3 inch body lift on a 00 s10 - S-10 Forum
post #1 of 12 Old 07-18-2011, 11:06 AM Thread Starter
Countryboy94's Avatar
User is: Countryboy94 is offline
Ive heard yes you can make it work and no you cant. I was gonna get the pa 2 inch body lift. But my buddys dad just offered me a brand new 3 inch lift for a earliar model.. the 2 inch kit is 230 and he told me i could have his for 20. How hard is it to do this. What do i need besided the lift... Some who has done it please give me some info
post #2 of 12 Old 07-18-2011, 01:51 PM
Resident Post Whore
chasekerr23's Avatar
User is: chasekerr23 is offline
Re: 3 inch body lift on a 00 s10
I did a 3" BL on a first gen. Check out S10extremist.org if you want to find out more info on lifting or whatever. I've read that you can use the BL for the 1st gen pick-ups. But you'll have to make your bumper brackets.
$230, much less $200, is a rip-off. Go to 4wheelparts.com and order it from them. Look around for some coupon codes though. I didn't pay more than $100 for mine.
Squeaky: 85 S10 Blazer 4x4: 3" BL; 2" SL; 31x10.50x15 BFG A/T
Originally Posted by 96superflow View Post
Diesel you are like the Buddha to knowledge of all things offroad!
post #3 of 12 Old 07-18-2011, 02:25 PM
fatphatboy88's Avatar
User is: fatphatboy88 is offline
It can be made to work. You will need to raise the front bumper with 3" lift blocks also. And the rear bumper will need brackets made. Lower the lower fan shroud 3". Extended the fuel filler neck. Extended the ground in the middle of the firewall. Your battery cables might be too short, mine were barely long enough with 2" BL. Im just thinking of what all had to be done to my truck for the 2" body lift.
TommyRocket has a 3" body lift on his 98 truck. Ask him if there was anything special he had to do.
1999 S-10 Reg Cab Short Bed 4.3 3" AIM spindles, 2" Dick Cepek coils, 2" shackles, 2" body lift, Classic IIs, 31x10.50x15
Full Infinity Audio Kappa 462.9cfp and 62.9i Reference 1062w sub, 1300a and 475a amps
AD244 with Big 3
post #4 of 12 Old 07-18-2011, 02:26 PM
AD244 with Big 3
post #5 of 12 Old 07-18-2011, 06:02 PM Thread Starter
I dont wanna pass up a bl for 20 bucks if its not that hard to custom fabricate lol
post #6 of 12 Old 07-19-2011, 02:57 AM
For 20 bucks I wouldnt pass it up either. Id get it, install it and worry about the bumpers later.
AD244 with Big 3
post #7 of 12 Old 07-19-2011, 09:07 AM
It's 2WD!
TommyRocket's Avatar
User is: TommyRocket is offline
I just sent you a PM, but afterwards figured this could help someone out in the future so I'm posting it here too.
I've done a 2" on a friend's '97 4x4 Blazer and a 3" on my '98 2WD pickup. Your truck is a 4x4, right?
If it's a manual transmission, the shifter is going to hit the center console. Just cut out what it hits or make a new shifter. You will also need to unclip the clutch line from the lower part of the firewall to allow it to have enough slack.
If it's an automatic, keep an eye on the linkage as you lift the body up. I'm not sure if your truck has a shift cable or a mechanical linkage. If it is mechanical, you may want to disconnect it before you do the lift and then figure out if it has to be modified.
The front bumper can be lifted with blocks and is pretty easy. I cut out 2" lengths of thick walled tubing to raise the bumper on the Blazer. The rear bumper is more difficult. Easiest way to move it up would be to make new brackets out of some C-channel steel. I still have my rear bumper at stock height.
Get longer hoses for the filler neck. The neck might sit at a weird angle behind the fuel door after you extend it. You might have to use longer bolts and add washers between the bed and filler neck. I can send you pics to show you what I'm talking about.
If you are careful, the stock brake lines will stretch the 3 inches. Just make sure they are moving where they are coiled and don't have too much stress where they are bolted to the frame. It's easy to kink them and even easier if they are a little rusted.
Make sure any and all wires have slack in them. Disconnect the battery before you do the body lift. On the '97, we had to extend the ground cable to the battery. On my '98, the battery cables fit fine.
There is also a large ground wire that will probably need to be replaced with a longer one. It's a wide bare wire that's on the back of the engine. I found one in Jeg's that worked great. I didn't have to do this on the '97 4x4 2" lift or on my 2wd trucks 3" lift when it was a 4cylinder. I did have to do it once I swapped a 4.3 into my truck. I have the part number somewhere.
Also, the fan shroud will have to be modified. I just took the bottom half of mine off but you could cut it out or add spacers to it if you want to keep the lower half.
If you have the remote oil filter mount, you will also need to drop it or make longer lines for it.
Too many dimes...
post #8 of 12 Old 07-19-2011, 11:27 PM
Solid Axle MOD
Sonomanclature's Avatar
And there you go.
I'm waiting for the parts to do the same, and completely forgot about the oil filter BS. I tossed my fan shroud lower on my 1st gen never had any problems.
94 Sonoma Dana44/60 5.7L 5spd
06 Subaru Impreza
post #9 of 12 Old 07-22-2011, 11:59 PM
Bold as Love
Harry Canyon's Avatar
User is: Harry Canyon is offline
My blazer also has no lower fan shroud. No cooling problems to speak of, at low or high speeds.
1998 S10 4.3/Auto daily driver.
1984 S15 2.2 Diesel.
1988 S10 2.5 5-speed lowered 4/4.
post #10 of 12 Old 10-27-2011, 02:20 AM
User is: liftedhombre97 is offline
i did a 2inch on my 97 hombre and i had no problems with extanding anything i just put the bl on and thats it i did not raise my back bumper oh well would like to but no big deal....also when i took my lower shroud off i had over heating problems once i put it back my fan ate it up but no more over heating.....just my 2 cents
post #11 of 12 Old 04-03-2013, 08:10 PM
gocart's Avatar
User is: gocart is offline
What part number would I be lookin for if I could not get a sweet deal like 20 bucks mine is 2002 zr2 ext cab auto #102 or #103 and thanks for the info
gocart is offline
post #12 of 12 Old 04-03-2013, 09:23 PM
Solid Axle MOD
Buy what ever kit is for a first gen excab, then buy 4 more blocks for the front bumper.
06 Subaru Impreza
