98 2wd-->98 4wd
Old 04-21-2009, 11:36 AM   #1
tommyramone55's Avatar
98 2wd-->98 4wd
hey there i was just wondering how hard it would be to convert my 2wd 98 sonoma to a 4wd 98 sonoma haha
just wanted to get an idea...
thanks guys
Old 04-21-2009, 11:39 AM   #2
Calico 1st Gen
90blueS10's Avatar
Re: 98 2wd-->98 4wd
well.. if you want to go the SFA route.. start reading up in the solid axle section...
if you want to go IFS.. then you have to either cut your frame in half and swap in the independent front.. or switch frames to a 4x4 frame.
Old 04-22-2009, 01:04 AM   #3
3 Leaf Fab
Donahue's Avatar
Re: 98 2wd-->98 4wd
it would be easier by far to just swap in a solid axle than try and get the stock IFS to work.
Old 04-22-2009, 01:50 AM   #4
wrekd's Avatar
Re: 98 2wd-->98 4wd
If you cant do the SAS, just swap your body onto a 4x4 frame. That would be the easiest way.
Old 04-22-2009, 12:07 PM   #5
GOT A NEW S10 WOO
bubbagt57's Avatar
Re: 98 2wd-->98 4wd
/thread
Old 04-22-2009, 01:07 PM   #6
banderillero90's Avatar
Re: 98 2wd-->98 4wd
How about all-wheel drive like the syclones and typhoons? would the front need a limited slip?
Old 04-22-2009, 10:07 PM   #7
95BlazerLT4wd's Avatar
Re: 98 2wd-->98 4wd
you wouldnt need to cut your frame in half. who the fvck taught you that?
Old 04-22-2009, 11:35 PM   #8
Slightly Over Built
DieselS10's Avatar
Re: 98 2wd-->98 4wd
Like already mentioned, if your wanting a solid axle go for it, if your wanting IFS sell your truck and buy a 4wd, GM already did it for ya.
Old 04-22-2009, 11:37 PM   #9
Calico 1st Gen
90blueS10's Avatar
Re: 98 2wd-->98 4wd
why wouldnt you?
Old 04-23-2009, 01:47 AM   #10
Registered Abuser
Merritt's Avatar
Re: 98 2wd-->98 4wd
why wouldnt you?
Just switch the IFS parts over from the 4x4 to the 2x4, then the trans/transfer case/driveshaft.
Old 04-23-2009, 05:47 PM   #11
3 Leaf Fab
Donahue's Avatar
Re: 98 2wd-->98 4wd
the frame is completely different on the 2wd verse the 4wd. i'm with 90blueS10, you would basically need the front half of a 4wd frame to swap over the 4wd suspension. nothing is the same between the two, not the control arms, not the mount for the differential (which the 2wd doesnt even have a provision for), nothing.
Old 04-23-2009, 09:36 PM   #12
Re: 98 2wd-->98 4wd
if you wanted to do it that bad you could do it, by no means do you absolutely have to cut the frame in half, thats the dumbest thing ive ever heard.
Old 04-23-2009, 11:10 PM   #13
Slightly Over Built
DieselS10's Avatar
Re: 98 2wd-->98 4wd
It wouldn't be any different than sub-framing an old car. I've done it many times and if you spend a little time doing it, it can be very hard to detect were it was done, but the only thing that I would be doing with 4wd S10 IFS is removing it.
Old 04-26-2009, 11:43 PM   #14
Registered Abuser
Merritt's Avatar
Re: 98 2wd-->98 4wd
Yeah, I'm still IFS, but if I was making a 2wd into a 4wd, especially if I had any urge to go wheeling, then I think IFS would be the last thing on my mind.
Old 06-30-2009, 11:50 PM   #15
Re: 98 2wd-->98 4wd
was lookin at a sas kit with a dana 30 up front but then for a trans?
Old 08-28-2009, 01:16 AM   #16
Re: 98 2wd-->98 4wd
think im gonna do a sas but im just wondering about the trans if i end up using a dana 30 up front....
where could i find a trans to make it 4x4? for the 2.2...
Old 08-28-2009, 11:09 AM   #17
992drjimmy's Avatar
Re: 98 2wd-->98 4wd
What about swapping your body and engine with all electronics to a SFA frame. Ive been thinking of this for a while. But i reallydont know what frame would be a good choice with nearly correct width axles. I most certainly dont want full width, like a K10 or something.
Old 08-28-2009, 01:27 PM   #18
BillaksBlazer's Avatar
Re: 98 2wd-->98 4wd
it would be easir to do a sfa swap on your current frame. Its really not that hard to do.
Old 08-28-2009, 01:46 PM   #19
992drjimmy's Avatar
Re: 98 2wd-->98 4wd
alot of people say how easy the sas is. But ive never been able to find anyone to help. My welding and fab skills are not good enough to do it.
