bad cv????
Old 11-10-2009, 11:15 PM   #1
crew cab sfbd commin soon
blazed00's Avatar
bad cv????
i have a 01 4x4 blazer. im wondering if my cv is bad. The front of my truck is clanking and i can move the cv with my hand. idk anything about 4x4s. how difficult is it to replace.
Old 11-13-2009, 09:58 AM   #2
02crewcab's Avatar
Re: bad cv????
if the CV joint is bad there should be alot of dark/greenish grease slung around the area
Old 11-15-2009, 02:07 PM   #3
Re: bad cv????
I went thru 4 remanufactured CV axles from O'Riellys. I finally got a brand new one.
Don't go to O"'Riellys and Don't get a remanufactured one. They are a pain in the butt to replace.
Old 11-15-2009, 02:07 PM   #4
Dain Bramaged
Re: bad cv????
This would be correct if you are diagnosing a ripped CV boot....
There should be no play in the joints themselves. I just replaced my right side axle as the inner joint had about 1/2" of up/down play. Took care of my problems.
Old 11-15-2009, 07:17 PM   #5
02crewcab's Avatar
Re: bad cv????
well mine did the same thing as blazed00, and it was because the CV boot ripped and it had no grease so it was grinding
Old 11-15-2009, 07:36 PM   #6
blazed00's Avatar
Re: bad cv????
i rplaced both cv's today. and somethng on the right side is notright still. its making a grinding sound now. and when i took the old cv out the axle shaft inside the tube slid out and has a bunch of play in it.
Old 11-16-2009, 09:49 AM   #7
montec's Avatar
Re: bad cv????
I would say bad front diff and maybe a hub bearing.
