#101 |
Re: 4X4 S10 Lift Kits
#102 |
3 Leaf Fab
as for trimming them, its not that bad. its mostly the corners of the fenders that need trimming, not the whole thing, and most of that is specifically the rear of the front fender. on my 89, i trimmed just a little bit (in my eyes) and i was able to clear 32's without any lift and infact you could say it was lowered about an inch just from the t-bars sagging after a trip or two. you can see from the pics, that rear of the front fender sometimes requires a little persuasion with a BFH, as mide did. however, even with 32's i only heard it rub maybe once and that was "flexed out" as well as the IFS could flex. it did however rub the frame and swaybar everytime simply because of the BS on stock rims. ![]() ![]() ![]() |
#103 |
#104 |
3 Leaf Fab
#105 |
#106 |
3 Leaf Fab
its all in that rear corner of the front fender.
#107 |
i've got to say man, i do like the look of the chop top.
#108 |
I Rather Be Wheelin'
Yeah, the cut-outs are the way to go if you're trimming and putting on wider/bigger tires. If you find a place that carried them for a decent price LMK, I'd like to get myself some.
#109 |
BTW, where did you find your graphic for your truck. i'd really like to get something like that? Last edited by BlazerKydd : 02-15-2008 at 01:16 AM. |
#110 |
#111 |
#112 |
#113 |
#114 |
NVRBDUN
What's up guys? I've been mostly doing slammed trucks but now I just bought a 96 blazer 4dr 4wd with a bad motor for $350. I got a motor for it already and I should have my TM 5" lift tomorrow. Planning 33x11.5 or close to that. Will post pics when there is something to see.
Great info in this thread.. |
#115 |
hey... Sup all.. i have a 98 that is starting to be a like a problem child from hell.. i just put a 6" Superlift and 33" tires now i am starting to feel a little lag when taking off.. i am thinking it either needs new gearing in trans or rear end or maybe both with a new motor.. does isn't the 4.3l good as well as the Trans.. any idea's.
#116 |
You need NAAAAWWWWWWZZZZZZZ
#117 |
This thread looks dead. Ohwell if any comes across this for informational purposes or whatever, here is my S10 with a 4in suspension lift and 3in body lift running 33s just for reference. As you can I can fit bigger.
http://i237.photobucket.com/albums/f...g?t=1213844315 http://i237.photobucket.com/albums/f...g?t=1213844208 |
#118 |
Slap my meat on your pita
You forgot to mention that your fenders are trimmed all around.
#119 |
#120 |
![]() Last edited by 89-S-Dime : 06-24-2008 at 04:16 AM. |
#121 |
3 Leaf Fab
#122 |
I always knew you were into that lowering thing.
#123 |
I just bought my S10 truck and it has a custom made 8in body lift. I wanna take it off but I still want to be able to clear my 33 x 12.50 Thornbirds. Does anyone know how much of a lift I will need to clear those tires? If you can help me out I'd appreciate it. Thanks
Mike |
#124 |
what is the fix for 2000 stock with saggy rearend? need to haul around atv for deer season.
#125 |
You need to post pics of that thing. |
#126 |
3 Leaf Fab
#127 |
#128 |
#129 |
Big Tymerz!
hey how do i get a 3ich body lift for my 96 i mena they make one for a 94 what the hell is the difference?
#130 |
Im picturing a 2 story truck....or a 4wd double decker bus! |
#131 |
[quote=89-S-Dime;3695339]Lift kits available for your IFS 4x4 S-series
Superlift 2" lift kit: This kit comes with new torsion bar adjuster keys that attach to the rear end of the torsion bars. These load the torsion bars and determine vehicle ride height. Replacement tubular, upper control arms make realignment possible. For rear lift, the options are add-a-leafs and/or shackles. This lift is known to cause premature wear of CV boots, ball joints, idler arms and pitman arms due to the more severe angles created by the upper a-arms and t-bar crank. Although 2" to 3" can be achieved using this lift, that is the maximum and will increase wear. Rough Country 2" lift kit: This kit is very similar to the Superlift 2" lift. It also comes with new torsion bar adjuster keys to lift the front and new upper control arms. For rear lift it provides shackles. Also included are front shock relocation brackets and polyurethane bushings. Rough Country has redesigned the front control arms to releave the balljoints as far as the Superlift kit goes I dont think they did. Last edited by 2002crewcab : 11-14-2008 at 05:55 PM. |
#132 |
The arms are fine, I would still use the stock keys and crank them 1.5", get a wheel alignment and call it a day
#133 |
how much trimming would u have to do to fit 35s on a zr2 with a 6inch susp lift?
#134 |
#135 |
ya i just joined i seen all of the info and you guys are great. i am 17 and have always love the muscle car scene until recently i started the LOVING the lifted trucks. i want to buy a mid '90's 4x4 s10 and want to throw some nice 33's on it whats the best way to get the height w/o losing stock drivability this truck will be dailey driver and see a little off road occasionally
#136 |
Registered Boozer
2in BL, 2"shackles and crank the tbars some trimming you can fit 33s ChrisinVT did it and his truck is outta commission at the moment but a sick truck. And he should put a new motor in it.
#137 |
what is the diff bewteen these lifts,
http://www.bds-suspension.com/kits/165H i see one has more parts then the other i would like to knwo which is better for a 04 crew cab before i purchase |
#138 |
Out of those two, you want the BDS kit. The Superlift 6 kit is an option as well. Both the SL and BDS are designed much better than the TM.
#139 |
one is 2grand the other 1grand why such a major price difference?
#140 |
One is built better than the other. You are much better off buying the BDS or SL. Save yo monies and do it once
#141 |
now what is the exact tire 31" x 10.50 is that the size you can go with the 5inch? an what rim size can those be mounted on
#142 |
I can vouch for the BDS kit. It is well worth the money. I have abused mine quite a bit and the kit is holding up fine. I wish I could say the same for the oem parts...
#143 |
I wanted to get a 2" suspension lift and a 2" body lift, along with 31"x10.50 tires on 15x8 rims. I was wonderin if there is anything that would make your tires not rub the frame when at full turn? like spacers?
#144 |
4x4 v6 blazer
You answered your own question |
#145 |
ok. thanks
#146 |
do you know wht size spacers?
#147 |
15x8 rims usually come with the right backspacing so they won't rub anyway. 4.5" backspacing is plenty enough to run 32's without rubbing. You could get away with more backspacing then that even. (6" is stock)
#148 |
ok, thanks
#149 |
Location: i live in Hendersonville nc User is: OffLine |
man the info really helps out when the person knows what they r talking about so thanks for the info know i can make a better choice on a lift kit for my 1994 s10
#150 |
I was wondering if you must do a sas to go more then 2" suspension lift. I would live to go 5" to fit 33/10.50 or 35/10.50, but it must be pa road leagal. Is there any kits that would be great for doing such a lift? And any sites for ball joints that can handle bein treated like a dirty w@&$?.. Just a little joke
