2wd to 4wd conversion - S-10 Forum
Old 04-19-2007, 02:00 PM   #1
OK i've been thinkin about this for a while i've got a 1988 Chevy S-10 2wd 5-speed with a 2.5 4cyl. standard cab and i was hoping to be able to convert it to 4wd and im not totally sure about how to do this or if it is even possible so if anyone can help it would be appreciated.
Thanks Mike
Old 04-19-2007, 04:08 PM   #2
Registered Dreamer
bobbys10man's Avatar
Re: 2wd to 4wd conversion
Thanks Mike
search around there are many threads here about that...
I think it would be cheaper to just trade in your truck on a 4x4...
Old 04-19-2007, 04:39 PM   #3
Lifted Member
Rinkrat456's Avatar
It would be cheaper to take your body off, and put it on a 4x4 frame. The only real economical way to make a 2wd 4x4, is to engineer your own suspension and do a solid axle conversion. It's how I'm going about making my 2wd Sonoma into a 4x4, same with many solid axle swappers unhappy with 2wd.
Old 04-19-2007, 04:43 PM   #4
No more switches
CustomS10's Avatar
2wd and 4wd have different frames.
Old 04-19-2007, 06:08 PM   #5
cool to the tool
shiftit's Avatar
i got an 89 4x4 s10 blazer with a rebuilt 4.3 ill sell for $1000. you will have way more than that in parts when youre done.
Old 04-19-2007, 08:28 PM   #6
Registered Dreamer
My point exactly
Old 04-19-2007, 09:46 PM   #7
I hate my truck.
monkeymouse's Avatar
Like already stated, if the body and everything else is mechanically sound; do a SFA swap.
Old 04-20-2007, 02:56 AM   #8
On tha grind
Snafu Pimp's Avatar
2wd s10's are optimal for a sfa swap because the spring pockets are already there for coils!
Old 05-11-2007, 12:16 PM   #9
fordktpjoe's Avatar
Please excuse an ignorant noob, but what is an SFA swap?
I have a 2WD extended cab with a really really sick, but still running 2.8L (200,000 miles) and need (read that "want") a 4X4, but because of children have to keep the extended cab. Have access to several regular cab 4X4's but just found out here that that is a no-go.
We've had this truck since almost new and dearly love it, and the body is perfect, although it could use paint. You guys reckon I oughta just keep hunting for a wrecked or rusty extended cab 4X4, and then just swap the cab and bed?
this is a 1992....any ideas what years will work?
Sorry this was so long and thanks in advance for any help!
Joe
Old 05-11-2007, 01:42 PM   #10
I hate my truck.
SFA is strait front axle.
Old 05-11-2007, 03:42 PM   #11
cool to the tool
shiftit's Avatar
SFA = Solid Front Axle, same idea though
SAS = Solid Axle Swap
not to be a dick just for reference
Old 05-11-2007, 06:31 PM   #12
gusdaman's Avatar
Rink,
Are you using the spring pockets to mount coils for your front axle??
GUS
Old 05-11-2007, 11:59 PM   #13
Registered dumbass
NC4x4's Avatar
Spring pockets? Never heard of those. Did you mean Spring buckets or something?
