LinkBack (2) | Thread Tools |
#51 |
3 Leaf Fab
Re: Project: Fix to busted CV shafts & wheel bearings! 56k no no
is that front hanger for the rear spring a zr2 specific one, or is that some aftermarket part? as for my comment on the 30* shackle, that is my personal preference. the more vertical the shackle, the more stable it is, but at the cost of (a little) flex. the more you angle it, the better it flexes, but you give up some stability. i would for sure reinforce those shackle mounts too. did you use weld on perches for the rear flip, or the "flip kit"? as for cutting the overload short, but leaving it in the pack, i would do that. the only reason though is to keep that extra 1/2" of lift it gives you. if you take the spring pack apart to put in an aal, be sure to replace the center pin with a new one.
and, the rear pinion angle look fine to me check the angle of the rear output with an angle finder, and then compare it to the pinion angle. at static height your pinion should be tipped down about 3* from what ever the output is at. my rear output slopes down at 5* in my blazer FYI. |
#52 |
Maybe it was just the picture I looked at. As I said I was eating pancakes at the time so I wasn't 100% paying attention.
#53 |
Fvck New Jersey
when you get parts cheeks... ok, as for the shackle hanger, i ordered a bushing and i will pick it up weds. this way is just a temp job, by no means staying on there. haha. the shackle mount should be tuff enough for what i do. i cut my old perches off, and re welded them on, (i just seen that flip kit fail on here. not good) i could prob use any spring off a vehicle with a 2" wide pack? or do i need a Z one. and will do on the center pin! i didnt have any vibrations at all, truck drives really nice, steering is a little loose, i think the pitman arm will help it? all in all, i feel pretty good about myself for being able to accomplish this in roughly 5 days thanks guys. ![]() |
#54 |
You can do anything as long as it is the same width. If it's from a different vehicle you may have to drill a new center pin hole but thats not a big deal.
#55 |
Fvck New Jersey
sweet. i hope i can find something to put good arch back in it. what would be a good one to use? any ideas. prob something off a full size? |
#56 |
WTF?
More lift per springs and ditch the BL and it'll be major
!once again good work Tim. |
#57 |
Fvck New Jersey
#58 |
WTF?
Hell yeah! |
#59 |
3 Leaf Fab
#60 |
Fvck New Jersey
ok. would that leaf come off a old full size front axle, or newer rear? where could i find it? and thanks for the warning about drilling it out! |
#61 |
3 Leaf Fab
#62 |
Fvck New Jersey
hmm thank you! your so helpful!
#63 |
i love my chevy
#64 |
This is why I'm going with full size springs to start with. I've already seen them work nearly perfect in another application.
#65 |
Registered Asshole
Location: Moscow, PA / Mansfield, PA User is: OffLine |
#66 |
Fvck New Jersey
well i got some pics, but im st my bros house right now, ill upload them when i go home!
#67 |
Registered loser
ur gonna half to wait in line. besides we half to do ours at the same time to be twins!!!!! |
#68 |
Twins like Amos and Drmrman?
#69 |
Fvck New Jersey
but gayer
#70 |
Registered Asshole
so yeah... how bout that damn pitman arm!!!!!!
next time i'm gunna tell ya everythings easy. by the way... the basement is finished so i'll be good to come down again sometime soon! |
#71 |
damn pitman arm?
#72 |
Registered Asshole
#73 |
What actually holds the pitman arm on?
And did he have to use the tool to get the old one off or just regular tools? |
#74 |
Fvck New Jersey
brandon gave me his pitman arm puller to use, tightened it down and tapped the pitman arm with a hammer and tightened the bolt up as i taped the pitman arm. it was a breeze..
the pitman are is held on by just that one nut and lock washer. I've heard they can be hard to pull off. i also heard t-bars are a bitch to get out, mine popped right out with a couple taps with a mini sledge hammer |
#75 |
Registered Asshole
![]() but yeah like tim said... big nut and washer. i used a 1 5/16" socket but it had a lil slop in it so i'm thinkin its metric....30 some odd millimeters |
#76 |
Fvck New Jersey
couple pics.. i need my wheels back!
#77 |
Registered Asshole
33s look tiny now! need 35s
#78 |
Fvck New Jersey
nah, ill keep the 33's... for now
#79 |
Registered Asshole
plus i'd be a lil worried bout wheelin 35s on that d30! just me though!
#80 |
35s would be okay if you didn't have the vacuum disconnect axle shaft
#81 |
Fvck New Jersey
dont matter, im keepin 33's just spent 800$ on them. haha
#82 |
3 Leaf Fab
#83 |
Fvck New Jersey
eh.. its rinkrat.. i dont care. besides, its not done yet.
#84 |
Fvck New Jersey
thanks for showin me thou.
#85 |
3 Leaf Fab
#86 |
Fvck New Jersey
haha, i feel my truck is done good. i feel my way is better than cutting into the frame, how he did it.
oh well! |
#87 |
WTF?
I love how people are quick to judge,
as far as I'm concerned he can stay off this forum.Also as you've already stated you're still working on it,right?guess they didn't see that. Fock it,good job in my book Tim. |
#88 |
Fvck New Jersey
well thanks o2, i never consider anything 'done' my truck is always a work in progress. hell if something breaks, i know to fix it better. live and learn
#89 |
Registered Asshole
wow... what got into that kid. like he has nothing better to do with his life than trash anything and everything on here
#90 |
Fvck New Jersey
i think he hates the entire s10forum now.. WAY TO GO amos.. haha
#91 |
If only he made it like a constructive thing. Like make the title "Check this out" and say this is this 19 y/o's first swap do you guys see any safety hazards? No matter what you will get criticism with an SAS because there are so many ways to do it. Like I pointed out earlier there are things that you need to fix, but you know that and as long as you fix them you'll be fine. Basically keep your truck safe for yourself and those around you.
And speaking of safety I saw something when I was looking over your pictures again. Your rear brake lines need to be redone BADLY. You need flexible lines because as your rear axle flexes so will those metal lines. As the metal lines flex they will most likely stress out and break. Which will render your rear brakes useless. Just looking out for ya, don't want to see another fellow S10 owner fly into a tree because of something thats pretty easy to fix. |
#92 |
Fvck New Jersey
yea, i also need new front brake lines.. the rubber ones, i got the s10 ones on there still. i just needed to get it done before the new year, so i have it for work, since its my DD. but im outta money. haha
#93 |
Just keep an eye on those rear ones.
#94 |
Fvck New Jersey
i keep checking things over once or twice a day! they should be ok for now, im not wheelin it or running it hard at all!
#95 |
so what are you doing for your front wheels? getting adapters or new rims?
#96 |
Fvck New Jersey
adaptors/ spacers, the front end feels way too narrow
#97 |
Registered dumbass
#98 |
Still 2 High
That's cool as hell, makes me want to do a solid front axle on my first gen so bad.
On another note, if I parked my truck next to yours, my roofline would be below the top of your rear fenderwell ![]() |
#99 |
3 Leaf Fab
#100 |
Registered dumbass
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f221/project-fix-to-busted-cv-shafts-and-wheel-bearings-56k-no-no-329989/
| ZR2 USA -> coupld pics | This thread | Refback | 01-14-2008 11:59 PM | |
| Xmas vacation plans? | This thread | Pingback | 01-03-2008 05:37 AM | |
