Project: Fix to busted CV shafts & wheel bearings! 56k no no
LinkBack (2) Thread Tools
Old 01-16-2008, 01:39 PM   #251
Sponsoring Amsoil Dealer!
poriggity's Avatar
Re: Project: Fix to busted CV shafts & wheel bearings! 56k no no
Don,
what T case do you have? My S10 has an NP207 with a slip yoke.. I am thinking about throwing in the front half of a NP231C and doing a D300 flipped and bolted to that for a doubler.
Scott
Old 01-16-2008, 01:42 PM   #252
3 Leaf Fab
Donahue's Avatar
Quote: Originally Posted by poriggity
Don,
Scott
i have a 231/241 doubler. i assume you are talking about d&d's doubler, thats what i have. if you run the 300 behind it, you have to flip the first case to clear the driveshaft. but its a common enough swap and you can find all you need to know on the pirate threads.
Old 01-16-2008, 01:48 PM   #253
poriggity's Avatar
If I do the D300 doubler, I will either use the doubler kit from D&D, or madrooster off road, and I will get the flip kit from D&D for the D300...
Scott
Old 01-16-2008, 01:54 PM   #254
Fvck New Jersey
Tim99Zr2's Avatar
ugh. will i be able to get a yoke like yours and put it on, i imangine ill have to get it drilled or something. ive read a lil on it
Old 01-16-2008, 01:54 PM   #255
3 Leaf Fab
Donahue's Avatar
Scott
i have the d&d, and i like it. i dont know anything about other kits, but d&d is very good quality and i will vouch for it. i havent run it yet, but i like the ways its made.
Old 01-16-2008, 01:56 PM   #256
3 Leaf Fab
Donahue's Avatar
you might have to change the hole output shaft, and if your doing that you might aswell just put a 231 in it that already has the fixed yoke and the manual shift.
one more thing, count the mounting bolts while you are at it. i want to know if it is 5 or 6
Old 01-16-2008, 02:03 PM   #257
Fvck New Jersey
Tim99Zr2's Avatar
fvck didnt want to put a new tcase in.. oh well its got to be done.
ill prob look into it this weekend for you don
good thing im gettin a second job next month haha
Old 01-16-2008, 02:13 PM   #258
3 Leaf Fab
Donahue's Avatar
ive got a few, too bad you werent a little closer.
Old 01-16-2008, 02:17 PM   #259
Fvck New Jersey
Tim99Zr2's Avatar
yea for real.. maybe ill just buy a new tranny while im at it.. i want a stick
edit. just found a cast iron tcase out of a 76 blazer... input on it?
Old 01-16-2008, 02:20 PM   #260
3 Leaf Fab
Donahue's Avatar
keep looking. its either a 203 or a 205 and its on the wrong side.
Old 01-16-2008, 02:21 PM   #261
Fvck New Jersey
Tim99Zr2's Avatar
shit.. haha. just thought i'd ask its for 25$. you know a quick list of ones i can use? or should i just get a 231?
Old 01-16-2008, 02:23 PM   #262
Fvck New Jersey
Tim99Zr2's Avatar
85 chev 4spd trans and tcase for 500 obo.
but its passs side drop too?
Old 01-16-2008, 02:25 PM   #263
3 Leaf Fab
Donahue's Avatar
yeah, thats a sm465/205 its a good combo but any full size older than 88 will be pass drop. and $200 is too much for that combo let alone $500
Old 01-16-2008, 02:27 PM   #264
Fvck New Jersey
Tim99Zr2's Avatar
son of a..... haha.
what is a good case to look into getting?.
Old 01-16-2008, 02:34 PM   #265
3 Leaf Fab
Donahue's Avatar
son of a..... haha.
if you have a 5 bolt, then get a 231c. if you have a 6 bolt (ive been told 98 and later do) then get a 241c
Old 01-16-2008, 02:35 PM   #266
Fvck New Jersey
Tim99Zr2's Avatar
hmm. ok thanks don!
Old 01-16-2008, 02:36 PM   #267
Fvck New Jersey
Tim99Zr2's Avatar
are the bolt holes where it mounts to the trans?
Old 01-16-2008, 02:42 PM   #268
3 Leaf Fab
Donahue's Avatar
not where the adapter mounts to the trans, but where the t-case mounts to the adapter. one thing, you will need to get the shifter for the correct t-case. you will also need a different rear driveline for the 241, it has a 32 spline rear slip yoke verse 27 spline that the s10 case has.
Old 01-16-2008, 02:45 PM   #269
3 Leaf Fab
Donahue's Avatar
if you get a 241 from a 1/2 ton, it is likely to have the same u-joint size and all you would need is the female end of the slip yoke, and you could probably put it on your current driveline.
Old 01-16-2008, 02:46 PM   #270
Fvck New Jersey
Tim99Zr2's Avatar
alrighty, ill check that out. and..
holy shit.. now i need a new slip yoke for the rear too
and the shifter shouldnt be too hard to get?. it may even come with the tcase?
i think i might try to figure something out for the front. haha or have a 2wd sfa truck
but time for work in 15 min, so i duno if ill reply again. thanks don!
Old 01-16-2008, 02:51 PM   #271
3 Leaf Fab
Donahue's Avatar
you could see what NC did, i believe he also has the same setup as you do, and he claims to have good flex.
Old 01-16-2008, 03:49 PM   #272
3 Leaf Fab
Donahue's Avatar
http://www.s10extremist.org/forums/v...ic.php?t=15256
Old 01-16-2008, 07:07 PM   #273
Fvck New Jersey
Tim99Zr2's Avatar
im thinking i can make a bracket or something to keep the front shaft from sliding off the t-case.. ill have to search around, and thanks for the link donahue, ill check that out
Old 01-16-2008, 07:08 PM   #274
Fvck New Jersey
Tim99Zr2's Avatar
hopefully nc will chime in before i get off of work with some info!
Old 01-16-2008, 07:39 PM   #275
Eroq's Avatar
Limit straps... or chains whichever you prefer.. gonna be putting them on mine when i 4link it
Old 01-16-2008, 09:25 PM   #276
Registered dumbass
NC4x4's Avatar
The rear is just a longer driveshaft with the same slip yoke.
At full droop, the slip yoke won't come off the output shaft.
On the front, for now anyhow, I had access to a slip yoke that had a been drilled out for a set screw. I ground a "V" into the splines of the front output shaft, put the set screw into the slip yoke, and tightened it down enough to where the driveshaft would pull apart before it ever began attempting to pull off the output shaft.
If any of that doesn't make sense, just let me know.
Old 01-16-2008, 09:35 PM   #277
Registered dumbass
NC4x4's Avatar
There isn't much "claiming" to it. I've known for quite a long time just how well the setup flexes.
Old 01-16-2008, 11:09 PM   #278
Fvck New Jersey
Tim99Zr2's Avatar
AWESOME nc. i completely understand that. ill have to do that.
what size screw? did you groove the whole way around the shaft? if i could get more info on that please. and get i get a pic of your tranny cross member? for the third time.
thanks
Old 01-16-2008, 11:16 PM   #279
Fvck New Jersey
Tim99Zr2's Avatar
so i think im back in the game for a square DS. on my way home from work i stopped on the bridge and left my truck crawling in gear and seen that my yoke on my front diff didnt spin... since baggey didnt tell me!
Old 01-16-2008, 11:20 PM   #280
Baggey22's Avatar
I didn't think you needed me to tell you anymore since Donahue told you last night that it wouldn't spin with the vacuum disconnected.
Old 01-16-2008, 11:22 PM   #281
Fvck New Jersey
Tim99Zr2's Avatar
oh, well i found out anyway.. just wanted to look
Old 01-17-2008, 01:07 AM   #282
Registered dumbass
NC4x4's Avatar
thanks
I'll see what I can do this week. It's suppose to snow quite a bit (so they say ) tonight and tomorrow, so I don't know if I will get to it right away but I'll see what I can do.
As far as the set screw, it is maybe 5/16ths or 3/8s thick, I guess. You don't have to grind all the way around the shaft because the "V" should be deep enough (relative to the set screw, not anywhere near 1/4 into the shaft at all haha) to where the set screw will not allow the slip yoke to travel forwards or sideways for that matter. Only issue I may could see is if the front square driveshaft gets caught on something, it may cause the set screw to want to move on the output shaft, but that would probably be quite rare if you notched well enough and tightened the set screw well enough (with anti-seize of course).
Old 01-17-2008, 01:13 AM   #283
Fvck New Jersey
Tim99Zr2's Avatar
oh you puss. learn how to drive in the snow! haha.
yea i def think im going to do it this way. how will i know where to groove the output shaft? maybe drill and tap the yoke, slid it on, put paint on a bolt head, run that in until it touches, back it out, pull off the DS and have a paint mark on the output shaft... hmm?
but yea, thats a good idea, dont you already have a pic of your tranny cross member, i know i seen it before. ill go browse your thread!
EDIT: its not in your thread.. i know i've seen a pic of it on here!!
Old 01-17-2008, 02:53 AM   #284
3 Leaf Fab
Donahue's Avatar
did you repaint your truck NC?
Old 01-17-2008, 11:43 AM   #285
Fvck New Jersey
Tim99Zr2's Avatar
thats not his. that one is 98+ and fleet side, with different sliders, tires, wheels
Old 01-17-2008, 12:21 PM   #286
Fvck New Jersey
Tim99Zr2's Avatar
ok, so i think my front drive shaft needs to be roughly 28" at ride height.
im planning on getting square tube of. 2x2x1/4" at 16" and a piece of 2.5x2.5x1/4" at 18" long along with 8-10' of 1" Sch. 40 pipe for my shock hoops and tranny crossmember.
going to get a price now. think the DS lengths will be enough?
Old 01-17-2008, 02:13 PM   #287
got SFA?
Geoff03's Avatar
no thats steve's truck from zr2usa...its going one tons now. and 42s. and it has a cage now, and flat bad. plus it actually gets wheeled
Old 01-17-2008, 02:16 PM   #288
3 Leaf Fab
Donahue's Avatar
this is how i figured our last sq one. take your yokes and figure out where you are going to cut them off, and how long they are from the u-joint center to the cut. something like 3" is what i would expect. now flex your drivers side up to full compression and measure that distance from your yoke to yoke. this tells you how short it has to be able to go. say that is 26". now take your measurements from before, add them together for both yokes, and take that off this minimum distance. now we have 20". then take another 2" or so for safety and you have 18". now if you had two pieces of square tube that fit inside each other and were 18" long this setup would be about perfect. one more thing though, when i did it i forgot to take into account the part of the yoke that went into the larger square. if you do it that way, make sure you take that amount off the smaller tube's length.
does this all make sense? measure what the minimum needs to be and go from there.
Old 01-17-2008, 02:31 PM   #289
Fvck New Jersey
Tim99Zr2's Avatar
meh, thats alotta shit. i bet if i read it ill understand it!
i was just eye balling it, guessing lengths with it sitting in my drive way. but ill do it that way tomorrow donahue!! thanks again man.
this truck is going to need some 3leaffab stickers. i think you put as much work into it as i did
EDIT: i get it now!
Old 01-17-2008, 07:37 PM   #290
Registered dumbass
NC4x4's Avatar
Is that the one you are thinking about?
Old 01-17-2008, 11:14 PM   #291
Fvck New Jersey
Tim99Zr2's Avatar
exactly it, thank you!
so im going to get my shock hoops and tranny hoop bent up tomorrow. and i also think i am going to get my driveshaft material!
for my hoops i may have to bang an amish chick thou, could make an easy 200$ on top of them bending my stuff!! (yea, the amish are going to bend my pipe)
Old 01-17-2008, 11:16 PM   #292
Registered dumbass
NC4x4's Avatar
If you want to PM me I can give you info to contact me, if it would be easier that way. It's up to you, I just figure I can explain it easier, quicker, and less painlessly that way.
Old 01-17-2008, 11:18 PM   #293
Fvck New Jersey
Tim99Zr2's Avatar
just needed a pic, thanks for the offer thou
what'd you do for exhaust?.. ugh
Old 01-18-2008, 12:25 AM   #294
Registered dumbass
NC4x4's Avatar
The main reason I said I will try to get one after the snow is gone is because I'd have to get up under there pretty good to take a picture, and the ground is still pretty nasty for the time being.
I had all new exhaust put in after I ran practically "open headers" there for a handful of weeks. Got the drivers' side pipe tucked pretty neatly under the transmission and then had the back in look like this...
Old 01-18-2008, 12:27 AM   #295
3 Leaf Fab
Donahue's Avatar
fancy shocks
Old 01-18-2008, 12:28 AM   #296
Fvck New Jersey
Tim99Zr2's Avatar
hmm, looks like ill deal with the exhaust too. haha. dammit. this is alotta work!! thanks for the pics man, they help!
i can get a ford 9" here for 50$ i wonder if i should grab it? someone had 2 for sale locally
Old 01-18-2008, 12:30 AM   #297
3 Leaf Fab
Donahue's Avatar
28 spline? 31 spline? full width?
Old 01-18-2008, 12:31 AM   #298
Fvck New Jersey
Tim99Zr2's Avatar
i dunno. ill send an email, and call tomorrow
guessing i'd want 31 spline, but i dont think id want full width
Old 01-18-2008, 12:32 AM   #299
Baggey22's Avatar
the 9" may be full width, also the gearing may be off, and your bolt patterns will be different. . . again.
Old 01-18-2008, 12:32 AM   #300
Fvck New Jersey
Tim99Zr2's Avatar
fvck, nevermind i just found a FF 14bolt with 4.10s!! 150 OBO?
out of a chevy, 70's 1ton
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f221/project-fix-to-busted-cv-shafts-and-wheel-bearings-56k-no-no-329989/
Posted By For Type Date
ZR2 USA -> coupld pics This thread Refback 01-14-2008 11:59 PM
Xmas vacation plans? This thread Pingback 01-03-2008 05:37 AM
Page generated in 0.66059 seconds with 31 queries
[Output: 229.21 Kb. compressed to 210.11 Kb. by saving 19.10 Kb. (8.33%)]
