1/4" steel plate and plated the inside, and outside and sides of the shackle. It lifted the back nicely, and has not had any problems. I was going to just fab some up from scratch, but I didn't have the metal I needed at the moment, and a buddy of mine had an extra pair of stock shackles.
Old 02-09-2009, 11:09 PM   #7
BigBoy70's Avatar
get some flat stock and make your own.....thats what I did; at least if you build them yourself you'll know that they are strong enuff to take a beating
my .02
Old 02-18-2009, 03:33 PM   #8
finally i did my own shackles there will be more images when install them.
Old 02-18-2009, 03:34 PM   #9
and they cost me less than 10 bucks
