proportioning valve? - S-10 Forum
post #1 of 11 Old 08-14-2010, 01:29 PM Thread Starter
BuzzerPB's Avatar
User is: BuzzerPB is offline
ok I'm still running my stock Brake proportioning valve, with the ABS still hooked up.... got the front end ripped apart and ditching the ABS unit, no need for it...
question i have is, the stock valve won't work unless I t the front brakes together.
I don't wanna do this, due to the front being the Duel pistions from a 76 F250 D44
and the rear are now disk as well
so in need of a proportioning valve with 2 inputs and 3 Out puts(2 front-1 rear)... andy ideas?
Thanks!
93' 4dr Jimmy 4.3 Vortec SAS
http://www.s10forum.com/forum/f221/93-jimmyd-397741/
(D60/60--5:38's)
BuzzerPB is offline
post #2 of 11 Old 08-14-2010, 09:04 PM
User is: contact420 is offline
Re: proportioning valve?
I dont think Its gonne matter I have a my stock matser and prop valve. The front brakes go to the frame and splite into a T the rear goes to the rear diff and splits into a T and I am doing a dual piston upgrade and I'm not expecting any problems. Not even thinking of running two front lines from the proportioning valve. I dont think its gonna take that much more fluid to operate the dual piston calipers compared to the sotck calipers. I might be wrong but I don't know. I will be able to say more after I start driving it again, more then a couple of blocks.
1995 Blazer HPD30 / 8.8 w/ 4.10's sittin on 33s.
post #3 of 11 Old 08-14-2010, 09:18 PM Thread Starter
BuzzerPB's Avatar
well with having ABS, each front ran straight to the box, might just T them.. but will check out a 70's ford 4x.. I do know they have a 2/3 combo valve..... but was hoping for one that handled rear disk as well.....
(D60/60--5:38's)
BuzzerPB is offline
post #4 of 11 Old 08-14-2010, 10:44 PM
BillaksBlazer's Avatar
User is: BillaksBlazer is offline
check classic chevy out. they are more for 55-57 chevys but i know they have a few different options for brake upgrades.
2000 4 door. SAS'd with 4.88's dual lockers and 36's
Build Thread http://www.s10forum.com/forum/f221/2...roject-386410/
post #5 of 11 Old 08-14-2010, 10:57 PM
on my 95 and 96 blazer and s10 the abs Has 2 lines running in and 3 out. the prop valve has 2in/2out. what year is you truck. Im interested now. how bout a pic?
post #6 of 11 Old 08-14-2010, 11:41 PM Thread Starter
BuzzerPB's Avatar
sounds as if ours are the same.(stock) in the next week I'll hit up a local junk yard @ some full size rigs, but belive the F250 4x is the one I'm looking for 2in/3 out
(D60/60--5:38's)
BuzzerPB is offline
post #7 of 11 Old 08-15-2010, 02:28 PM
if you find one with 2 in 3 out let me know and post a pic I might swap oto it since I am putting dual piston calipers on my truck. Not an F250 D44 but dual piston from a WJ.
post #8 of 11 Old 08-18-2010, 05:08 PM Thread Starter
BuzzerPB's Avatar
heres the one i got.... outta a 3/4tons Suburban 80's model (located on front cross member/by bottom of the fan)
(D60/60--5:38's)
BuzzerPB is offline
post #9 of 11 Old 08-18-2010, 07:16 PM
NM_Wanderer's Avatar
User is: NM_Wanderer is offline
Let us know how it works out. I am currently just using a tee set up for the front brakes and don't have too many issues.
2004 4dr Blazer 4.3 V6. HPD30/Ford 8.8 with 4.10's locked front and rear. Hitch cross-member, Rancho 44044 springs, 33s.
Build Thread http://www.s10forum.com/forum/f221/4...roject-436226/
PhotoBucket http://s934.photobucket.com/albums/a...zer%20Project/
post #10 of 11 Old 08-18-2010, 09:11 PM Thread Starter
BuzzerPB's Avatar
I snached up one of those from the junk yard also!
(D60/60--5:38's)
BuzzerPB is offline
post #11 of 11 Old 08-23-2010, 11:17 PM
MTchevyS10's Avatar
User is: MTchevyS10 is offline
When I put in the MC from the Suburban, I just tee'd the lines because they had drum brakes in the rear, so I knew there would be no issue. With disk brakes like you have, I'd just check around for some small aftermarket valves and go from there.
I can't seem to remember much of what folks have been running, although oddly enough I do remember a Corvette valve being used at some point (probably for massive tires).
'97 Stepside: D44+Aussie/9"+Detroit
'07 Solstice GXP: 2.0L Turbo
