Sas Info
Old 06-09-2009, 10:08 PM   #101
96superflow's Avatar
Re: Sas Info
Cool thanks 4wd Joey. Now i just need to find a set of gears for it.......
Old 06-09-2009, 10:27 PM   #102
Site Sponsor
4wdjoey's Avatar
Re: Sas Info
what ratio do you need?
Old 06-09-2009, 10:28 PM   #103
Re: Sas Info
lol i think we are hopin back and forth on threads, i just checked your vendor thread out and put it over there. 4.10s plz.
Old 06-09-2009, 10:31 PM   #104
wrekd's Avatar
Re: Sas Info
Mkae sure its not a 7.625" rear. I dont know exactly what year they started using them, but I know it was around that time. The 7.625 has 28 spline axles and the 7.5 has 26 splines.
The only way you could tell is by pulling out a shaft and counting the splines (I Think).
Old 06-09-2009, 10:37 PM   #105
Site Sponsor
4wdjoey's Avatar
Re: Sas Info
i'm not sure about that one...
Old 06-09-2009, 10:40 PM   #106
Re: Sas Info
Old 06-09-2009, 10:47 PM   #107
wrekd's Avatar
Re: Sas Info
Did you pull a rear out of a 92 and put it in your 96???
Old 06-09-2009, 10:53 PM   #108
Re: Sas Info
yeah... long story but i have my reason why i did.....
Old 06-09-2009, 11:00 PM   #109
wrekd's Avatar
Re: Sas Info
I would check into it before you go buying parts for it. Better to be safe then sorry.
Old 06-09-2009, 11:02 PM   #110
Re: Sas Info
oh yeah, im starting to research it right now....
Old 06-09-2009, 11:05 PM   #111
Re: Sas Info
accuautoparts.com just said it was a 7.6... Anyone else know about these??? Ill be clear too, the axle is out of a 1992 4dr 4wd blazer with 3.73 gears and limited slip. Im trying to find the ring gear size....
Old 06-09-2009, 11:06 PM   #112
Site Sponsor
4wdjoey's Avatar
Re: Sas Info
looks like the ring and pinions are interchangeable. i don't even have any gears for the 7.625. they also share the same master install kit.
Old 06-09-2009, 11:08 PM   #113
wrekd's Avatar
Re: Sas Info
Yeah some people call it a 7.6, 7 5/8", 7.625, etc.
Old 06-09-2009, 11:09 PM   #114
Baggey22's Avatar
Re: Sas Info
If you're gonna put money into the rear axle you're better off just buying an 8.8 that already has 4.10. That's what I did, mine has the LS too.
PLUS you can get rear disk brakes, and getting the e-brake to work is REAL easy.
Old 06-09-2009, 11:12 PM   #115
wrekd's Avatar
Re: Sas Info
Its been a while since i read up on the differences, but I think to run a 7.5 ring gear you have to change the carrier. And that would require getting 26 spline axle shafts to match.
I could be wrong though. Like I said, its been awhile.
Old 06-09-2009, 11:12 PM   #116
Re: Sas Info
I might do that, trouble im having is finding one of those damn things around here........... I deff leaving all of my options open. Once i get up some funds, i will probably hit up the local pnp to see what they have. Where do you find the id tag on the 8.8 for the gears?
Old 06-09-2009, 11:13 PM   #117
wrekd's Avatar
Re: Sas Info
^^^ Thats what Id do.
Old 06-09-2009, 11:13 PM   #118
Baggey22's Avatar
Re: Sas Info
There's a small tag that SHOULD be held on by one of the diff cover bolts. On that tag it'll tell you the gear ratio AND if it's limited slip or open.
You can see it at the "2:00" bolt
This one you can see the bottom row says "3L55" that means it's got 3.55 gears and limited slip.
Old 06-09-2009, 11:17 PM   #119
Re: Sas Info
Alright, im not going to close off any doors yet. I did check tonight and after all that damn work on the drum brakes, the damn parking brake doesnt work!!! i was kinda worried about swappin in the 8.8 and having trouble hooking up the parking brake.... Its required in NC for inspections.....
Old 06-09-2009, 11:24 PM   #120
Baggey22's Avatar
Re: Sas Info
Read this:
http://forums.s-series.org/viewtopic.php?t=51625
Old 06-09-2009, 11:34 PM   #121
wrekd's Avatar
Re: Sas Info
Good read
Old 06-10-2009, 08:41 AM   #122
Re: Sas Info
Thanks Baggey, That link was awesome. Now im really considering the 8.8 swap into my blazer. How common are the ones with 4.10s and should i look for the smaller engine with those gears?
Old 06-10-2009, 08:41 AM   #123
Re: Sas Info
dont worry about the parking brake, mine was super easy to hook up. It was almost a direct install. And for the price of gears you could buy an 8.8.
Old 06-10-2009, 08:46 AM   #124
Re: Sas Info
Yeah that and i dont think the 10bolt could stand up to the abuse my right foot puts it through.
Old 06-10-2009, 08:52 AM   #125
Re: Sas Info
if its the 28 spline version it probably would. I was bouncing with heavy 33's and a locker and it never gave me any problems. So if you cant find an 8.8 you could keep it.
Old 06-10-2009, 09:29 AM   #126
Baggey22's Avatar
Re: Sas Info
Getting one with 4.10 around here is KINDA common. I can think of two in my area last time I checked. It's getting one that is 4.10 and limited slip that can be a little bit of an issue.
Old 06-10-2009, 11:31 AM   #127
Site Sponsor
4wdjoey's Avatar
Re: Sas Info
Update on your 92 S10 Axle:
Between the years, the carriers changed and like Wrekd stated they were identified as 7.5 and 7.625 but the ring gears are the same.
Old 06-10-2009, 10:15 PM   #128
Re: Sas Info
Ah alright. cool. I appreciate the help guys. Im deff looking into the 8.8 swap. Im not worried about if its got limited slip or not cause i would probably just throw an aussie locker in it. Im going to be working a few side jobs with a buddy of mine so that i can come up with some more funds for the project, but that means the work is going to be put on hold, i am deff keeping an eye out for one...
Old 06-14-2009, 09:26 PM   #129
Re: Sas Info
Did a lil bit tonight. Just cleaned up the d30, painted it and mounted the inspection tires and wheels on it. no pics, but it came out damn good.... Might also have found an 8.8. I drove by a local scrap yard and they had a 4 dr newer body type sitting there, i drove by it again, but couldn't tell if it had discs brakes or not. We will find out tomorrow, hopefully before they crush it.......
Old 06-14-2009, 09:41 PM   #130
Baggey22's Avatar
Re: Sas Info
If it's newer than 1996 it'll have disk brakes
Old 06-15-2009, 10:24 PM   #131
Re: Sas Info
Well donno about the axle. They were planning on crushing the car, and the guy still wanted 200 bucks for it, although it had 3.73 gears. I wasn't too worried about it. Real quick thou, how long of shocks should i be looking at running, i gotta get hoops from 4wdjoey in either 12 or 14". Types would be awesome too. Thanks guys.
Old 06-16-2009, 10:17 PM   #132
Re: Sas Info
Did more than whats in the picture tonight, but it got to dark to see.
Old 06-16-2009, 10:52 PM   #133
wrekd's Avatar
Re: Sas Info
Lookin good!!
Old 06-17-2009, 10:01 PM   #134
Re: Sas Info
Tore into her a lil more tonight. I only had about an hour to work on it since my dad needed help taping up a car for paint tomorrow morning. But thats basically one side done.
My pile of IFS stuff im saving for the 2 other s10s we have...
HP D30 all cleaned up
Hopefully i can start putting the axle back in sometime this weekend. We shall see. Doing all the work outside so its all weather permitting.....
Old 06-17-2009, 10:07 PM   #135
MTchevyS10's Avatar
Re: Sas Info
Looking good, buddy.
Take your time and get that sucker in there!
Old 06-17-2009, 10:16 PM   #136
nyteRyda's Avatar
Re: Sas Info
[Weather Permitting]
I know how that is, its my problem right now as well
Old 06-18-2009, 05:04 AM   #137
wrekd's Avatar
Re: Sas Info
I hear ya. This rain is starting to piss me off already. Cant do shit.
Old 06-18-2009, 09:13 AM   #138
Fvck New Jersey
Tim99Zr2's Avatar
Re: Sas Info
yepp! i cant even go to work out tractor keeps sliding off the gas lines!
supposed to rain all week end i guess tooo.
Old 06-18-2009, 12:07 PM   #139
nyteRyda's Avatar
Re: Sas Info
Yeah same here, but we just got a break in the rain, I have my buddy coming down to finish welding up my rear hangars, then its supposed to be sunny the first half the day tomorrow so I should have this f*n thing finished by then...I want it supporting its own weight by tomorrow
Old 06-19-2009, 10:28 PM   #140
Re: Sas Info
Well guys, i finished up riping out all the ifs bull crap tonight. got too dark to take pics, and its def been a slow process but i should have all this weekend to play with it. Hopefully have the axle in by sunday evening. i will be taking pics tomorrow and keeping ya'll updated!!!
Old 06-20-2009, 11:26 AM   #141
Re: Sas Info
Here are some pics of what i finished pulling last night.
Now with the D30 sitting under her.
Hopefully i can have the crossmember burned in by this afternoon. Ill keep ya'll updated!!!
Old 06-20-2009, 08:26 PM   #142
Re: Sas Info
GOT THE CROSSMEMBER BURNED IN!!!!! HELL YEA im excited. I cant wait to finish this thing up. I wont be able to attach the rear just yet cause of the metal place being closed today. But thats alright with me. Now im exhausted and need to rest. Im sure ill have questions soon!!! Here are some pics.
Old 06-21-2009, 01:11 AM   #143
Fvck New Jersey
Tim99Zr2's Avatar
Re: Sas Info
awesome man, its lookin good!
Old 06-21-2009, 12:09 PM   #144
Re: Sas Info
Thanks!! Im thinking about running the heep wheels, they actually dont look too bad, but im gonna need to space them out some.....
Old 06-21-2009, 01:35 PM   #145
Re: Sas Info
Heres a few more pics. Got some with my 16 year old (minus 13 years)nephew that will be his Vehicle!!!!!
Old 06-22-2009, 06:52 PM   #146
Re: Sas Info
Hey guys, i need some help. I have found an 8.8 rearend and i believe with 4.10 gears. He wants 200 for it, and i think im willing to pay that much if in fact it has those gears. Any input would be awesome from ya'll. and just so you know, im have a tough as hell time tryin to find one of these complete. Let me know thanks...
Old 06-22-2009, 07:32 PM   #147
GAVE his truck to 96super
bubbagt57's Avatar
Re: Sas Info
what is it out of?
Old 06-22-2009, 08:19 PM   #148
Re: Sas Info
Explorer
Old 06-22-2009, 08:57 PM   #149
Re: Sas Info
if thats the gears that you want to run id say 150 and if your willing to you could go 200. They go for 125 around me with what ever ratio.
Old 06-22-2009, 09:18 PM   #150
Re: Sas Info
We will find out. The guy called me back and said he had a bunch of them and i told him how to check the ratio, so he will call me back some time. We will see. It seems like they are all going for around 200, so ill see what i can talk him down too.
Page generated in 0.66406 seconds with 31 queries
[Output: 208.93 Kb. compressed to 190.07 Kb. by saving 18.86 Kb. (9.03%)]
