LinkBack (2) | Thread Tools |
#401 |
Re: Project: Fix to busted CV shafts & wheel bearings! 56k no no
i have a regular s-10......i may just go 2 inch BL and crank..and 31's for summer..hell i dunno...right now just gettin ideas...before i do one thing..then regret it and have to start over to do another..even though the BL and sas go hand in hand
#402 |
I have a NON Z S10 with 2" body lift and 1" shackle lift/Tbars cranked 1" and I have 31s that BARELY rub at full lock and I have minimal trimming. So if you did maybe 1.5-2" shackle/Tbar lift and a good amount of trimming you'd be okay I think
#403 |
hmm..maybe body lift...and the shackles..and some 31's...with nice aggressive lookin tires...
#404 |
Just get radial mud tires and you'll be all set, good on the road and look good too
#405 |
Fvck New Jersey
baggey, you running 33s on your sas too?
i think trucks with a SAS look so much more aggressive anyway. SAS FTMFW! haha, im all for them now! but if your set on 33s or 32s i think you'll either have to SAS or get a 5-6 IFS lift |
#406 |
Tim read my sig
#407 |
maybe i can chill this summer..and if i get a house with my own garage..and build a sas next winter....if i went with 2 inch body...torsion crank and shackels...what is the widdest 31 i can run?
#408 |
Fvck New Jersey
cant answer that. haha. i dont know my tires and wheels too well. like i already said.. might as well just keep stock wheels and a 31-10.5 if you are planning on doing a SAS soon? baggey - i see now, thanks1! |
#409 |
I don't think 31s come much wider than like 10.5 or 11 inches wide.
Heres mine with 31/10.5/R15 ![]() ![]() |
#410 |
i found them on ebay 31x12.5x15 what about a lift like this.
.and a 2 inch body lift... |
#411 |
Say NO to new Tbar keys. They do more harm than good. You REALLY shouldn't go over 1.5 inches with a Tbar crank, it puts the CV axles at a bad angle for breakage
#412 |
Fvck New Jersey
baggey, picture whore!!
#413 |
I learned from the best
#414 |
Fvck New Jersey
haha. so i guess they had to custom make my shocks.. and my truck runs out of inspection in 24.25hours.. and i dont get my shocks til tuesday at least.
#415 |
well..maybe i will stick with a one inch crank to level the truck out...a 2 inch body lift..and some 31's with chrome wheels....how do u crank the t-bars correctly?
#416 |
should have kept the crappy ones just to pass
#417 |
#418 |
Fvck New Jersey
i thought i was going to get my new ones today, so i left my olds ones at the store.. ![]() |
#419 |
What about rear shocks?
#420 |
wow..nice site...aight im outta here for now..thanks for info and i will be watchin this project till finished!
#421 |
Fvck New Jersey
stock for now.. althou they aint doing shit alright, later zach, you'll be waiting awhile!! |
#422 |
I don't know if there is such a thing as a DONE SAS
#423 |
Fvck New Jersey
true that.. haha
#424 |
3 Leaf Fab
all this talk about tires, i ran 32's with stock suspension. i would have easily ran 35's with the same setup, and if i wasnt worried about turning or breaking the rear axle in half, i may have considered running my 38's with no lift too. its all about perspective...
#425 |
Registered Asshole
Location: Moscow, PA / Mansfield, PA User is: OffLine |
#426 |
Fvck New Jersey
than most? i think all..
so i guess my back up light sensor is the expensive one!! GRR, i hate inspections |
#427 |
Well it is nice that people know when you're backing up
#428 |
Registered Asshole
#429 |
ive been watching u do the buildup on this thread, and great job, your truck looks great. just a ?, how much lift did you get. also the only thing i dont like so much is your front spring mounts, it just looks bulky, is it possible to have made it smaller or did it have to hang down that far so springs cleared. it can be covered up with a nice sheet of plished diomond plat for cheap though hehe. great truck though, not trying to bash it just wondering.
Joe |
#430 |
Fvck New Jersey
kinda like that pole at sheetz huh? well i lucked out, checked my bulbs and they were both blown out.. ![]() and joe, it could have been made "slimmer" to tuck into the frame more, and i coulf of cut notches out in my frame for it. but this way is the most common / simplest way to do it. its really not that bad in person IMO. and i may make a skid plate from my bumper to it. and i think i got about 5-7" of lift. dont know exaclty off the top of my head. i think im 8-9" over a stock Z. |
#431 |
3 Leaf Fab
one thing to consider about the front crossmember, usually if you run it up into the frame, it has a tendency to make the springs sit at an angle, and can play havoc on you when you go to set the pinion angle and or steering linkage. the one that i have designed right now for my kit drops it 5.5"-6" off the bottom of the frame, and buy doing that it makes the spring almost flat. though, i have designed mine to look good too, and it gives room for a winch below the core support, but you get my drift.
#432 |
Fvck New Jersey
yea, my spring bolt holes are like 5.5 inches below the frame
baggey, if you could, could you get me quite a few pics of that cross over set up your going with, i think im going to try to make something on my own pics of it mounted on the knuckle too please! |
#433 |
I'll get on that as soon as I can Tim. I MAY have to work tonight because people in my theatre are slackers, but I'll do what I can. I'll get you the pictures by Sunday at the latest.
#434 |
Fvck New Jersey
kk, cause if i can make it, i might as well. hah thanks man
#435 |
Registered Asshole
i'm pretty sure you'll need some flattop knuckles to do this. check on paragon forum... i know i've seen a few sets pop up there.
edit... unless theres a way to make your own... which i've never seen it done Last edited by crazy91s10 : 01-31-2008 at 11:26 PM. |
#436 |
Fvck New Jersey
ugh, then i get to drive 4 hours to get them!!!
i can weld, i dont NEED anything. bish |
#437 |
Registered Asshole
#438 |
Fvck New Jersey
haha, i did a quick look on that site, couldnt find anything..
that reminds me, i need to refresh my mind on welding cast steel. thanks B! maybe ill go to my old school tomorrow... hmmm with a non inspected truck ![]() |
#439 |
3 Leaf Fab
cast steel welds like mild. cast iron on the other hand...
the knuckle is steel. |
#440 |
Fvck New Jersey
i should know how this works.. seeing i have a degree in welding, but i forget stuff
i might as well fab something up then |
#441 |
3 Leaf Fab
#442 |
Fvck New Jersey
#443 |
Fvck New Jersey
ok donahue, i just scored some xj springs out of a 99' to try on my truck. dunno if i want to try that pack or mix and match with my s10 and fullsize springs (if i even can)
what ya think? anyone? |
#444 |
3 Leaf Fab
#445 |
Fvck New Jersey
could i just drill i new hole in it? or would that not be a good idea?
#446 |
3 Leaf Fab
#447 |
Fvck New Jersey
front, i mainly wanted the main leaf son of a bitch |
#448 |
Maybe it would help your truck if you took the packs you already have and get them rearched by a professional. Get them even so the truck will sit level. Also have you checked your shackle mounts? Maybe one of them shifted or something
#449 |
3 Leaf Fab
#450 |
I'm putting my axle as far forward as I can, cause don't forget your axle moves back when you flex.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f221/project-fix-to-busted-cv-shafts-and-wheel-bearings-56k-no-no-329989/
| ZR2 USA -> coupld pics | This thread | Refback | 01-14-2008 11:59 PM | |
| Xmas vacation plans? | This thread | Pingback | 01-03-2008 05:37 AM | |
