steering shaky
Old 10-01-2009, 01:25 AM   #1
steering shaky
alright, so I recently changed out my steering set up. I went from a stock grand cherokee pitman arm to 4-8 drop pitman arm for a grand cherokee. Now if i hit enough little bumps i the road it the steering wheel starts moving left to right which makes the whole truck shake. I cannot figure out what it is. This happend to my friends dodge ram but it was because his traction bar bracket was cracked. Do i need a wheel alignment? i do have some play of the wheel to start.
thanks
Old 10-01-2009, 04:00 AM   #2
Banned
Re: steering shaky
sounds like the death wobble. my buddies jeep did that and no shop could ever figure it out... i kept telling him the bushings in his upper/lower arms were stretched to max (put 150 coils in) and wore out... sure enough, new bushings fixed it.... on yours, dont know if thats the case... what springs and arms are you running?
Old 10-01-2009, 08:56 AM   #3
pjg1173's Avatar
Re: steering shaky
what type of suspension are you using in the front coils or leafs? Do you have a steering stabilizer? do you have a panhard bar with good bushings? it you are using the stock stabilzer from the D30 they are prone to going bad and will not absorb the "bump" in the steering effectivly. also if using the stock steering setup from the D30 you changed the angle of the steering which may cause an alignment problem.
Old 10-05-2009, 12:54 AM   #4
Re: steering shaky
I have the stock steering stabilizer i believe, im going to change that out and then. I found out my wheel bearing is bad so i bought a new hub, i just have to put that on. For suspension its stock s10 springs, that are starting to sag now. there is no pan hard bar, I was thinking about getting one but i dont know if it would be wort getting
Old 10-05-2009, 07:30 AM   #5
BillaksBlazer's Avatar
Re: steering shaky
a worn bearing can cause the death wobble so that might be the cure. Also a steering stablizer shoudnt be used to cure a problem like that, it should be just to make draving more comfortable.
Old 10-05-2009, 10:53 AM   #6
Slightly Over Built
DieselS10's Avatar
Re: steering shaky
X2, anything loose or worn in the steering or front end can contribute.
Old 10-05-2009, 03:56 PM   #7
pjg1173's Avatar
Re: steering shaky
death wobble is usually assosicated with linked suspensions. I know mine would lean horibly in curves and while turning until i installed a panhard bar. I have also had a truck that would get unstable while breaking or driving on uneven pavement due to the shackles being too long with out a center support in them.
Old 10-08-2009, 12:36 AM   #8
Re: steering shaky
im going to try to put a pan hard bar on. All the shaky started after I purchased a drop Pittman arm haha. My power steering box leaks and i think it maybe worn out so im going to replace that also and get a new steerig stabilizer. The tshaking is only if one front tire hits uneven surface and the other doesnt, and this doesnt happen all the time either only after the right bumps
Old 10-08-2009, 10:35 AM   #9
Slightly Over Built
DieselS10's Avatar
Re: steering shaky
Be sure to make your panhard bar the same length as your drag-link and mount it at the same angle.
Old 10-08-2009, 02:00 PM   #10
Re: steering shaky
you think the stock one from a jeep wrangler. like the one that originally came on the axle would work? If I made a bracket on the frame that is
Old 10-08-2009, 10:57 PM   #11
Slightly Over Built
DieselS10's Avatar
Re: steering shaky
I'm not familiar with them ( i aviod Heeps!), but I'm sure that it could be made to work.
Is it the same length as your drag-link?
Old 10-09-2009, 04:10 AM   #12
Re: steering shaky
yes, I would believe considering I have the stock drag link. I founded out my ptiman arm was loose, so that helped most of te shaking but i believe that i just need an alignment now. I 99% sure i have toe on my wheels. I just picked up a set of 35x12.5 thornbirds from a buddy so im going to wait to put those on
